Looking for some new tires...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tnluu1, Mar 7, 2013.
  1. Mar 7, 2013 at 11:12 AM
    tnluu1
    tnluu1 [OP] Well-Known Member
    I'm around 30k miles on my 2012 taco and the tire tread is almost dead on my stock tires. I've been looking into some new tires with more of an agressive look that will fit the stock oem 16" rims, not looking for anything crazy big because I dont feel like lifting it yet. Any advice on what tires I should get?
  2. Mar 7, 2013 at 12:31 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    p265/75/16 is about as big as you can go. I would not go with LT tire because of weight of tire and your rims are 7" wide, plus you will lose about 1 mpg. this tire usually comes in both P and LT in about every brand, depending how much offroading you do, if mostly on road go with AT tire. I've personally used Cooper ST, Bridgestone Revo, and Goodyear ATS in C range because only maker in the size I run 275/70/17. my son runs the Firestone Destination AT in P265/75/16 on his 2005 Tacoma
  3. Mar 7, 2013 at 1:06 PM
    BradyT88
    BradyT88 Well-Known Member
    Yep, 265/75/R16 is the biggest you can go without a lift to avoid rubbing issues.
  4. Mar 7, 2013 at 1:09 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Lots of people on here at Nitto Terra Grapplers. Good for on and off road that wont break the bank.
  5. Mar 7, 2013 at 6:23 PM
    tnluu1
    Thanks for the input
  6. Mar 7, 2013 at 7:26 PM
    mattmyster
    mattmyster Well-Known Member
    matt
    nova scotia
    07 4 door trd offroad radiant red
    Kenwood DD deck, XD 17in rims, 285/70 firestone destination A/T, ,7in spotlights behind the grill, satoshi grill and color match, rough country lift, seat covers...maybe more cant remember
    cooper at3 is a great combination of on/off-road capabilities while offering aggressive looks and performs well in the snow...not to mention 50,000 tread wear warranty
  7. Mar 7, 2013 at 7:38 PM
    redtacoma88
    redtacoma88 Well-Known Member
    John Austin
    TN
    2012 TRD Off Road
    See Build Page...
    Terra Grapplers are cool but I have had pretty bad expiriences with them offroad even for an AT tire.
    I would recomend 265/75/16 bfg all terrains, goodyear duratracs, or Dick Cepek Radial FC-II
  8. Mar 7, 2013 at 9:32 PM
    sde780
    sde780 Well-Known Member
    I'm a fan of hankook dynapros
  9. Mar 7, 2013 at 9:43 PM
    Merchantmarine
    Merchantmarine Well-Known Member
    Tim
    Southern New Hampshire
    TRD Off Road D.C.
    Wet Okole TRD seat covers, Extang Trifecta, TRD Exhaust cat back, TRD Front skid plate-for-looks. Michelin AT2 265-75-16 tires. WeatherTech front and rear
    Michelin AT2 265-75-16 I really like them I can send you pics of how they look if you want
  10. Mar 8, 2013 at 12:48 AM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
  11. Mar 19, 2013 at 9:25 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I researched the hell out of tires for the last month. Very nearly bought the Cooper AT3s, but after reading the reviews online, and reading a couple bad experiences that members have had with Cooper, it seemed like there was a trend that they could be hard to balance, or go out of balance. I wound up going with Michelin AT2s. I've only had them a few days, but so far I think I've made the right choice for a primarily highway vehicle. There is a 70 dollar rebate on a set of four through the end of the month.
    If looks matter, the Michelins look a lot tougher in person than they do in pics.
