Look at my CV angles! :(
Discussion in 'Suspension' started by skybob, Apr 19, 2011.
  1. Apr 20, 2011 at 5:54 PM
    Fabulous
    Fabulous Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    Dude, you paid $29 for your OME CB drop? I got mine from Fat Bobs for $12.
  2. Apr 20, 2011 at 5:56 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Oh , I was just guessing , I couldn't really remember , mine was included with my kit .
  3. Apr 20, 2011 at 9:44 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I got mine from Home Depot: $2 worth of washers.
  4. Apr 20, 2011 at 9:48 PM
    OZ-T
    Peter North
    British Columbia
    Yes , it is just a glorified block of metal .
  5. Apr 20, 2011 at 10:05 PM
    JC47
    JC47 Well-Known Member
    British Columbia
    08 TRD Sport DCLB 4X4
    OME 885, 5100's, 1.5 AAL, DC2's, 265/75/16 Duratracs. Leer Cap, Debadged.
    Do you have pics of your new lift?
  6. Apr 20, 2011 at 10:09 PM
    OZ-T
    Peter North
    British Columbia
  7. Apr 21, 2011 at 4:23 AM
    empitec01
    empitec01 New Member
    Bill
    Southern California
    02 PreRunner
    Driver Side Axle Looks to be Aftermarket, while Passenger Side appears to still be the OE. Look closely at the Inboard Joint on the aftermarket Axle, on some aftermarket axles the center shaft will actually strike the raised areas between the Tripod Tracks on the inner housing when put into a little steeper angle than stock, whereas the OEM inboard joint will not be affected by these sligh angle changes.
  8. Apr 21, 2011 at 9:51 AM
    JC47
    British Columbia
    Looks great, hopefully I'll have mine in by the end of summer!
  9. Apr 21, 2011 at 11:32 AM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    That lift looks good. Do you have a thread that has what you did?
    Thinking my stock leafs are done and now debating on the whole new lift system.
  10. Apr 21, 2011 at 1:16 PM
    skybob
    skybob [OP] Well-Known Member
    Yes.
    I had the one axle repaced when I bought the truck, the boot was torn and the axle was bad. This didn't change anything with vibration, the vibration came with the lift. It's still at the shop, they are swamped and so I'm just playing the waiting game!
  11. Apr 21, 2011 at 1:39 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
  12. Apr 21, 2011 at 7:24 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Those angles look good IMHO.
  13. Apr 21, 2011 at 8:03 PM
    OZ-T
    Peter North
    British Columbia
    If both those pics were taken on flat ground why is one LCA level and the other cocked downhill a couple inches ?
    That's what I was wondering .
  14. Apr 22, 2011 at 11:56 AM
    skybob
    THIS... The shop said everything in the front end is tight, the angles all looked fine, the carrier bearing is no longer vibrating but I still have the noise. I checked to see if it goes away in 4x4 and it does. I guess I'll try getting these fixed. the control arms look offset from the camera angle I think, I looked under it today and can't see anything with my eye that makes ones sit differently than the other and it's parked in the same spot at my work.
    It does sound like a bearing type noise, and it seems to be getting worst, or it's just bothering me more. Hope it's the needle bearing :D
  15. Apr 22, 2011 at 2:28 PM
    #35
    905Taco
    905Taco New Member
    Vnacouver Island
    07 taco TRD
    3" fabtech lift
    I have the same issue, just purchased my 07 DBL cab. Put in a fabtech 3" lift. same vibration but at 60 KMH. thouht it was tires so i rotated them. While they were off I spun the rotor and saw that the drive axel was spinning off its axis which would explain the vibration. 4wd takes it away as well. I am thinking bearing but cant explaing the offset driveshaft, shouldnt happen with the CV's. and why does 4wd take it away.
  16. Apr 22, 2011 at 9:18 PM
    #36
    snorola
    snorola Well-Known Member
    Brett
    Canmore Alberta
    06 4x4 Dbl Cab
    SAW 2.0 Coilovers Eibach 14" 650lb springs Camburg UCA's All pro expo springs OME rear shocks All pro front bumper All pro IFS skid All pro sliders SCS f5 matt black rims Lightforce blitz 240's
    I'm betting this is the problem too! I have this problem as well
  17. Apr 22, 2011 at 9:20 PM
    #37
    MOT
    MOT Prez of @BattleBornToyotas
    Daniel
    Las Vegas
    08 DB DC 4X4 Sr5 Sport
    Black Housing Head, Custom Retro fit, T-Rex #2 Eyelids 50 inch ToughLight Radius Bar and 2 20 inch Bars behind grill with BAMF mount, T-Rex #2 Eyelids, Custom Vegas Dezert Fab Front Bumper and Rock Sliders,Wet Okole's, WeatherTech Mats, Magnaflow Exhaust, Pro Comp 6 InchStage 2 Lift, K&N Intake,
    Balance tires?
  18. Apr 22, 2011 at 10:13 PM
    #38
    905Taco
    905Taco New Member
    Vnacouver Island
    07 taco TRD
    3" fabtech lift
    I did this but that wouldn't explain the relief under 4wd. Will look at needle bearings! Any special tools needed?
  19. Apr 22, 2011 at 10:28 PM
    #39
    OZ-T
    Peter North
    British Columbia
    Hey man , where on Van Island are you ?
    :canada:
  20. Apr 23, 2011 at 11:21 AM
    #40
    skybob
    Let me know what you find! I'm pretty sure that's my problem as well.
