Looking for better mileage?
Discussion in '1st Gen. Tacomas (1995-2004)' started by sslongmuir, Jan 27, 2008.
  1. Jan 27, 2008 at 11:27 AM
    sslongmuir
    sslongmuir [OP] Well-Known Member
    Maine
    95 single cab 2.7 on 33's
    Custom rock sliders
    So i realized im spending 200$ a week in gas to get to work and back. that not even school. Im looking to get better mileage but i dont know what else to do. i removed my weight from the back and tuned it up. Im still getting 16-18mpg but should be getting atleast 20. any hints would be helpful
  2. Jan 27, 2008 at 11:43 AM
    Hittman
    Hittman Member
    looking for a taco
    put the stock tires back on and move closer to work:D
  3. Jan 27, 2008 at 1:01 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Clean the MAF sensor. Likely fouled by the oil from the K&N. Check with 007tacoma for the procedure for this.
  4. Jan 27, 2008 at 2:45 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    in your tune-up, did you include changing the fuel filter?? if not, do that, it may help too!!! cleaning your maf sensor like maverick said will help you out also, along with cleaning your throttle body if you havent done so. let us know how everything turns out!!
  5. Jan 27, 2008 at 4:45 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Tire pressure, max it out, road tires; non aggressive, axle alignment, make sure you are not crooked going down the road. Maybe a hard cover for the bed. But with the amount of money that you could spend on saving money for fuel, just gas it up.
  6. Jan 27, 2008 at 4:59 PM
    sslongmuir
    Maine
    Custom rock sliders
    i run the tires high, maf sensor got cleaned. the throttle body i didnt do but the fuel filter is a bitch. ihave one but it looks like a job to get at it.
  7. Jan 27, 2008 at 5:01 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Lighten up on the go pedal,avoid jackrabbit starts,time the stop lights, use cruise controll,.....buy a used cheap econo car that gets 25-30mpg...???
  8. Jan 27, 2008 at 6:52 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    yeah winter gas kills about 4mpg man it sucks... but you should still get better, hell I'm getting better mpg with 35's
  9. Jan 28, 2008 at 3:36 AM
    sslongmuir
    Maine
    Custom rock sliders
    yea i kno. i put a trd supercharger on my friends 6cyl and he still gets 20. Im fucked i guess lol.
  10. Jan 28, 2008 at 6:16 AM
    350TacoZilla
    Hancock MD
    seems it....LOL i dunno wierd
  11. Jan 29, 2008 at 2:59 PM
    sslongmuir
    Maine
    Custom rock sliders
    sealed up the exhaust but i still only get 20. hmmm
  12. Jan 31, 2008 at 6:57 PM
    TacoSteelerMan
    TacoSteelerMan Active Member
    Arkport N.Y.
    95.5 Toyo,Taco, with 263,000
    dry K&N cold air kit BONE STOCK
    Tire size although bad to the bone is working against you 31x10.5 looks sweet on your ride like they did on mine but....This is the price you pay for looks It's killin your gear ratio I went back to a 225-75-15 and ran closer to 24 MPG Yup 95.5 2.7 Taco
  13. Feb 1, 2008 at 9:34 AM
    cycledrum
    cycledrum Well-Known Member
    Union City, CA
    88 4X4 Pickup xtra cab, SR5
    Put a Tonneau cover on or get a louvered tailgate or 'Gator Net'.
    The tailgate causes a lot of aero drag and lowers your gas mileage.
  14. Feb 2, 2008 at 8:55 PM
    99TRD
    99TRD Well-Known Member
    17 Tacoma TRD OR DC Auto V6
    Smoke headlights, improved LED tail lights...Pending: De-chrome badges and grille, new tires
    I lost a few mpg when I got the new tires. I am still getting just over 20 on the hwy.
    Personally, I think it is worth a few mpg's for the look.
  15. Feb 3, 2008 at 2:38 AM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    Believe it or not, a louvered tailgate or a "Gator Net" (or any net for that matter) causes much more drag than just a tailgate with no tonneau cover.
    Air that passes through the crosshatching or louvers creates a ton of parasite drag.
  16. Feb 3, 2008 at 3:08 AM
    TuRDTACO
    TuRDTACO Carolina Alliance: Midwest Firearms Division
    joliet, il
    HAD 07 TRD OFFROAD PRERUNNER
    small dent on the hood, new foglight bulb, roughed up bedliner, been smoked in, suspicious stains on the passenger seat, boogers on the drivers seat, dirty floor mats, girl doodles on the dirty windows, loose wiring
    tailgate down or off is supposed to reduce your gas mileage because when the tailgate is on and up, it creates an air pocket in the bed that the airflow coming over the front just rolls over. when you remove the tailgate, you get rid of that pocket and it creates more turbulence and drag, which means less MPG
  17. Feb 3, 2008 at 4:44 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    The biggest mod you can do for gas mileage is watch the way you drive. Moderate acceleration to speed and then be STEADY. A scangauge is a fantastic tool because it lets you see exactly how much fuel you're burning in real time. Anticipate lights and stops so you can coast to them. Turn off the AC when you really don't need it. Don't let the truck sit idling. Drive with the wind, in RI we usually get a 15 mph seabreeze in the afternoon and a land breeze at night so I save gas by driving north during the day and south after midnight. OK I'm kidding about the last one, but in theory it'd probably work.
  18. Feb 3, 2008 at 9:15 AM
    concrete jedi
    Rochester N.Y
    Wow you almost had me! I was thinking; damn this guy is serious. nice hook:D
  19. Feb 3, 2008 at 2:46 PM
    TSUNAMI*22
    Stockton, CA
    My ScanGauge disagrees with you.
    Driving with the tailgate opened or off completely actually helps MPG. It's not a ton, but it IS better. You'd notice it on a 300+ mile drive as long as you maintained a steady speed on cruise control.
    I show lower Gallons Per Hour being burned on the SGII.
  20. Feb 3, 2008 at 3:03 PM
    docc30
    docc30 New Member
    Hell Creek Suspension Leaf Springs
    From the myth busters:
    http://mythbustersresults.com/episode43
    It is more fuel efficient to drive your pick-up truck with its tailgate down, rather than up.
    busted
    Driving with the tailgate down actually increased drag on the pick-up and caused it to consume fuel faster than the identical truck driven with the tailgate up. It was later revealed that the closed tailgate creates a locked vortex flow that created a smoother flow of air over the truck. With the tailgate down the trapped vortex was dissipated and the drag increased.
    (This myth was revisited in episode 64 and re-busted. However, it was found that mesh tailgates are the most efficient configuration.)"
