Long Travel BS Thread
Discussion in 'Long Travel Suspension' started by amaes, Aug 20, 2010.
  1. Jul 5, 2018 at 10:11 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Because jumping curbs is for long travel and he's mt
    Coot83 and ls1 prerunner like this.
  2. Jul 5, 2018 at 10:12 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    so he's just doing it wrong by smashing into the front of the curb vs jumping off of it ?
    jeff b and FlapJack935 like this.
  3. Jul 5, 2018 at 10:25 AM
    dillonk1602
    dillonk1602 Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    does anyone know the torque spec on a 2018 tacoma for the u bolts ?
  4. Jul 5, 2018 at 10:33 AM
    DMCtacoma
    DMCtacoma Well-Known Member
    Brian
    Prescott,Az
    08 caged long travel preruner
    Almost everything
    With the 2nd gen 2wd you get kinda screwed because no one makes a full floater that can still run the speed sensors to control the trans. So you're kinda stuck with the semi floater.
    Basikbiker[QUOTED] likes this.
  5. Jul 5, 2018 at 10:37 AM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
    i get a alignment after every dezz trip
  6. Jul 5, 2018 at 10:41 AM
    Basikbiker
    Basikbiker Well-Known Member
    Trav
    09 AccCab 4x4 spaceship
    My doors are the only stock things left besides the headlights
    Well convert to 4wd....duhhhh lol I wonder if you could adapt the gear driven sensor to a 2wd trans...or so microswitches in a gate shifter and make it shift like a manual valve body
  7. Jul 5, 2018 at 12:18 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    "One biffs many curbs whilst Mall Crawling"
    :gossip:
    Stryker420 and snowsk8air2 like this.
  8. Jul 5, 2018 at 2:01 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    https://www.tacomaworld.com/threads/the-torque-spec-guide.318116/
    All of the suspension specs should be the same as 2nd gens. There's a big debate over the u-bolt torque spec, but no one has posted about losing an axle on here from following these specs.
    dillonk1602[QUOTED] likes this.
  9. Jul 5, 2018 at 2:29 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Spec should be 73ft lbs. the factory manual these come from typo'd it to being 37. I usually just go to 80 and call it good.
    dillonk1602 likes this.
  10. Jul 5, 2018 at 3:45 PM
    dillonk1602
    dillon
    san diego
    tacoma 5 lug
  11. Jul 5, 2018 at 6:24 PM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Oh if “ biffing curbs “ means urban whoop shock tuning ( IE: speed bump and speed hump thrashing at 50 mph) ...call me the biffmeister
  12. Jul 5, 2018 at 8:45 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
  13. Jul 5, 2018 at 8:53 PM
    phillipthetaco
    phillipthetaco Well-Known Member
    Marcus
    Mesa,AZ
    2007 Tacoma Prerunner Barcelona Red
    Wheels and Tires: (5) 35/12.50/17 Toyo R/T tires (5) 17” x 8.5” Matte Black Method NV wheels Black extra thread (ET) spline lug nuts Front Suspension: Total Chaos 3.5” long travel kit Fox 8” x 2.5” coilovers with remote reservoirs Wheelers Super Bumps Limit straps and clevis mounts Total Chaos shock tower gussets Total Chaos cam-tab gussets Maxtrac 4 inch lift spindle Larger Lexus rotors, calipers and brake pads Stainless steel extended brake lines Rear Suspension: DMZ Fabrication Spring Under Kit Fox 16” x 2.5” smooth body shocks with remote reservoirs Fox 4” x 2.0” hydraulic bump stops (shortened to 3”) Custom low profile bolt in bed cage (1.5” DOM tubing) Boxed frame from fuel tank back Custom tube rear cross-member (1.5” DOM tubing) Custom bump stop mounts and strike pads Stainless steel extended brake lines Performance: AFE cold air intake w/reusable filter Nitro 4.88 Gears w/heady duty seals Custom driveshaft with grease-able slip-yolk Odyssey Extreme battery Armor: Custom front tube front bumper (1.5” DOM tubing) w/custom skid plates and valance Custom rear tube bumper w/license plate mount and led light Exterior Accessories/Body: SDHQ “y-strap” for spare tire mounting Harbor Freight 1.5 ton floor jack w/quick release mount Fiberwerx fiberglass front fenders Fiberwerx fiberglass “TT” style bedsides Custom window tint and tint visor Retrofit style Headlights LED tail lights Custom black mesh grill Viper alarm Rigid Industries 30 inch amber LED Rigid Industries 20 inch white LED Rigid Industries D2 Blue rear chase lights X2 Interior: Pioneer touch screen head unit Kenwood mono amplifier Rockford Fosgate 12" P3 subwoofer Infinity Kappa door speakers (4) Weathertech front floor mats LED interior dome lights
  14. Jul 5, 2018 at 8:54 PM
    phillipthetaco
    Marcus
    Mesa,AZ
  15. Jul 5, 2018 at 9:08 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I'll give you $19.95 and a pack of big league chew in your choice of flavor
    tubbsisland, Bentrodder and Dalandser like this.
  16. Jul 5, 2018 at 9:45 PM
    phillipthetaco
    Marcus
    Mesa,AZ
    add the K to your price and i'll even deliver it for you:thumbsup:
  17. Jul 7, 2018 at 6:16 AM
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    It's apparently not that hard to cinvconthr auto to a manual shifter, but it throws a bunch of warning lights.
  18. Jul 7, 2018 at 7:47 AM
    Basikbiker
    Trav
    If your serious about putting a 5k$ axle into your truck and using it for its purpose....who cars about some warning lights?
    Arcticelf and Dalandser like this.
  19. Jul 7, 2018 at 9:00 AM
    Basikbiker
    Trav
    Nice! Clean simple fix
    AssBurns[QUOTED] likes this.
  20. Jul 7, 2018 at 1:13 PM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    Cool! Definitely will have to look into those
