Looking to install a transmission cooler. Any particular one you'd recommend?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blewis1984, Jul 31, 2016.
  1. Jul 31, 2016 at 1:03 AM
    blewis1984
    blewis1984 [OP] New Member
  2. Jul 31, 2016 at 3:52 AM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    There was just a good thread on this a few weeks ago. I'm thinking the same thing and I have the factory tow package. There is a larger aftermarket cooler that was getting great results
  3. Jul 31, 2016 at 4:02 AM
    Capt Jrod
    Jarrod
    Northern Ohio
  4. Jul 31, 2016 at 6:42 AM
    blewis1984
    Awesome! Thank you so much.
  5. Jul 31, 2016 at 7:28 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Are you looking to replace a trans cooler or to add another one in series?
  6. Jul 31, 2016 at 10:38 AM
    Capt Jrod
    Jarrod
    Northern Ohio
    I think I'm going to swap the factory one for a larger aftermarket. It's either that or change fluid every 50k. Amsoil trans fluid claims to withstand higher temperatures. I never have sustained temps over 210, but I've seen it spike and drop off. Fresh clean fluid is the best medicine for any trans, but a cool transmission is a happy transmission. I do 90% of my towing around town, all my trailers have brakes and I have never hooked more than 4500# to the truck. I've only got 24k on the truck, but I don't want to step over a dollar to pick up a dime...
  7. Jul 31, 2016 at 11:51 AM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I also replaced my stock cooler with a larger, more efficient aftermarket unit. The stock cooler is a small tube and fin style; stacked plate coolers are more efficient. If you go this route, I strongly recommend you use existing mounting brackets and/or fabricate new brackets - steer clear of mounting the new cooler to the radiator using the supplied zip ties.
