Looking for a Fuse that Supplies Dash Light
Discussion in 'MESO Customs' started by Waynebarkr, Oct 31, 2020.
  1. Oct 31, 2020 at 9:14 PM
    Waynebarkr
    Waynebarkr [OP] Well-Known Member
    Wayne
    Phoenix
    2020 Cement DCLB TRD-OR AT
    I have a 3G (2020) TRD Off Road and am looking to supply power for the light on the Switch for an ARB compressor.
    --The ARB instructions say to find a "dash light supply wire" preferably one that reacts to the lighting level of the instrumentation / dash light dimmer.
    Can anyone tell me which fuse in the under-dash fuse box meets this requirement?
    I have attached a photo of my fuse box label for information.
  2. Nov 4, 2020 at 3:15 PM
    Waynebarkr
    Wayne
    Phoenix
    Got my multi-meter and figured it out. Using the 7.5A fuse (labeled "IG2") on the left hand side in the photo above.
  3. Nov 5, 2020 at 2:31 PM
    Tacospike
    Two Trucks
    Also an add a fuse for the 5A panel is another option
  4. Jan 22, 2021 at 12:56 PM
    trdtacomabob
    trdtacomabob 2020 TRD Sport MGM
    Bob
    Westford, MA 01886, USA
    2020 TRD Sport
    Running boards, LED lights all around, Bed Step, Auto Start, Backup Anytime Front\Rear camera, relocated ECT PWR switch, under hood lighting, chrome delete kits, Gas Hole, Integrated locking tailgate, bed USB & 12V ports, access cab USB & 12V ports
    A jumper harness I've made a few of that works off the ECT PWR or Auto High Beam switches with a dash light pigtail.
  5. May 18, 2021 at 5:23 AM
    UnpavedPreferred
    UnpavedPreferred Member
    Gabe
    2020 Tacoma TRD OR
    2nd fuse down on the left column of fuses: 7.5A TAIL. I used this to illuminate switches, when the lights are turned on.
  6. Sep 22, 2023 at 8:21 AM
    Jigstick
    Jigstick Well-Known Member
    2023 TRD OR LB
  7. Oct 17, 2023 at 8:56 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    I don't think any fuse tap will produce a variable lighting level.
  8. Sep 4, 2024 at 5:45 AM
    Screaminr1
    Screaminr1 Member
    2023 Tacoma SR
    I have a 2023 Tacoma my dash lights work but the lights on the radio buttons is not lighting up when you turn them on. Are the dash lights and radio lights on 2 different fuses?
