Looking for some all-terrain tires that won't hurt MPG...
Discussion in 'Wheels & Tires' started by Vrbas, Nov 29, 2010.
  1. Nov 29, 2010 at 10:00 AM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    I have a 2011 Ext Cab 4-cyl 5-speed (2x4). I like the ride height and don't want to make it "look" offroad, per say. But I do want the added comfort of knowing I can fair well enough when i do take her off the beaten path. I'm also trying to hold my average 23mpg that i've been getting lately. Any chance? Also, can i keep the stock rims or will those have to be upgraded?
    It's only 2x4 so i don't plan on doing anything hardcore. I was just wondering if y'all have any recommendations... pics too would be GREAT. I'm trying to keep it as "stock" looking as i can if possible. Thanks guys.
  2. Nov 29, 2010 at 10:06 AM
    JLamb11
    JLamb11 Well-Known Member
    Jared
    Orange County, CA
    08 PreRunner TRD Sport
    Regear, 6" Pro Comp Lift, Wicked Flow Exhaust, K&N Intake, T-Rex Billet Grill, Cobra CB, Wilson Flex 3', Radio Shack PA, Eyelids, Xenon HIDs, Tint, Kenwood GPS/DVD/Bluetooth...
  3. Nov 29, 2010 at 10:08 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    You don't need to change the rims unless you want to go much larger than stock. There are a lot of options depending on how aggressive of a tire you want. I went with Cooper Discovery ATRs, they aren't as aggressive as the BFGs but are fairly well mannered on pavement and capable on trails, snow and mud. You can look at my pictures if you want to see what they look like or Cooper's website.
  4. Nov 29, 2010 at 10:22 AM
    BassMaster06
    BassMaster06 Well-Known Member
    Dan
    South Carolina
    2006 Double Cab V6 4x4
    Mods: sand, dog hair, roof rust
    I was in the same boat as you a couple months ago, and I went with the Bridgestone Duelers A/T. They're definitely cheaper than BF Goodrich, and I'm still getting 21-22mpg in my V6 double cab, so you might look into a set of those...good luck
  5. Nov 29, 2010 at 12:24 PM
    Vrbas
    I understand that as soon as you start increasing the size of the tire, you lose mpg. Is it as simple as just changing tread type? What really makes an "All-Terrain" tire all terrain besides it's tread (and height)?
    I'm looking for something that still looks "standard" but can perform on light offroading, mud, and maybe snow. I guess i just fear getting stuck w/ my stock treads if the ground is too loose or wet.
  6. Nov 29, 2010 at 12:30 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I have general grabber AT2, nice all terrain and didn't lose any mileage.
  7. Nov 29, 2010 at 12:31 PM
    Pugga
    Massachusetts
    All-terrain tires have nothing to do with height, it's a tread pattern. You can get all-terrain tires in your stock size, no height increase at all. Increasing tire size is a personal choice. I'm still running stock size all-terrains. You lose MPG for a number of reason. With a more aggressive tread pattern you have more resistance and you may lose a little (very minor). If you increase the tire size, or width, you'll lose a little more to rolling resistance. If you go up in load range you end up with a heavier tire and you could lose some MPGs by doing that also. Some like I mentioned (the Cooper) has a solid centerline which makes it quieter on the road but an open tread pattern on the outside which allows it to get through mud and loose stuff. It's still an all-terrain tire but with street manners. Something like the BFG All-Terrain has no solid centerline but will perform much better off road because of the deep lugs and open tread pattern.
  8. Nov 29, 2010 at 12:34 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    its a double edged sword.
    If you go offroading you won't get good mileage.
    A good offroad tire won't make good mileage.
    Which is of the most importance?
    With that said, I'm happy with my rare 20mpg I can achieve with 33's. So if I were you I'd get an AT with stock height tire.
  9. Nov 29, 2010 at 12:38 PM
    Vrbas
    Thanks for all the input.
    I may see 10, perhaps 15% offroading (and my definition of offroading isn't anything extreme). So the MAJORITY of the time i'm going to be caring about street manners and gas mileage. I was just wondering if it'd be possible to have the peace of mind that my 4x2 could perform if the occasion arose to drive off the road or through some loose ground, muddy, slippery conditions.
  10. Nov 29, 2010 at 12:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Oh buddy your truck is very capable.
  11. Nov 29, 2010 at 12:50 PM
    MAtrdguy
    MAtrdguy Well-Known Member
    Pete
    Western Ma ( on the lake) / Danvers N Shore
    06 Taco DC LB
    None YET
    I like the Firestone Destination A/T's ( cause I drive 300miles a day interstate), they are the best I personally have found.
    I got 105 K miles out of one set on my old Tundra.
    Great reviews on tire rack too. i never got stuck with them.
  12. Nov 29, 2010 at 12:55 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    What are the stock tires you have on now?
    I changed my stock Dunlops out for Goodyear Silent Armors on a recommendation from PB over at TN. They've been a great tire in all conditions though I do have snows now for the winter. The tire does have the snowflake rating and handles well in all the conditions.
    I did not really notice any loss in mpg from my tires. My thule rack did that.
  13. Nov 29, 2010 at 1:24 PM
    YayAreaTaco0311
    YayAreaTaco0311 Motivator
    California
    '09 TRD 4x4 O/R Supercharged
    OEM TRD supercharger, OEM wheels painted black by me, yellow sidemarkers, arb bumper, LED interiors, roll-n-lock, 5% rear windows, mudflaps removed, protector alarm, mobile trace, blacked out front Toyota emblem, debadged, & tree air freshener.
    Michelin LTX AT sounds pretty good from what I've heard...
  14. Nov 29, 2010 at 1:35 PM
    Vrbas
    It says "Dunlop Grandtrek AT 20"
  15. Nov 29, 2010 at 1:42 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
    X2. I went to them with no change in mileage. They're quiet and perform great. As said above, check out Tire Rack's ratings, they are way above BFG and all the rest.
  16. Nov 29, 2010 at 1:46 PM
    Vrbas
    Question about sizing:
    It says my tire specs are 215/70R15 but if i plug that into TireRack I'll only get 3 results, all from Dunlop. Do the tires have to meet those EXACT numbers?
  17. Dec 1, 2010 at 9:36 PM
    JLaScala
    JLaScala Super White is gonna treat you right.
    Snohomish Washington
    2010 TRD Sport 4x4 long bed crew cab.
    Secondary air filter removal, K&N drop in, Removed front mud flaps, Toyota all weather matts, skid plate, bug guard. Bilstein 5100's all around fronts set at 2.5", OME add a leaf, Goodyear Wrangler Authority 265/70/17, stubby 6.5" antenna, smoked tail lights, blacked out badges.
    Hankook dynapro atm rf10. I love mine!
  18. Dec 1, 2010 at 9:48 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    My 255/85/16 cooper ST they haven't reduced milage at all for me.
  19. Dec 1, 2010 at 10:43 PM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    255/75/17, 32" GY Silent Armors here. They've been good to me so far :)
  20. Dec 3, 2010 at 5:00 PM
    nermalgod
    nermalgod Well-Known Member
    Bend, OR
    Offroad boat hauler
    Not going to brag.
    You're running a 33" tire with no mpg loss? Compared to what did you have before?
