Looking to buy. What do you guys think?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beanstalk728, Oct 10, 2018.
  1. Oct 10, 2018 at 2:01 PM
    Beanstalk728
    Beanstalk728 [OP] Member
    Hey everyone as the title says I’m looking to buy this truck in the Northeast. It’s a 2014 access cab v6 4x4 TRD Sport in white with 24k miles. Asking price is 24,990 and I got them down to 24,500 before I walked away. It’s stock everywhere with new tires and brakes. Also has custom heated leather seats.
    Do you guys think this a reasonable price? According to kbb, nada, car gurus it’s saying the fair market value is 25k+.
    I’m attaching some photos of the undercarriage because it’s a little rustier than I expected given its age. Do you guys think this amount of rust is alarming? I did knock around the frame to listen for soft spots but didn’t hear anything. Looks like surface rust to me.
    What’s some good tips for inhibiting this rust if I decide to buy this truck?
    Thanks in advance!
    Edit: should have mentioned it’s certified prep Wednesday and comes with 1 year bumper to bumper and maintenance and 7/100k power train
  2. Oct 10, 2018 at 2:07 PM
    Tacosrus
    Tacosrus ipso facto
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    It looks a little too rusty.
    I'd keep looking.
    Beanstalk728 [OP] likes this.
  3. Oct 10, 2018 at 2:09 PM
    Biscuits
    Biscuits Thorny Crown of Entropy
    2014 PovertyCharged & 2010 PovertyRunner
    Swiggity swangin' biggity bangin'
    I personally haven't had to deal with this so I don't know the specific requirements, but I wonder if this truck would qualify for a frame replacement from Toyota.
  4. Oct 10, 2018 at 2:18 PM
    Miami Chillin
    Miami Chillin Well-Known Member
    DCLB TRD Sport 4x4
    Frame needs to have holes in it.
    Beanstalk728 [OP] and Biscuits like this.
  5. Oct 10, 2018 at 2:21 PM
    Biscuits
    Gotcha. Thanks.
    Some sections of that frame don't look too far from having a hole...
  6. Oct 10, 2018 at 2:21 PM
    JMC3800
    JMC3800 Well-Known Member
    Western MASS
    2015 TRD PRO
    Tail Gate Mods, Gator SR-1 Roll up Tonneau Cover
    For that kind of money you can buy a DCAB keep looking.
  7. Oct 10, 2018 at 2:23 PM
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
    '18 DCSB, TRD Sport, 4x4, 6MT
    UltraGauge
    That's quite a bit of rust for a 4 year old vehicle. I'd probably keep looking myself
  8. Oct 10, 2018 at 2:27 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Alot of that rust is surface rust but some of it is not.
    My 2012 has less than that and has sat outside in NE ohio it's entire life.
    The transfer case picture shows a TON of rust that has already started on the Cab body around the grommets.
    The the E-coat on the body has been penetrated and is allowing metal to oxidize, there is no stopping it now.
    I would bump your mileage criteria up to 40-50,000 miles and find a body/frame that's in better shape.
    If you are set on this one, ask for a car-fax on that thing.
    That truck either lived on the beach or took a few swims.
    Rust should not be propagating from the grommets unless the grommet was holding water. (IE water in interior, or water up to bottom of cab)
  9. Oct 10, 2018 at 2:34 PM
    Tcomaboy
    Tcomaboy Well-Known Member
    TX
    2010 PreRunner Sr5 TRD LongBed
    No bueno on the rust.... you should have told them to replace the frame before you buy it
  10. Oct 10, 2018 at 3:32 PM
    Beanstalk728
    Thanks for all the advice guys. I guess the search continues. I’m not opposed to getting higher miles if it looks like it’s in better shape
    What if I negotiate a rust inhibitor/coating be added? Do those things help?
    Biscuits likes this.
  11. Oct 10, 2018 at 7:29 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Greg
    Las Vegas
    2017 Pro/2015 Tacoma
    Lifted
    Too much money for the rust it has.
