Loose feeling when truck rocks side to side
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cvisinho, Apr 26, 2017.
  1. Apr 26, 2017 at 8:00 AM
    cvisinho
    cvisinho [OP] Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    Good morning all,
    For the life of me I cant sort this out and every time i bring it to the dealer they say there is nothing wrong.
    Whenever i go over uneven terrain or an uneven bump when the truck rocks side to side I can feel something a little off up front. I dont know how to explain it but something feels loose or moving/clicking. I can feel it in the steering wheel when its really rocking side to side. Like a bumpy dirt parking lot with divots all over.
    Thoughts? Its not wheel bearings or suspension according to the dealer. Ive looked around a bunch underneath and nothing looks out of the ordinary. This has been going on for as long as i can remember.
    Rides perfectly fine on flat roads. I know the 5100's are a little stiffer than stock but nothing similar happens when hitting bumps or little pot holes. I've driven my Dads newer tacoma over the same roads and dirt parking lot and it is definitely not an issue in his.
  2. Apr 26, 2017 at 9:01 AM
    Pigpen
    Dan
    Northwest Montana
    Your profile doesn't list the year of your truck. It does show that you had the frame replaced though. So many things could have been left under torqued. I would guess the major culprits to be the steering shaft (which could also just be shot) or the LCA/ UCA bolts.
  3. Apr 26, 2017 at 9:06 AM
    cvisinho
    Rhode Island
    Its an 05. This was happening before the frame was replaced too. I only noticed it when going up a driveway on an angle from the flat street back then though, which didnt happen too often.
    I should probably look into upgrading or replacing the bushings on the UCA/LCA for the hell of it anyhow. Im sure they are toasty now.
  4. Apr 26, 2017 at 9:56 AM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
  5. Apr 26, 2017 at 10:37 AM
    cvisinho
    Rhode Island
    f me sideways. I thought it was a joke when i saw the first pic but i am going to zip tie the shit out of that the first free moment i get.
  6. Apr 26, 2017 at 10:42 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    My truck does this. It's like a repeating rattle or knock that sounds as if there's torsional play in the steering shaft, prevalent on washboard roads. I've been meaning to try the zip tie fix but haven't gotten around to it.
  7. Apr 26, 2017 at 11:12 AM
    cvisinho
    Rhode Island
    I cant get outside fast enough right now to try this. However, i am at work:smash:, its pouring, and have no zip ties anyhow.
    RacecarGuy likes this.
  8. Apr 28, 2017 at 7:57 AM
    cvisinho
    Rhode Island
    WOW! i figured i would give this a couple days before posting.
    3 zip ties later and im blown away at how this solved my issue.
    Thanks for the link @RacecarGuy
  9. Apr 28, 2017 at 7:59 AM
    RacecarGuy
    Houston, Texas
    '12 DCSB OR
    Glad it was something cheap and not slop in the steering rack.
  10. Apr 28, 2017 at 8:00 AM
    cvisinho
    Rhode Island
    yeah, that was my biggest fear. thanks again
