Looking for "P" rated 33" tires
Discussion in 'Wheels & Tires' started by KeithB, Nov 21, 2011.
  1. Nov 21, 2011 at 5:47 PM
    KeithB
    KeithB [OP] Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Falken Wildpeak AT3/W tires, Suspension: Fox coilovers set at 2", TC UCA's, 1.5" lift 3 leaf pack with overload left in Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau, USB ports front and rear, seat heaters, birddawg mirror riser Cosmetic: window tint, grillcraft black mesh upper/lower grill, vinyl armrest in doors, Clazzio black seat covers with blue stitch, Redline steering wheel wrap Lighting: fogs only mod, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights, Tacomabeast headlights and matching tails.
    Ok, here's the deal. I have P265/70R17 Nitto Terra Grapplers and want to go larger in a few months. I don't want an "LT" rated tire because I don't take the truck off-road and the LT tires are heavier hurting gas milage and stiffer so the ride isn't as smooth. I know there are some P285/70R17 tires out there like the Nittos but was hoping for a more aggressive tread. Seems most aggressive tread tires in 33" size are LT rated and weigh in over 50 lbs. Some as much as 68 lbs. Current tires are only 42 lbs and if I stick to P rated 33's, I can keep it under 48lbs.
    So does anyone know of a P285/70R17 or P285/65R18 tire that has a little more aggressive look than Nitto Terra Grappler or Bridgestone Revo 2's? Replacing stock wheels with either 17x9 or 18x9 XD Addicts so could be for 17" or 18" wheel but I think I might have better luck with 17's from my research so far. 18's have more limited size options and tend to be more LT in the size I want. i.e. the Nitto Terra Grapplers don't even come in P285/65R18.
    P285/70R17 48 lbs 33" tire
    LT285/65R18 52 lbs 33" tire load range E (too stiff)
    P285/60R18 47 lbs but only 32"
    P275/65R18 45 lbs and a true 32" tire
  2. Nov 21, 2011 at 5:51 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    so ur worried about gas mileage and ride quality... and u want to go up a size in tires with a more aggressive tread pattern, and not lose gas mileage?????
  3. Nov 21, 2011 at 5:52 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Have you considered a 255/75/17 Hankook ATm ? It's a P rated , 32 1/4" tire
  4. Nov 21, 2011 at 6:32 PM
    OZ-T
    Peter North
    British Columbia
    You could also get a Cooper ST AT tire in 255/85/16 , which is a 33 1/4" tire
  5. Nov 21, 2011 at 8:39 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    The new rugged terrains look aggressive and are a 32.6 height and only weigh 40.8 lbs.
    P265/70R18
  6. Nov 21, 2011 at 8:42 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Nitto Trail Grapples can be had in 33" and P rated
  7. Nov 21, 2011 at 10:35 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Bingo.
  8. Nov 22, 2011 at 8:09 AM
    KeithB
    Keith
    Cheshire, CT
    Yes, I know. I've had LT tires and did not like the ride. I know I will lose gas milage, just trying to minimize the effect of larger tires by keeping the weight down. I will probably go with NTG's like I have now just in larger size but was entertaining the idea of a more aggressive tread pattern too.
    Also, don't like the pizza cutter look. Looking for wider tire as well as taller.
    http://www.tacomaworld.com/forum/wheels-tires/27583-p-vs-lt-rated-tires-3.html