  12. Oct 10, 2018 at 7:56 PM
    FlamingTacoBro
    FlamingTacoBro Taco Junkie
    So CA
    2015 Inferno Pro
    ToyTec 1/2" Front Top Plate Spacer, Toytec Progressive 3 Leaf Add A Leaf Pack, Front & Rear S.S. Brake Lines, StopTech Cryogenically Treated Slotted Rotors, TRD Front Brake pads, TRD 17" Matte Black Alloy Wheels, LT 265/70/R17 BFG KO2's (Load Range C), Cali Raised 32" LED Light Bar with Stealth Mount Brackets, Toyota OEM "LED Light Bar" Switch, Front & Rear Husky X-act Contour Floor Liners, Front & Rear Wet Okole Seat Covers, Center Console Organizer & Tray, Anti-Glare Scoop Decal, Low Mount/No Drill License Plate Bracket by ACEkraut, Falcon Zero F170 HD Dash Cam DVR (Hardwired), UnderCover Ultra Flex Tonneau Cover, Pop & Lock Tailgate Lock, OEM Bed mat,
    lots of rust for a 2014.....I'm glad I don't have to worry about rust here in So CA......keep looking OP
  13. Oct 10, 2018 at 8:14 PM
    Biscuits
    All you'd be doing is putting a band-aid on a cancerous problem.
    Thing about oxidation is that it can continue sight unseen. They either replace the frame or you walk.
  14. Oct 10, 2018 at 8:24 PM
    Tacosrus
    Tacosrus ipso facto
    Northern California
    Walk. Lots of other stuff looks problematic. This truck will turn into a Hole you throw money in...
  15. Oct 10, 2018 at 8:29 PM
    Tacosrus
    Tacosrus ipso facto
    Northern California
    OP not sure where you are but you may consider buying a California Truck or one from a drier climate that's close to you.
  16. Oct 11, 2018 at 7:39 AM
    rphillips
    rphillips Well-Known Member
    Rick
    1991 tacoma 4x4
    none
    Rekon why new tires & new brakes with only 24K miles, my opinion, should be maybe 1/2 way to being replaced. Rust this bad within first 4 yrs. will get waaaay worse in next 4 yrs. If this is a dealer, in my part of the country, you should be able to negotiate way more than $400 on a $25,000 truck. Just my opinion.
  17. Oct 11, 2018 at 7:44 AM
    PackCon
    PackCon Well-Known Member
    Connor
    Super White 2013 TRD Sport DCLB - 2002 Ford F250 SD
    How does the price compare to KBB?
    Leather seats dont change the value abd neither does new tires and brakes. The truck shouldn’t have needed either with only 24k.
    The new brakes creep me out. What the heck happened to the first set?
    Is this a dealer or private sale?
    The rust doesn’t bother me. Thats what my ‘13 looks like. If you live in the rust belt your frame is going to rust out and it will need to be replaced. Just accept that fact and move on. If rust scares you that bad don’t buy a Tacoma. It is an inevitable problem with these trucks.
  18. Oct 11, 2018 at 7:48 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2014 Tacoma DCSB..Pyrite Mica...6 sp MT
    the search goes on.........
  19. Oct 11, 2018 at 8:48 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    No way!! I'm in the northeast as well and I bought my '15 DCSB (non-TRD tho) for 25k with 14k miles on it. And I spent a good 30min underneath the thing before I bought it, not a speck of rust.
    The deal you listed above is not a good one.
    EDIT: remember, it's a toyota, jack up your acceptable mileage window. Find a rust free truck with 50 or 60k on it and it'll go for another 200k miles.
  20. Oct 11, 2018 at 10:31 AM
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, Toytec AAL, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Toyota Wheel Locks, Extang Trifecta Cover, Fumoto Drain
    Sheet metal underneath is rusting already. Owner was not proactively maintaining the underside in the winter. Possible flood vehicle? My 09 is rustfree and I live in the northeast!
    Skyway likes this.
