LOOKING INTO GETTING KING SHOCKS??
Discussion in 'Suspension' started by WTFaulkner, Feb 26, 2013.
  1. Feb 26, 2013 at 6:06 PM
    #41
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Correct. The diff drop is unnecessary for 2nd tacomas. You are more likely to develop vibrations coming from the front differntial if you install it. The purpuce of the diff drop is to lessen the angles of you front axles. To much angle can cause the CV boots to prematurely wear, try searching CV boot slide mod which will help with this issue if your fins are touching eachother on the CV boots after the lift
  2. Feb 26, 2013 at 7:51 PM
    #42
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I would order an OME carrier bearing drop if it is not included in a kit (if you go OME)
  3. Feb 26, 2013 at 7:58 PM
    #43
    WTFaulkner
    WTFaulkner [OP] Well-Known Member
    Kris
    SLC
    Tacoma
    Stuff
    So in the end I could do some non-resi Kings or the original kings I posted about in front and get some dakar rear spring with a light racing UCA and be set??
    Do I have to get a after market UCA?
  4. Feb 26, 2013 at 8:00 PM
    #44
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    i took my kings from absolutely no preload on the coils to cranked up to 3-3.5" of lift with 700lb springs and it absolutely made the ride stiffer!!
  5. Feb 26, 2013 at 8:20 PM
    #45
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Get a uniball UCA like (total chaos, camburg) with the Kings if you decide on those. The uniball UCA allows for more travel.
  6. Feb 26, 2013 at 9:08 PM
    #46
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    So would that be considerd a mid travel set up.
    And also and when you say more travel that means?
    So I HAVE to have a after market UCA?
  7. Feb 26, 2013 at 9:09 PM
    #47
    Mitch
    Mitch
    Spokane, WA
    Kings only come in remote reseviors for the 2nd gen tacomas. Otherwise. Yes you would be fine
  8. Feb 26, 2013 at 9:46 PM
    #48
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Sorry I feel like I'm repeating my self a lot just trying to get better understaning thanks a lot guy.. lol so kings,icons, or fox spring or ..a ome lift in front and some dakar rear springs and if I wanted but (don't HAVE too have) a after market UCA would be a preatty great set up for what and where I plan on driving?
  9. Feb 27, 2013 at 1:55 AM
    #49
    evanmb31
    evan
    connecticut
    09 trd off road
    Lol more suspension travel. Mainly more droop or downtravel. You dont absolutely need UCAs but it is recomended. Lifting the front end screws with the alignment and you will end up with low caster, which could make the truck feel like it wonders on the highway
  10. Feb 27, 2013 at 1:57 AM
    #50
    evanmb31
    evan
    connecticut
    09 trd off road
    Light racing ball joint UCAs also allow for 20% more articulation over stock according to their stats on their website.
  11. Feb 27, 2013 at 7:08 AM
    #51
    Mitch
    Mitch
    Spokane, WA
    Don't be sorry. We've all been there. And just for your knowledge, the OME kit will be a full front and rear suspension.
  12. Feb 27, 2013 at 8:17 AM
    #52
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Ok sweet i will look more into the CV boot slide mod, Thanks:)
    I see i see so your going to have better alignment and in a sence better controll over your vehicle with an after market UCA?
    so going with a full OME suspention kit alone will be a fine set up? or are you meaning includeing the light racing UCA as well will be fine?
    Again thanks for all the knowledge and help fellas!!:cool:
  13. Feb 27, 2013 at 8:26 AM
    #53
    Large
    Large Red
    FWIW (for what it's worth), I'm running OME front to back, total chaos UCAs and can't be happier with the way it rides. I am replacing them today with 700lb Kings up front and resi'd rears. I have run the OME setup since August and it has handled the abuse quite well. I also ran 885s (OME coils) with 5100s (Bilstein shocks) up front for a while and it was a great ride. Also with total chaos UCAs, I know a guy who runs OME front to back (886s.. very stiff coil) with stock UCAs and his alignment is in spec. It's kind of a hit or miss with our tacos, but when in doubt why not fork over an extra $600 for your expensive taco? :cool:
  14. Feb 27, 2013 at 8:32 AM
    #54
    evanmb31
    evan
    connecticut
    09 trd off road
    Yep sounds like you got it, aftermatket UCAs will make it much easier to get the alignment in spec. I run a full OME setup with light racing UCAs and it rides great. The only issue is not as much downtravel, which would probably make the ride smother offroad. Extended travel coilevers with uniballs will be a better setup but in my opinion it isnt worth it unless you offroad alot or do high speed offroading, the price difference between OME with LR UCAs vs. extended travel with uniballs is alot.
  15. Feb 27, 2013 at 8:35 AM
    #55
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    So my plan to go with the kings front too back and some dakar rear springs an after market UCA I should be preaty satisfyed? :rasta:
  16. Feb 27, 2013 at 8:42 AM
    #56
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    With this last part being said tho^^. So is the uniball taking the place of the UCA in a sence?
  17. Feb 27, 2013 at 8:55 AM
    #57
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  18. Feb 27, 2013 at 9:16 AM
    #58
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Your stock shocks have a set travel range (the difference between the collapsed and extended length of the shock). A stock replacement shock will have the same travel range so they are considered stock travel setups even though you can have that and a lifted application. The problem with stock travel setups is when you lift them, you gain uptravel but have very little downtravel with a 3" lift. With an extended travel setup, you get some of your downtravel back while still having all your uptravel. Extended travel setups require an aftermarket UCA.
    A uniball is just describing the joint where the UCA meets the spindle. You'll either end up with a ball joint (which is what you have stock) or a uniball setup. The Light Racing UCA, even though it is a ball joint UCA, will work with an extended travel coilover.
  19. Feb 27, 2013 at 10:56 AM
    #59
    WTFaulkner
    Kris
    SLC
    Tacoma
    Stuff
    Ok so a uniball is just another type (persay) of UCA then?
    so preatty much with wating a 2.5"-3" lift im going to want a LR UCA or a uniball UCA,, and to get both up and some down travel back get extended travel coil overs (or springs)? lol
    Again thanks!!:cool:
  20. Feb 27, 2013 at 10:59 AM
    #60
    Pugga
    Massachusetts
    Extended travel coilovers will gain you back your downtravel, not uptravel. With any suspension lift kit, uptravel is not a concern, you'll have plenty of it. Otherwise, yes, you've got it.
