Those with a ScanGauge. What's your typical transmission temperature?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KaPantsKey, Jun 21, 2016.
  1. Jun 21, 2016 at 5:38 PM
    KaPantsKey
    KaPantsKey [OP] Well-Known Member
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Our outside temperature has been in the high 90's here. I see temperatures of 160-200 around town. Some of that is stop and go through the city during rush hour. What's everyone else's temperatures typically? At what temperature should I be concerned?
  2. Jun 21, 2016 at 6:40 PM
    Capt Jrod
    Capt Jrod Well-Known Member
    Jarrod
    Northern Ohio
    15 WHITE DCSB 4x4 TRD SPORT
    Same as you are seeing... 180-190 when towing. 140's most days
  3. Jun 21, 2016 at 6:41 PM
    theox26
    theox26 Well-Known Member
    '11 DCLB Sport
    I monitor my temp for towing or when I have a heavy load in the bed. Without load I can range from 140-200 depending on the hills and my driving. Oddly, going slow in town or on slight inclines gets me the highest temps. I stay cooler going faster on an incline I assume due to the fluid cooler up front.
    When towing it tends to stay right around 175 - 200 and in hot temps has been as high as 220. I would stop and let it rest if I ever got to 240. Your limit and how often you change the fluid can vary for how much you want to push things.
  4. Jun 21, 2016 at 6:47 PM
    Capt Jrod
    Jarrod
    Northern Ohio
  5. Jun 21, 2016 at 7:26 PM
    wsurunner
    wsurunner Well-Known Member
    2015 Pyrite Mica DCSB
    I actually upgraded and replaced the stock tube and fin cooler with a larger stacked plate cooler as I saw temps climb higher than I was comfortable when towing with the stock cooler. Just got back from a 400 mile trip with the camper and it only reached 235 briefly during a long hill climb. I'd say 'normal' temps during the trip were 200ish across elevation changes and 95+ degree outside temps.
    brizower likes this.
  6. Jun 21, 2016 at 10:16 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I'm curious if someone here has BOTH a scangauge/ultragauge and one of the ELM bluetooth OBD readers + Torque for Android. I still don't trust the custom PIDs that are supposed to read the transmission temp.
    With my ELM + Torque, on a day when it's 95*F out, I see the following temps:
    Cruising around 50mph steady = 160*F at the pan, 165*F at the torque converter outlet
    On the interstate at 80 = 175*F on both
    I'm trying to wait until the warranty is up before I modify anything powertrain related, but I plan on installing one of these to hopefully drop the ATF temps to where they max at 170*F under the most extreme conditions.
    https://www.amazon.com/dp/B0035Z3NU...TF8&colid=315DJJJ0SLBRC&coliid=I3EA8Z5WK9GBZL
  7. Jun 23, 2016 at 6:58 PM
    KaPantsKey
    Kyle
    SC
    13 MGM DCSB TRD-OR
    Thanks for the responses. I am assuming you'd have to maintain those temperatures in the chart to have the ill effects of running a high temperature. Periodic spikes should be ok, right?
  8. Jun 23, 2016 at 7:26 PM
    2015WhiteOR
    Gainesville TX
    Sort of. You don't want to go too high, period.
    On the Tacoma, I believe the red AT TEMP light comes on somewhere between 320-340*F. Once that light comes on, the fluid is done for. It'll be cooked.
  9. Jun 24, 2016 at 2:17 PM
    Capt Jrod
    Jarrod
    Northern Ohio
    I decided that 50k change intervals were best for my style of driving/towing. Fluid = $125 ish dollars for 12 qts... New trans is $3500ish. Clean fresh fluid = happy transmission. Temp gauge allows me to know if I'm hurting it. Finally, NEVER TOW IN OVERDRIVE!!
  10. Jun 24, 2016 at 2:25 PM
    chyknees
    chyknees nomadic wanderer
    So Cal
    05 Tacoma TRD 4x4
    TRD, Total Chaos, Fox, Volk, BFHoodrich
    Normal city driving is around 180 to 200/210, depending on weather, if its stop and go, etc.
    Highway is around 180/190.
    If its a steep grade or long uphills I can sometimes see around 220 to 230's.
  11. Jun 24, 2016 at 2:26 PM
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    I always wondered when folks start adding armor, tools, camper shells, etc. shouldn't trans cooler be upgraded as well due to all the extra weight being added one?
  12. Jun 24, 2016 at 2:39 PM
    Iggy
    Iggy Well-Known Member
    Northern CA
    09 4x4 Off-Road Access Cab
    Check out the build
    Are you thinking of replacing the stock transmission cooler? I noticed you have an OR and assume you have the tow package.
  13. Jun 24, 2016 at 4:23 PM
    2015WhiteOR
    Gainesville TX
    Yup. The tow package cooler helps, but is dinky. I'm hoping there is enough line slack that I can pop the Mishimoto one in its place and just worry about bracket placement.
    Yup. Same goes for brakes. If you're adding a bunch of more weight (especially swamper type tires) then you should think about better brakes.
  14. Jun 24, 2016 at 4:34 PM
    wsurunner
    I replaced stock cooler with a larger one. The flex lines connect to hard lines to pass through into the engine compartment, I simply popped off those flex lines and ran lines from the new cooler to those hard lines. Used one existing mounting hole and made brackets to anchor to other mounting locations.
    2015WhiteOR[QUOTED] likes this.
  15. Jun 24, 2016 at 5:17 PM
    6xchamps
    6xchamps Well-Known Member
    Fuquay Varina NC
    2015 AC
    Which cooler did you upgrade to?
  16. Jun 24, 2016 at 6:51 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I have the dinky stock cooler and lately been seeing 170-180's with the hot weather.
    Reading with Elm327 and Torque. Got up to 190 a couple times but not over. This was with normal driving.
    The transmission shifts really smooth when the temp is 180.
  17. Jun 24, 2016 at 6:58 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  18. Jun 24, 2016 at 6:58 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    About overdrive. .. I didn't know that! Thanks!
  19. Jun 24, 2016 at 7:16 PM
    2015WhiteOR
    Gainesville TX
    That is impressive. Those temps are almost TOO low but I'd rather lose a little MPG than have to rebuild the transmission later on.
  20. Jun 25, 2016 at 3:50 AM
    Capt Jrod
    Jarrod
    Northern Ohio
    What about a bypass thermostat? My sequoia has one that the trans fluid only goes to the cooler if it gets up to 180... I have to override it to change the fluid and get it all
