Long Travel information.
Discussion in 'Long Travel Suspension' started by mjp2, Oct 13, 2009.
  1. Mar 28, 2020 at 10:58 PM
    #401
    CaveCreekTacoma
    CaveCreekTacoma New Member
    Chase
    2003 Tacoma 4x4 v6
    Blistein coils, 3 in body lift, tube bumper, and many cosmetic mods.
    Dumb question but just curious: why do all of these kits require fiberglass fenders? Would it be terrible to run LT with stock fenders?
  2. Mar 30, 2020 at 7:15 PM
    #402
    Wildwilly
    Wildwilly Well-Known Member
    David
    Southern illinois/ metro east STL area
    2015 DCSB SR5
    -LT -pelfreybilt Armor
    im still running stock fenders with my all pro kit. had to trim around 3" give or take. even then sometimes it still rubs
    whatstcp[QUOTED] likes this.
  3. Nov 18, 2020 at 4:47 AM
    #403
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    Why cant anyone build a decent linked kit for the rear on a 16+? Everyone I see running it is custom; given there are a couple plug and play bed cages, but what about the rest of it? I'm sure there is a market given performance and ride improvements with it for less than the cost of doing the front. The 1st post in this thread is woefully out of date and som of the links arent even working anymore.
    On my build we are find some rear guidance, but much of it is custom. Work missing details are: trailing arms, break length requirements, gas tank mods (including if they will throw a code or even fit in the spare tire area), pan hard details, etc.
    There is a ton of room back there once the tank is moved, but a simple all around kit would be great. Even better would be a cantilever kit to save 100% of the bed, but for me it is a bridge to far to go the cantilever route given the experience required to get the geometry right.
  4. Nov 18, 2020 at 10:45 AM
    #404
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    I think its basically because the install of even a kit requires so much custom work, that by the time you understand enough about the kit and have enough tools to install it, you might as well designed your own. Also most of the installs for this type of go fast truck is destined for California, where playing with the gas tank provides specific challenges.
    And there are kits out there for you. Here's the rear long travel cantilever kit for the 3rd gen you inquired about: https://www.simmonsind.com/
    amadougrand[QUOTED] likes this.
  5. Nov 18, 2020 at 10:52 AM
    #405
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Website under construction still; is it still brand new? I’ll give them a call. Where I am the emissions is not an issue and I’m actually building my mountain wagon, not desert runner. Wife just wants smooth and I’m tired of her excuses for not traveling the mountains with me.
  6. Nov 18, 2020 at 10:57 AM
    #406
    DocME
    California
    '07 FJ Cruiser
    I don't know much about it, so I couldn't tell you. I know they have a bookface page with some videos. I'd try letting some air of the tires and see if it appeases the wife! Everything feels softer with less than 20psi.
  7. Nov 18, 2020 at 11:02 AM
    #407
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    Lol. I dropped them to 4lb for her one day and then she was worried about how they looked. She’s a little bit city and then didn’t like waiting for me to air them back up. Running 25lbs.
    I found their FB page and was looking at them. Looks like they have done both SUA and SOA on Tacoma’s. Looks like it may be an option. Saves the tank move also.
  8. Nov 18, 2020 at 1:01 PM
    #408
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I'd be careful with going to a sua or link setup without seeing it work on multiple trucks similar to yours or built from a shop with a highly reputable product history. Here's another SUA for Tacomas which is bolt on.
    https://www.instagram.com/p/BjgOLbjli1g/?igshid=jmta3i24cd2d
    The thing with a fully bolt on link kit is there is nothing you can build that will be bolt on. Welding link mounts and axle dressing is necessary. Therefore you will need measuring and welding capabilities that basically make the rest of the process doable if you're diy. Most linked trucks go with a cage for required protection when you're able to hit highway speeds off road. Eventually the builds just get to the point where a daily driven (DD) link it isn't really profitable for any shop yet.
    Key issue here:
    No one should replace any suspension kit prior to tuning the shocks - it's like not tuning after any engine mods - you're not going have the best performance from what you have.
    amadougrand and DocME like this.
  9. May 31, 2021 at 8:55 AM
    #409
    81Trekker
    81Trekker Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Simple because 3 link with a panhard bar will never work that great and the effort required is way more than a SUA for the same amount of travel. Also you can get almost 20” of travel and keep the shocks under the bed
  10. Jun 8, 2021 at 8:33 PM
    #410
    tacotruck2005
    tacotruck2005 Goodolboys 4x4 section
    Bozeman Mt
    camburg or dirt king is there any reason to pay a little bit more for the camburg?
  11. Jun 8, 2021 at 11:16 PM
    #411
    DocME
    California
    '07 FJ Cruiser
