Looking for confirmation on 2009 4x4 Front Wheel Bearing Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PB65stang, Dec 5, 2011.
  1. Dec 5, 2011 at 6:13 PM
    PB65stang
    PB65stang [OP] Well-Known Member
    Patrick
    Kansas City
    2016 F150 Lariat 4x4
    5100s (2.5" front), OEM Raptor wheels, 315/70/17 BFGs, Undercover, tint, Weathertechs.
    Read the sticky, did the search, but I want to clarify with people who have done this repair themselves before I undertake this. Most of the stuff I read mentions a bearing needing to be pressed in, but can't you make the job a lot easier by just buying an assembly like this:
    http://www.autopartswarehouse.com/sku/Koyo/Wheel_Bearing/W0133-1741015.html?loc=Front
    And then I would need a new O ring and Front Axle Hub Oil Seal, correct? Is that all I need to do this replacement? I think this is the way to get around needing special tools, etc. Thanks in advance.
  2. Dec 5, 2011 at 6:48 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Great question, looking forward to hearing some answers.
  3. Dec 6, 2011 at 5:49 AM
    PB65stang
    Patrick
    Kansas City
    Think I can answer my own question. After looking again at the FSM, that link I posted is the actual bearing only, and not any kind of assembly. But I think all I need to do is get the old one pressed out and this pressed in (probably $25 somewhere) and then I can reinstall it myself. Now I just need to source the correct gaskets and seals.
  4. Dec 6, 2011 at 4:04 PM
    fjm0008
    fjm0008 Well-Known Member
    Jack
    Annapolis
    06 4x4 LB White
    Sirius Starmate and ipod integration w/Pay15 Toy USA Spec, Hardwired Radar Detector and GPS, DRL Mod,Tailgate Anti Theft mod, Hi Lift Jack, CB Radio, Back up sensors, Front 30% tint, Leer 100R Cap, Weathertech, Under hood light and 12V outlet, D Rings, N-FAB Step Bars, Bed Mat, Yakima Bike Rack, OEM Roof Rack
    How many miles does your 2009 have? What kind of symptoms/noise did you have to warrant the replacement? I have a 2006, 68000, and I just started getting a sound/ vibration in the front. It sounds like tire noise so I can't tell if it is the bearings or not. Thanks.
  5. Dec 6, 2011 at 4:34 PM
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    subd
  6. Dec 6, 2011 at 4:36 PM
    scocar
    scocar hypotenoper
    :spy: XXXX
  7. Dec 6, 2011 at 4:47 PM
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    subd.....same boat.
  8. Dec 6, 2011 at 4:52 PM
    SJginger
    SJginger Well-Known Member
    Jerry
    South Jersey
    08 tacoma trd sport, stock for right now!!!
    I just did both wheel bearings on my 08 TRD sport....try rockauto.com I got both wheel assembles for around 175$ and then u would need to get the hub pressed out of old one and pressed into new one...I don't know the exact part numbers from Toyota but u need the oil seal that goes between the bearing assemble and the hub...I believe the part number is 90312-96001 seal type V oil...dont quote me but almost possitive.....hope this helps
  9. Dec 6, 2011 at 4:54 PM
    korslite
    korslite Well-Known Member
    Justin
    Bellingham, WA
    DCLB Sport
    FOX 2.5 RR's, TC UCAs, TC Spindle Gussets, Allpro Expedition leaf pack, Fox 2.O RR w/ Comp adjusters, 17" ATX Artillery, BFG AT 285's, de-scooped, custom sliders, custom bedrack, Brute Force Fab bumpers, Smittybilt XRC8 winch, ARB locked Rear diff
    sub'd... just recently did this job, i have the part numbers at home i believe... stand by
  10. Dec 6, 2011 at 4:57 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You are correct.
    The info can be found here :spy:
    http://www.tacomaworld.com/forum/2n...eplacement-part-s-general-bs.html#post3278586
  11. Dec 6, 2011 at 6:57 PM
    korslite
    Justin
    Bellingham, WA
    DCLB Sport
    Here is the order invoice for the seals needed for replacing both front wheel bearings, hope this helps. These are toyota part numbers.
  12. Dec 7, 2011 at 10:02 AM
    jayr
    jayr Member
    MA
    09 DC TRD Sport 4x4
    sub'd for future ref - THX
