Looking for Aux circuit wiring inspiration (placement, location, etc)
Discussion in 'Technical Chat' started by GawainXR, Jul 24, 2025.
  1. Jul 24, 2025 at 9:01 AM
    GawainXR
    GawainXR [OP] Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    I'm planning to add a secondary battery to my 2020 Tacoma, which as of right now is planned to be a seperate AUX circuit with the battery charged via a BCDC1225D,
    I'm trying to decide on a few things for the build and could use some inspiration by seeing what others have done or reccomend.
    - Placement of Solar Panel Input (MC4) E.G. do people usually run a feed to the bed or just run the wires under the hood cowl when charging.
    - What accessories to place on the secondary battery, and where to mount their plugs.
    - I'm currently thinking of a dedicated 100a 2AWG circuit that branches to a female anderson plug and SAE connector (SAE for powering accessories like a fridge, light duty compressor), anderson for higher draw accessories like an inverter)
    - I may also feed a WeBoost and my canopy dome light off this circuit.
    - Switched accessories like lightbars, hood light, etc would remain wired to the start battery.
    - Would a 3 position switch opposed to a 2 position one, allowing me to bypass the AUX battery and directly power accessories using the START battery/alternator in extreme cases be wise?
  2. Jul 24, 2025 at 9:25 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
