Long travel installed & TC not working??
Discussion in 'Long Travel Suspension' started by rzimm001, Mar 2, 2010.
  1. Mar 2, 2010 at 10:38 PM
    rzimm001
    rzimm001 [OP] Tearmytaco
    Bobby
    Wildomar
    08 PreRunner SR5 Long-Travel
    King 10" coilovers w/ resi. 3.5" over long travel kit. Factory spindles w/ ALLPRO gussets. Total Chaos tower gussets. Energy Poly cab mounts and steering rack mounts. Glassworks fenders and bedsides. Home fabbed bed cage. King 2.5x16 bypass shocks in the rear. DMZ long travel rear end. Race radio (2meter). Removed secondary carbon air filter. Exhaust dumped before the axle / no muffler. Phram fresh air cabin filter. K&N replacement filter, After market stereo, Grillcraft grill, custom fabled roof rack with 7" HID's, PRP race seats.
    Just helped a buddy install the camburg lt kit on his 2010 pre runner. The traction control light keeps coming on and off. Any ideas? We're bewildered... Thanks
  2. Mar 3, 2010 at 6:53 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    :notsure: turn TC off?
  3. Mar 4, 2010 at 4:21 PM
    rzimm001
    Bobby
    Wildomar
    Cleaned the sensors and it seemed to help. Then the problem re appeared. He said he's going to try some new sensors. Apparently they are not expensive.
  4. Aug 29, 2010 at 8:50 PM
    motox_315
    motox_315 Member
    Sean
    Sac
    2010 DCLB SR5 4x
    3" truxxx lift
    Traction and stability control use yaw rate sensors as well as wheel speed sensors for info on slippage or stability. With lc the truck will move around more than designed causing it to activate or shut off and set codes. Still worth it in my opinion.
  5. Aug 29, 2010 at 8:53 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
  6. Aug 29, 2010 at 9:09 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Do all second gens have traction control?
  7. Aug 29, 2010 at 9:10 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
  8. Aug 29, 2010 at 9:15 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    First time I've heard of it. When did this happen, 09's & up, Sport package?
  9. Aug 29, 2010 at 9:19 PM
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    Did you make sure none of the wires were tight? If everything looks fine, just call Camburg in the morning and talk to them. They are good people over there and will help get the problem fixed or PM MJP2 he runs that kit. But his truck is not a 2010 so idk if he has TC.
  10. Aug 29, 2010 at 11:03 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    my tc light comes on when i make hard turns like freeway on ramps, too much lean without sway bar, turn it off. It will come on because of the lean no matter what you do.
  11. Sep 8, 2010 at 10:52 PM
    rzimm001
    Bobby
    Wildomar
    2009 offroad model. I guess he had a lot of issues with the sensors. Busted a couple sets up them or so he thinks. Finally got the matter resolved by the third set. Evidently they are sensitive little bastards so becareful when removing and installing those wheel bearing sensors. I just installed my own set up camburg spindles and had no such problem after completeing the install.
