Looking for a manual hub swap writeup
Discussion in '1st Gen. Tacomas (1995-2004)' started by WVTaco12, Mar 12, 2019.
  1. Mar 17, 2019 at 2:07 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The manual hub stub shaft has 6mm smaller OD than the ADD stub. I had a manual hub and swapped back after breaking one. The hub grenaded with it. Good luck finding parts for hubs. I could not find the brass bushing anywhere. Even called ORS and they no longer make them. If that is salvageable then you've still got to find a hub in a junkyard for $100 plus another axle at $50. I'll take only replacing a broken axle and save the $100 in hub replacement. Stick with ADD if you push your truck offroad. 2lo is fun though.
    Edit: I felt my 4 banger snapped the manual hub like a tooth pick
  2. Mar 17, 2019 at 2:10 PM
    Reh5108
    Idaho
    Never seen an ADD break the stub shaft. Usually it's the joint that fails. Cut the boots and pull the shaft, drive home.
  3. Mar 17, 2019 at 2:16 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Thanks for the suggestion. It's like major armageddon when these shafts break.
  4. Mar 17, 2019 at 2:17 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Yeah they break at the axle shaft..
    So you leave the tulip in the diff?
    You must be a monster. I've never been able to pull the shaft from the birfield. Even using the pipe trick with the CV on the bench... Always have had to cut the cage or the axle tip with a cut-off wheel..
  5. Mar 17, 2019 at 2:17 PM
    License2Ill
    Ian
    Lol. Come on now.
  6. Mar 17, 2019 at 2:20 PM
    Timmah!
    TIM
    Hey, I remember that somebody sold the needle bearings and bushings but can't remember the company. Do you remember? I think it might have been Marlin Crawler.
  7. Mar 17, 2019 at 2:24 PM
    License2Ill
    Ian
    ORS sells the needle bearing and used to sell the bronze bushings but haven't for around two years now. I think the only option is to scavenge at the junk yards or buy a new hub and pilfer the bushings.
  8. Mar 17, 2019 at 2:25 PM
    License2Ill
    Ian
    Marlin sells just for the Toyota pickup, but I haven't investigated in a while.
  9. Mar 17, 2019 at 2:26 PM
    Timmah!
    TIM
    I just checked Marlin Crawler and they sell the brass bushings for a Hilux which I assume would work.
  10. Mar 17, 2019 at 2:29 PM
    Reh5108
    Idaho
    No, the ADD axles I've seen break, break in the birf joint. The stub end remains in the hub and the tulip just slides out after the boot is cut.
    License2Ill[QUOTED] likes this.
  11. Mar 17, 2019 at 2:42 PM
    License2Ill
    Ian
    Isn't the Hilux in the states considered the pickup?
    Well please let us know if they work. Im sure Marlin would know if they fit 95-00 Tacoma's. Those parts are the biggest headache to find.
    Inner and outer are two different sizes fwiw.
