Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jun 26, 2017 at 7:50 PM
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    Anyone have the build thread on the Dirt Designs center mount first gen?
  2. Jun 26, 2017 at 10:01 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wasn't much if a build thread. It's in the main lt area. Search should pull it up easy
    FlapJack935[QUOTED] likes this.
  3. Jun 26, 2017 at 10:19 PM
    stumbles
    stumbles 1 eye
    bryan
    mesa
    2002 White Double Cab
  4. Jun 27, 2017 at 5:54 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Deaver is in Santa Ana.....not to bad of a drive from SD. Call them...tell what you want....should be that easy.
    J.Maynard[QUOTED] likes this.
  5. Jun 27, 2017 at 12:31 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Was someone on here looking for stock lca's a little while ago? I got a spare set I'll sell on the cheap that's ready to go and then I'll have the ones that come off my truck when I get my LT installed.
  6. Jun 27, 2017 at 12:59 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I know some guys up in Northern VA that would likely take them if you are willing to ship.
  7. Jun 27, 2017 at 1:54 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Sure I'll ship them so ask around. Tell them $100 plus shipping. I imagine shipping will be another 30-50. If they are still actually interested then I'll find a box and get a more accurate quote.
    Coot83[QUOTED] likes this.
  8. Jun 27, 2017 at 2:10 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Whaaaat? Why lol, never throw away stock parts, there are PLEEENNNTTYY of people that need/want spare or replacement parts on here or CL.
    ls1 prerunner likes this.
  9. Jun 27, 2017 at 2:31 PM
    VolcomTacoma
    Jeff
    NorCal
    Nah, you'd be surprised the random parts people want here lol
    ls1 prerunner, jeffz0rz and erok81 like this.
  10. Jun 27, 2017 at 8:18 PM
    J.Maynard
    J.Maynard Well-Known Member
    Josh
    Oceanside
    2001 Tacoma Long Traveled Daily
    -K&N cold air Intake, Spintech catback exhaust with fender outlet, Total Chaos Front Long Travel with Fox 2.5 10" coilover, Bed cage with Fox 2.5 16" smoothies with dsc, TC shackles, fiberwerx bedsides, frame boxing,
    any body run national leaf springs? found a pair on race dezert guy is claiming 17 inches of travel?
  11. Jun 27, 2017 at 9:06 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    At ride height for high speed stuff you should be 60% uptravel and 40% downtravel is my understanding of things
    erok81[QUOTED] likes this.
  12. Jun 27, 2017 at 10:25 PM
    dirt addiction
    dirt addiction Well-Known Member
    Flagstaff
    Solo motorsports XLT LT, foxshox
    Are you building shock mounts or bolting in coilovers?
  13. Jun 28, 2017 at 12:25 AM
    dirt addiction
    Flagstaff
    Shit that's easy then. Run a poly bump and set your ride height. Done
    tubbsisland and Coot83 like this.
  14. Jun 28, 2017 at 8:23 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    Zero preload does not mean zero up travel. It simply means that you are not adding any load to the coils under their full extended length. Based on your spring rate and coil length You may very well have several inches of of travel left on a non preloaded coil.
    For a bolt on LT kit and its corresponding shocks you are really only adding preload to determine ride height which should be in a place to achieve the amount of clearance you need for tires or general GC without going too high that you are prematurely wearing things like CV boots or other wearable components. Also if you add too much you risk coil bind before the shock has fully compressed which will lead to a snapped coil but again on these off the shelf kits and shocks it should be as simple as just setting the desired ride height and going from there and possibly making a rate change if your truck is exceptionally heavy.
  15. Jun 28, 2017 at 8:45 AM
    DirtRev.
    DirtRev. Kick the tires and light the fires...
    Oregon
    95 4x4 LT Tacoma
    Blood, Sweat, and Beers
    The less preload on the coils the better the ride. I'm pretty sure more down travel is desired rather than up. Look at how low the stance is on Trophy trucks or class 1s they are squated at ride height but have loads of travel the majority of which is droop. If your happy with ride height at 0 preload mob it.
    Caboose117 and Coot83 like this.
  16. Jun 28, 2017 at 8:51 AM
    Rextinkleton93
    Rextinkleton93 Well-Known Member
    Kyle
    Phoenix, AZ
    2018 Superwhite Tundra Crewmax 4x4
    It's the opposite actually. Bump travel is what's going to make the ride not suck. Most tt's and such sit nearly in the middle of their travel range. They look like they squat because of 39's (or big tires in general), propperly fitted fiberglass.
    how much travel you have isn't the most important factor though, it's all about the shocks!
    LTDSC, ls1 prerunner and stumbles like this.
  17. Jun 28, 2017 at 9:00 AM
    dirt addiction
    Flagstaff
    We've been over this already. It's not about how well it works it's about how many tubes you have. More tubes=more bitchez. It's simple math guys come on meow
    jubei, LTDSC, ls1 prerunner and 9 others like this.
  18. Jun 28, 2017 at 9:13 AM
    DirtRev.
    Oregon
    95 4x4 LT Tacoma
    Hmm I've always understood it a little differently but regardless with #erok81 question as long as spring height/rate is appropriate 0 preload will result in best ride quality.
  19. Jun 28, 2017 at 9:45 AM
    DirtRev.
    Oregon
    95 4x4 LT Tacoma
    If you have the proper spring height and rate it will give you an exceptable amount of both up/down travel while settling at a close to desired ride height. in your example above if you had 0 preload and were sitting with 1inch of up travel before bump stop you have the wrong springs, likewise if you only had 1 inch of down travel, again wrong springs. In a perfect world you would get the correct spring height/rate to give you desired ride height without preloading. Preload does exactly that adds a load to the spring prematurely as in before you ever hit a bump your spring already has more of a load thus it will inherently be a harsher ride then same setup without preload. Think of a spacer puck lift all that is doing is preloading the spring to gain ride height. Do you think a truck with spacer puck rides as good as one without? Same principle.
  20. Jun 28, 2017 at 9:49 AM
    dirt addiction
    Flagstaff
    What it comes down to is your bolting in coilovers onto a kit. All the geometry is done for you, that's what you paid for. I understand your argument but for your application, it's invalid. Your gonna setup your preload to your preference ie level, brolean, or stink bug. I'm assuming your stock or springunder in the rear so you won't have any adjustment back there. If your building a trophy truck then your shock sizes/shock location/ 60/40 ratio come into play. My trucks linked and I like it to sit as low as possible, but I have adjustment in the rear to go along with the front and that's the way I like it. Set it where you like it and play with it if you want. It is your truck after all
    jubei, LTDSC, Dalandser and 2 others like this.
