Loose window
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cheesycook, Nov 8, 2009.
  1. Nov 8, 2009 at 1:45 AM
    Cheesycook
    Cheesycook [OP] Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    The driver door window on my 01 DC rattles pretty bad when closing the door unless it is all the way up or down. Any idea what I could do to snug it up again? Any small parts or would this require a whole new rail setup?
  2. Nov 8, 2009 at 2:05 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    there should be a little hex head bolt on the edge of the door that you can tighten (but not too tight because it will break) that will solve this issue
    ill try and get a pic tomorrow when its daylight
    Rastopher, FirstTimeFirstGen and DVS1 like this.
  3. Nov 8, 2009 at 2:07 AM
    JimBeam
    JB
    2015 Tundra
    edit...heres a pic
  4. Nov 8, 2009 at 2:08 AM
    JimBeam
    JB
    2015 Tundra
    that bolt holds the window track secure and can loosen over time...just tighten it down a bit and it should help
    ztwatson likes this.
  5. Nov 8, 2009 at 12:35 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    That did the trick. THANKS!!! That is the easiest fix I have ever had. :D
    ztwatson and keakar like this.
  6. May 15, 2017 at 11:49 AM
    DVS1
    DVS1 Well-Known Member
    Ray
    Tampa, FL
    18 4Runner TRD Off Road
    Fuzzy dice
    Glad I found this discussion! I have a 16 Tacoma and my back passenger window is having the same issue. When the window is rolled down half way. I am able to rock the window side to side. When window is rolled all the way down you can hear the window banging around inside the door.
    Fingers cross this will be the fix for my truck.
  7. May 15, 2017 at 12:01 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    wow, thanks for the bump, I needed this too.
    tacojim02 and GQ7227 like this.
  8. May 15, 2017 at 5:02 PM
    Sicyota04
    Sicyota04 Slowly but surely.
    Morgan
    California
    04 DC 4x4
    I just read this and since my driver's side front window is banging around inside the door. I thought I'd be able to just go out and tighten it. But it doesn't even have the 10mm hex head bolt at all! Should be able to go to a hardware store and replace it? But if you look closely at the picture the metal around it, is bent and looks like the bolt was ripped out
  9. May 16, 2017 at 5:48 AM
    DVS1
    Ray
    Tampa, FL
    Fuzzy dice
    My 16 doesn't have a bolt on the back passenger door. Hope this will be covered under my warranty.
  10. May 17, 2017 at 8:19 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    me too!
    GQ7227 likes this.
  11. May 17, 2017 at 8:39 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    makes me wonder how long it was like that before finally falling out. But yeah, you should be able to hit up a hardware store for a bolt. Put some thread lock on it.
  12. May 17, 2017 at 10:28 AM
    Sicyota04
    Morgan
    California
    04 DC 4x4
    If you look at the picture the metal is actually bent. Like the bolt got ripped out.
  13. May 17, 2017 at 11:20 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    May have caught on the door when closing and that's why it looks bent :notsure:
  14. May 15, 2020 at 12:54 PM
    ChipperD
    ChipperD New Member
    David
    2004 2WD Tacoma, SR5 4cyl
    Ran across this post thank to Mr. Google. Just registered at Tacomaworld.com in order to post a Thank You to 'JimBeam'! My windows been rattling a bit just as the OP's was. I was thinking I'd have to at least remove the inside driver side door panel... thanks for saving me the time I would have otherwise spent. Problem solved. Good day to you, sir!
    cornbread_wy, Bridge4 and GQ7227 like this.
  15. May 15, 2020 at 1:12 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TW David
    Wulf likes this.
  16. May 16, 2020 at 3:28 PM
    JFS
    JFS Member
    2003 2.4 Tacoma regular cab
    swapped bench for bucket seats, monstalinered the bed.
    Just bought my first Tacoma (2003 2.4 regular cab) and my mechanic was excited to hear it. I have this same bolt issue and rattling in the door. The window opens and closes all right but there's rattling when closing the door. My limited mechanical skill tells me that bolt is supposed to secure something on the inside. What is it? Is there an exploded view of this door somewhere? I'm just trying to figure out what I'll face once I pop the door panel. Also, can anyone tell me the exact bolt I'm looking for? Much appreciated. Let me just say, I drove two hours to buy this thing, and I was stunned in the good way at the way it drives. I think we'll love this vehicle. I've posted a pic of the missing bolt, but if it doesn't come through, it looks just like the previous one, except there's no bending of metal at the hole. The truck has been repainted, if that explains where the bolt went. I thought it might be inside. No idea what's actually rattling in there. Thanks for any help.
    GQ7227 likes this.
  17. May 16, 2020 at 4:13 PM
    Black DOG Lila
    Virginia
    Welcome aboard new member
    JFS likes this.
  18. May 11, 2021 at 12:19 AM
    cornbread_wy
    cornbread_wy Well-Known Member
    W
    San Rafael, CA
    98 xtracab 3.4l Sr5 4x4 - copper mica
    5100 w/ 881
    bump - cause this site rocks. Thought I had to open up the door panel and found this thread for my drivers side window thats been rattling for 7 months. :amen:
  19. Nov 7, 2023 at 6:02 AM
    jconlon6544
    jconlon6544 New Member
    2002 Tacoma 4 cylinder extended cab
    Good tip with the bolt ! Saved me an hours work
