Looking To Get A 2013 4 Banger Extra Cab 4X4 Manual, Any Reviews?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by STOCKTRD, Oct 31, 2012.
  1. Nov 7, 2012 at 2:42 PM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    if you plan on towing/hauling alot get the 6, otherwise get the 4. transmission is simply preference. i wanted the configuration your looking at, but theres no way a 4cyl would tow the things i tow regularly
  2. Nov 9, 2012 at 1:04 AM
    Sunacus
    Sunacus Well-Known Member
    Sun
    Surrey, BC, Canada
    '12 Tacoma
    All stock!
    I test drove a white 2012 4cycl 4x4 Access cab in manual. I did not like it. It felt weird to me since I've always driven manual transmission cars that are smaller. The throw of the shifter was crazy. The clutch gripped at the very top. I don't know, maybe it's because I haven't driven standard in a long time. If I took that one out offroading, I would have fried the clutch by now or damaged the truck lol.
  3. Nov 9, 2012 at 5:54 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    I have the SR5 package and it will be a rare option to find, but worth it. You need to try both and see what you can handle. I didn't tow and wanted the manual. At the time the v6 had the TOB issue and there was no fix yet. The bigger factor for me was the $23,800 out the door vs almost 30k for the v6 version. It allowed me to spend money on suspension, wheels and interior. I have the 2012 mirror now and fogs, so minus the engine and trans it's pretty much what I liked in the v6.
    I had the tsb clutch done under warranty as the clutch was weak and would slip some. It shows more on the heavier AC 4x4, but since repairing it has been much better. It has plenty of get up and go; you just need to drop a gear and punch it. The v6 seemed odd with the gearing and 6th didn't lower the rpm enough to be useful to me. Shifting from 1st to 3rd to 6th wasn't much fun either. Everyone is different, so test drive away!
  4. Nov 9, 2012 at 11:08 PM
    Tommy27
    Tommy27 Well-Known Member
    Tommy
    Boise,ID
    White 09 AC 4x4 2.7 5spd SR5
    Leer shell, Bed mat, Grill Guard
    I also have a 4cyl AC 5 speed. I love it. I test drove an automatic so my friend could see what its like to drive a truck. When it was my turn I felt that the automatic made the truck very slugish. I think the 5speed should be almost required if your getting a 4 cylinder. 4 gears are not enough in the auto.
  5. Nov 10, 2012 at 6:57 AM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    The Toyota 4cyl, 5spd, 4x4 has been legendary and still sets the standard. :cool:
  6. Nov 10, 2012 at 6:58 AM
    superswamper003
    superswamper003 Taco
    Hendrik
    N. Snottsdale Arizona
    1998 4wd TRD 3.4l Tacoma Xcab 313k miles!!!
    Fox Xtended travel coilovers w/resis, AllPro UCA's, AllPro 3 inch leaflets, 1" Diff Drop, 285/75/16 Bfg KO, 16x8 Black Pro Comp Steelies, AP 1.25" wheel spacers in front, 8 inch Rockford Fosgate sub that bumps like your mother, old school deck, downey headers, cold air intake, grey wire mod, e-locker, hurst shift knob, LED Strips, USMC Decals FTMFW, Fox decal, Billet grille, Alarm with no remote, Straight piped to the side of the truck
    Awesome truck.
    Thats my review :)
