Looking for a portable compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JUS, Jul 8, 2019.
  1. Jul 8, 2019 at 5:38 PM
    JUS
    JUS [OP] Active Member
    Justin
    Jax, Fl
    19 TRD OR, 08 4Runner
    Hey guys.
    Like the title says, I'm looking for a portable compressor to run off the 120v outlet in the trd off road. I would prefer it to be small enough to store in one of the back seat storage bins. I would like a setup with a quick connect to change air Chucks or nozzles for inflating air mattresses or floats etc.
    Can anyone make a recommendation?
    Thanks
  2. Jul 8, 2019 at 5:47 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    SR-71A, fullripbrian and JUS[OP] like this.
  3. Jul 8, 2019 at 5:49 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I recently got the Viair 300P and it works great but its 12v as well. Fits behind the rear seat though.
    JUS[OP] likes this.
  4. Jul 8, 2019 at 5:50 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    The MasterFlow is also a nice one, but is 12 volt too
  5. Jul 8, 2019 at 5:51 PM
    AZ_Matt
    AZ_Matt Well-Known Member
    Arizona
    2019 White Tacoma TRD OR
    FOX 2.5 Coilovers OME HD Dakar Leafs 285/75r16 Patagonia's 16x8 Method 305 NV wheels Mobtown Bed Bars Front Runner RTT and Awning Hooke Road Roof Rack
    JUS[OP] likes this.
  6. Jul 8, 2019 at 5:51 PM
    kritz
    kritz Well-Known Member
    Isle of Long
    18 TRD PRO Stupor White
    Meh
    Harbor freight, 12v. The outlet is only 400w iirc
    JUS[OP] likes this.
  7. Jul 8, 2019 at 5:53 PM
    Jere
    Jere Outdoorsman
    Northern Chester County, PA
    '18 TRD Sport MGM with ARE Cap
    I carry one of these in my tool box in the back of the truck:
    It has a compressor that runs on 12v built into this tool which also jump starts vehicle if your battery dies. Also includes a couple inverted 110 outlets, a USB charger port, a flash light/reading light. And, if the inbuilt 12v battery runs down, you can plug it into the truck via either 12 or 110 volt inlets for recharge/operation. Only thing is, the compressor is kind of slow, so if you need a lot of volume, and you might if you are filling four tires, it probably would take near infinite patience.
    JUS[OP] likes this.
  8. Jul 8, 2019 at 5:53 PM
    Maxcustody
    Maxcustody Looking for answers, Refer to the EAD manual.
    Scott
    Berkeley Springs, West Virginia
    I have a Viair and love it, works great and never had a problem. I have had it for years..........................
    JUS[OP] likes this.
  9. Jul 8, 2019 at 5:55 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    I just got the viair 400 automatic. It works great thus far!!! Fast inflation and fairly quiet. Don’t know if they have one that’s 120v though. I like that it can be hard wired and add a storage tank too. If your looking for something that’s more household/shop based (compressor/tank combo) the only recommendation I can make is look for one that’s oil lubricated vs oil free. The oil ones seem waaay quieter. I bought a cheap 1 gallon Campbell hausfield compressor like that years ago and it sucks. Its loud and for only 1 gallon it takes a while to build Pressure
    JUS[OP] likes this.
  10. Jul 8, 2019 at 5:58 PM
    Virginian
    Virginian Well-Known Member
    Raleigh, NC
    2017 Tacoma Double Cab TRD Off Road
    I agree and Another vote for the
    VIAIR 400P-Automatic Function Portable Compressor
    JUS[OP] likes this.
  11. Jul 8, 2019 at 6:01 PM
    JUS
    Justin
    Jax, Fl
    400w should be good for up to a 1/2 motor, assuming the motor's start capacitor has enough oomph to provide the inrush current on start.
  12. Jul 8, 2019 at 6:03 PM
    JoeCOVA
    Joe
    Colorado Springs
    maxtherat likes this.
  13. Jul 8, 2019 at 6:14 PM
    fullripbrian
    fullripbrian Well-Known Member
    Seattle sucks now.
    2017 SR Utility
    JUS[OP] likes this.
  14. Jul 8, 2019 at 6:23 PM
    maxtherat
    Inland Northwest
    Maybe for a bike or motorcycle but nothing more. It would be interesting to see some real world reviews on it. My guess is 10-15 minutes and it’s cooked.
  15. Jul 8, 2019 at 6:34 PM
    blackohio
    blackohio Well-Known Member
    Cliche Guevara
    white mudflap
    why is everyone so against compressed air setups. way better, faster, works longer. 10lbs powertank and be done. not as small but you won’t spend ½ your time waiting
    Tullie D likes this.
  16. Jul 8, 2019 at 6:49 PM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
  17. Jul 8, 2019 at 7:08 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    JUS[OP], Rockefelluh and shakerhood like this.
  18. Jul 8, 2019 at 8:35 PM
    Xfile
    Xfile Member
    Central Florida
    2017 TRD Off Road
    For occasional use our budget friendly Viair 88P has worked well for our Jeep on 35s. Attaches to the battery and the hose will reach all 4 tires. It stores nicely in a plastic ammo box. Truck is still new to the family and have not aired it down yet here in flat FL. If you will use it a lot then you might consider a more powerful unit.
    JUS[OP] likes this.
  19. Jul 8, 2019 at 10:10 PM
    Shellshock
    Iowa
    Because I’ll forget to fill it and then have to drive to a gas station to refill.
    Or I just use my compressor that always works and I don’t ever need to refill.
    SR-71A and HelloMyNameIs like this.
  20. Jul 8, 2019 at 10:51 PM
    Rocket3004
    Rocket3004 Well-Known Member
    I may have to take a look at these. I was contemplating buying a Milwaukee m12 compressor for light use (mostly airing up tires) since I'm already in that ecosystem, but the videos I've seen make it seem that thing is super loud and slow and not very good... unlike the rest of their stuff which has been great. The only good feature on those seems to be able to have it fill up to a user-set PSI
