Looking for advice
Discussion in 'General Tacoma Talk' started by lilmr703, Oct 24, 2024.
  1. Oct 24, 2024 at 8:14 PM
    lilmr703
    lilmr703 [OP] Member
    Ryder
    1998 Single Cab Taco 4x4
    2000-2004 Taco Hood, Grill, Lights
    Got a 98 2.7l taco here and about a year ago I replaced whole top end and deleted the EGR and drove for a year solid with no issues at all.
    About 2 weeks ago my truck began dying every time I would come to a stop, once it was warmed up. I adjusted the throttle set screw so that it would idle enough for me to get back and forth from work but i’ve thrown some parts at it in my best attempt to fix the problem.
    I have since replaced the radiator, because it was cracked, the thermostat, and last year I had capped off 2 coolant lines that ran to and from my EGR (since i deleted it), but those caps ruptured and caused amassive coolant leak so i replaced them with a hose that connects the 2 lines. I have also just replaced my water pump this evening because I was hopeful that wouldbe causing some sort of snafoo that replacing would eliminate, but it did not. My truck will run at about 900 rpm no problem until it has run for a few minutes. After that the lowest i can get my truck to stay running at is about 1100 rpm.
    I have a fairly okay understanding of my truck but i’m not a mechanic so i’m not sure where to turn now. I will be checking back often to answer questions as i’m sure i’ve left something out.
  2. Oct 26, 2024 at 8:18 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    given the age, how do the plugs and coils look?
  3. Oct 26, 2024 at 8:26 AM
    ace_10
    ace_10 Well-Known Member
    Rural NoVA
    1st Gen, Best Gen X2
  4. Oct 26, 2024 at 12:52 PM
    lilmr703
    Ryder
    Plugs and coils were both replaced 1 year ago when i did work to the top end
