Longer brake lines needed with 5100s?
Discussion in 'Suspension' started by michaelg589, Nov 5, 2010.
  1. Nov 5, 2010 at 2:45 PM
    michaelg589
    michaelg589 [OP] Well-Known Member
    I did a search and couldnt find any hard facts about this particular situation. Most of what I found say you "shouldn't" need longer brake lines unless you lift your truck 3+ inches. However, After my recent AAL install and seeing how extended the brake lines were with the stock shocks, I am concerned about how they will handle a longer Bilstein 5100 shock. I only have the AAL kit from toytec in the rear on non-TSB springs. ( 4 leaves all together). My plan is too use 5100s at all four corners and Maybe Eibach springs up front.
    Thanks for any info!
  2. Nov 5, 2010 at 2:49 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    No. When you change shocks in the rear that doesn't affect lift. So you will be fine. The fronts only go up to 2.5" so you won't need them in the front either.
  3. Nov 5, 2010 at 2:55 PM
    michaelg589
    The front shocks will stay at 0. I was worried about how far the rear shocks will extend. I like to do some off-roading once in a while. Last time I went, I think i had all four wheels off the ground at one point. lol
  4. Nov 5, 2010 at 3:02 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I run a 3" leafpack with OME rear shocks and stock lines. I just bent the brake line bracket up to give me more play. I've had both my rear wheel off the ground and no issues. But your at what? 1.5"? 2"? In the rear. I dont see a problem.
  5. Nov 5, 2010 at 3:04 PM
    michaelg589
    Cool. Just want to be sure. How are the OME shocks?
  6. Nov 5, 2010 at 3:15 PM
    senna
    senna Well-Known Member
    San Jose CA.
    09 DBL CAB TRD-OR OME shocks 885 and AAL
    I would jack up the truck from the frame in front of the the left rear wheel until the wheel is off the ground and see how it effects the the brake lines. I am the same as you, AAL and stock leaf pack and it was too close for me, the price for failure is way greater than the price of lines.
  7. Nov 5, 2010 at 3:16 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    They are ok. They do their job.
  8. Nov 5, 2010 at 3:31 PM
    michaelg589
    kinda how i felt.
