Look to Buy Portable Air Compressor
Discussion in 'Buy / Sell / Trade' started by Fred4, Mar 14, 2013.
  1. Mar 14, 2013 at 10:21 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    2002 v6 4WD Auto TRD Xtracab
    Hey, I'm looking to get a portable air compressor for my 2002 Tacoma. Just for the tires right now, but maybe I will add a front locker down the line. I dunno how useful it would be or what the extra expense would be like, but maybe something to run some air tools as well, though that's a tertiary concern.
    Anyone got anything like that used?
    Edit:
    Also appreciate suggestions on models if you don't have one for sale yourself.
    And if a mod could change the title to "Looking to Buy..." I would feel less retarded.
  2. Mar 14, 2013 at 10:28 AM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Hey welcome to the forum!
    Check out the ARB's for the whole locker and air tool route. Make sure you add a tank as well... or if not the monies for that go to harbor frieght. They have a couple that will handle the tires and you can save for a better setup.
  3. Mar 14, 2013 at 10:38 AM
    medic2230
    Murph
    Bama! Roll Tide
    Actually I was looking at the ones smittybilt has and they can be mounted and a tank added to them too. Cheaper too.
  4. Mar 14, 2013 at 10:40 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    Oh jeeze, my first post. I thought I had posted here before, but I guess not.
    Where would you locate a tank? Does it fit in the engine compartment? What size tank am I lookin at?
  5. Mar 14, 2013 at 10:47 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
  6. Mar 14, 2013 at 11:28 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
  7. Mar 14, 2013 at 11:39 AM
    SupraT
    SupraT Tacoma Lover
    Tony
    Columbia Falls
    98 TRD SR5 4x4
    3" Lift Three leaf add and Bilstin 5100"s in back and Donahoe coilovers in front, Tinted Windows, Blackened parking light, tinted brake lights, clear bumper lights, Blacked out turn signals, AVS vent visors, Electric Fan mod, K&N CAI
    Take a look at Wheelers off road they are a vender on this site, they have a few different options
  8. Mar 14, 2013 at 11:59 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    Thanks, I'll check it out.
    Edit: I like the prices on Viair compressors there. And I like the idea of being able to upgrade to a tank later on. Do I need a constant duty one if I wanna run air tools? I also do not plan on having huge tires, as I'm more interested in gas mileage than serious rock crawling.
  9. Mar 14, 2013 at 12:02 PM
    medic2230
    Murph
    Bama! Roll Tide
    I'm going to mount the compressor and tank under the bed.
  10. Mar 14, 2013 at 1:41 PM
    SoCaltaco65
    495 new, ill go 450
  11. Mar 15, 2013 at 10:13 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    Yea, too high for me I'm afraid. I'm probably looking at a couple hundred at the most.
  12. Mar 15, 2013 at 10:17 AM
    2ski4life7
    2ski4life7 Well-Known Member
    Seattle WA
    17 DCLB 4x4 TRD Off Road Previously '12 DCLB 4x4 SR5
    Adding these tanks is no one ever worried if someone rear ended you and the tank somehow ruptured?
  13. Mar 15, 2013 at 10:19 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I don't think you drive around with it filled all the time. Just when you are going to use it, fill it up.
  14. Mar 15, 2013 at 10:23 AM
    2ski4life7
    Seattle WA
    I see. Good to know.
  15. Mar 16, 2013 at 10:04 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    Still looking for used one if anyone has.
  16. Mar 17, 2013 at 2:18 AM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    Search "Puma 12v compressor". You'll likely eventually end up at Buzzard Gulch's eBay store. About $200 shipped for a 3.5cfm 100% duty cycle 12v OBA compressor.
    Mine came in a couple weeks ago. It's about 85% mounted up, just gotta connect it to the battery, do one last air line fitting, and it's done. I have it under the hood, on the PS wheel well, where the stock intake tube would go (I rerouted that to my cowl). I do not currently have a tank installed, but will as soon as I get the time, find the space to fit it (I'm trying to fit a 7-gallon tank), and possibly down-size the stock muffler.
    It's pretty big. And heavy. Think stock Tacoma battery size and weight. But it pumps a LOT, and is pretty quiet.
    While the Puma is well-built cheap Chinese crap, it does have some advantages others don't, like a built-in cooling fan.
  17. Mar 17, 2013 at 3:15 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Im rocking the big smittybilt. It inflates my tires from 15-35 psi in about 2 minutes each. I've tried filling a 2.5 gallon air tank before. it inflates it to 75psi in 2.5 minutes, 0-115 in 5 minutes. It is not constant duty however. smittybilt says 40 on, 20 off.
  18. Mar 17, 2013 at 12:56 PM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    Is it this one?
    http://www.ebay.com/itm/12-volt-1-5...004?pt=LH_DefaultDomain_0&hash=item2c6ca9b7dc
  19. Mar 18, 2013 at 8:05 PM
    Mach375
    Yup. That's the one. I guess I meant $230 out of pocket. Still a hell of a deal.
    I divorced the tank from the pump and motor. Mounted the motor/pump on the PS wheel well where my stock intake used to be (rerouted the intake to the cowl), will be mounting the tank elsewhere once I get to that point (likely under the bed somewhere) (I may be using a different tank than the one it came with, seeing as I have four tanks of various sizes sitting around).
    As I discovered this weekend, while it may not exactly be mandatory to do so, it is *HIGHLY* recommended to use the switch mechanism it comes with. The unloader is pretty much necessary in order to get it to start again without drawing ~100 amps (ask me how I know :anonymous: ). That is about the only part of my system I haven't worked out 100%.
  20. Mar 19, 2013 at 8:39 AM
    Fred4
    Fred4 [OP] Member
    Fred
    San Diego, CA
    Awesome, thanks man. And your thread should be real helpful. Does seem like a good deal.
