looking for alloy wheels
Discussion in '1st Gen. Tacomas (1995-2004)' started by 99taco, May 11, 2007.
  1. May 11, 2007 at 9:49 PM
    99taco
    99taco [OP] Member
    hi guys, new to the board. i live in california and drive a 99' tacoma 4x2. i would like to replace the steel wheels with a set of alloys. i'm looking for 16" alloys. i was wondering if alloys from other toyota models like camry, highlander, etc., or lexus models like gs300, etc., will fit tacoma 4x2. from what i know, the bolt patterns are the same (5x4.5) but i'm not sure about the offset. any info or feedback is appreciated.
  2. May 14, 2007 at 4:25 PM
    twoarezee
    twoarezee Well-Known Member
    esco, ca
    00 Dropped Mini
    rims,tires,3"/6" drop, 4x4 front end, 01 tails and corners, prerunner buckets,tenzo r steering wheel w/ momo hub, b&m shifterw/ jdm trd knob, alpine system, tint, 3 3/4" autometer tach, jardine cat back, k&n, debaged, hellwig rear sway bar, kyb monomax shocks, tundra v8 oil filter w/ mobil 1 in ever
    you can use lexus wheels but you need to have the hubs bored out to 67.1mm to fit the tacoma hubs. you can try and find some 16" s-runner rims too, they are direct bolt on.
  3. Jun 4, 2007 at 8:52 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    2001 - 2004 S-Runner rims (alloys; 16X6.5; +30mm offset) might be an option.
  4. Feb 4, 2009 at 12:52 PM
    nguyen
    nguyen New Member
    Atlanta, GA
    01 Tacoma SR5
    Does anyone know if the 5 bolt wheels from a Highlander would work for a 2001 2wd tacoma?
  5. Feb 5, 2009 at 8:19 PM
    Aldo ct
    Aldo ct Well-Known Member
    central California
    97 Tacoma 2rz
    LC header, prerunner/4x4 front end, hellwig rear sway bar/beefed brackets, instrument cluster w/tachometer, 60/40 bench seat, solid sideview mirrors, slider rear window, rearview mirror w/map lights, 27x8.50r14 tires
    The earlier Highlander wheels wheels will not bolt onto a 99. You have to enlargen the center bore. The center bore of the Highlander wheels measures 60.1mm and the tacoma wheels have a 67.1mm center bore on the 95-04's. That can be done for you at a wheel shop or machine shop.
