Loose Bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TXTaco211, Jan 31, 2020.
  1. Jan 31, 2020 at 6:08 AM
    TXTaco211
    TXTaco211 [OP] Well-Known Member
    Corpus Christi, Tx
    13 Pyrite Mica TRD Sport DCSB
    Kicker Speakers, 5100's with HS coils and HS AAL, Caliraised 30" LED light bar
    When I bought my Tacoma the bed was loose.... well the forward passenger side you could grab a hold of and bounce it probably 1/4 to 1/3 of an inch I tried to tighten the bolt down and it seemed like it was already bottomed out. So I took it to the dealer the next day after I figured all this out and they told me it was missing a spacer and they "Fixed it". Fast forward 4 months and my bed is clunking again due to the same issue I haven't tried to tighten it back down yet but I did look for the "spacer" they said it was missing and could not see any spacer between the bed mount and the frame that the dealer said was missing and they installed. Has any one else had an issue with the bed bolts/spacers and is there a more permanent fix as the bed clunking is driving me nuts and I don't want to go through this every 4 months.
    Thanks
  2. Jan 31, 2020 at 6:17 AM
    Clearwater Bill
    Billy
    Largo Florida
  3. Jan 31, 2020 at 6:55 AM
    TXTaco211
    Corpus Christi, Tx
    Yes it can if you use the right wording in the search. Obviously I didn't find it. Thank you for your reply and assistance. And just to be clear there are 485 results for loose bed in the search function unless you know the exact title you could be on here quite some time trying to find the right thread. This forum is great for information I just wish people would be more understanding and less aggravated with someone asking a question. I am sure there is an answer for just about everything on here if you look hard enough some times its easier to possibly re ask a question than to spend hours trying to find the right answer that is why we are all on a message board for anyways right. To assist those that may not have the knowledge or were not part of a previous thread.
    Once again thank you for pointing me in the right direction.
    Rick's 2012 likes this.
  4. Jan 31, 2020 at 7:00 AM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    Here you go, a more accurate search feature that works on any website
    goto google.com and search this: "Site: www.xxxxxxxxx.com : search criteria"
    Example:
    https://www.google.com/search?q=site:+www.tacomaworld.com+:+loose+bed&rlz=1C1GGRV_enUS751US751&oq=site:+www.tacomaworld.com+:+loose+bed&aqs=chrome..69i57j69i58.9870j0j7&sourceid=chrome&ie=UTF-8
  5. Jan 31, 2020 at 7:11 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    If you had mentioned in your original post that you did use the search function and came up empty, Clearwater Bill probably wouldn’t have responded the way he did. Many folks come here without doing so and sometimes it irks people, understandably.
    Wish I could help you with your bed problem, good luck.
  6. Jan 31, 2020 at 7:16 AM
    wheeliest
    Json
    TMPE AZ
    its crazy how people read books that can take days to learn something and people on the internet cant research for an hour...
