Loss of power after replacing injectors
Discussion in '1st Gen. Tacomas (1995-2004)' started by jl0, Nov 25, 2019.
  1. Nov 25, 2019 at 8:46 AM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    Hello all,
    Long time lurker first time poster.
    I have a 2001 Tacoma 2.4l rwd with about 175k miles on it. This past spring it started sputtering and misfiring like crazy while I was on a small trip. It was right after I got gas. I pulled into an auto parts store and the guys there asked where I got gas. Upon answering they said I got bad gas and that station was known for this. Yellow heet and keep driving. I got home like that and it was a tiny bit better but I knew something else was up. After a ton of research I got to work. Cleaned MAF sensor. Cleaned throttle position sensor. Changed fuel filter. Changed plugs. After I changed the spark plugs it seemed to be running fine. Until recently when it got really cold.
    I started it up one cold morning just fine and went to work. When I left work it started misfiring again. Back to the drawing board. After more research this problem seemed to be a clogged or bad fuel injector. Did the test. Yup. So I ordered new ones (supposedly oem) and replaced them and cleaned my fuel rail. No more misfiring but it hesitates to start (but does if you give it a little gas) and I certainly lost quite a bit of power. I wish this wasn't a big deal. But. I live at 8k feet and drive a 4 cylinder like an idiot cause that's what I have. So! Any ideas or suggestions?! Can't seem to find anything. Thanks in advance for even reading this novel. Cheers!
  2. Nov 25, 2019 at 8:55 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Where did you get your injectors from? there have been several users who have documented getting fake "Toyota" injectors through Amazon and ebay
    Timmah! likes this.
  3. Nov 25, 2019 at 9:00 AM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Where did you get the injectors from? Might not be OEM.
    If the fuel you got was indeed bad, maybe there's a possibility the filter in the tank that attaches to the fuel pump is partially clogged. The video below show the filter I'm talking about. Go to play time 27:17. This job was done on a 3rd Gen 4runner but I imagine it will be similar to your 1st Gen Tacoma. Getting the fuel pump electrical connection undone might be troublesome because you don't have a hatch you can pull to get right on top of it. You might want to get everything disconnected and then drop the fuel tank slightly so you can have an easier time getting your hand on top of the tank to disconnect the connector.
    https://www.youtube.com/embed/GrzX_K-jcuo
    CS_AR and jl0[OP] like this.
  4. Nov 25, 2019 at 9:05 AM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    Amazon... Uh oh.
  5. Nov 25, 2019 at 9:16 AM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    So step one I should probably get some quality injectors from a trusted source? Where? My friend that helped me threw my old ones away ‍♂️ so I can't send them in.
  6. Nov 25, 2019 at 9:23 AM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    Either your local dealer or a Toyota dealership that sells parts online. Camelback Toyota in Phoenix seems to be the dealership of choice on this forum.
  7. Nov 25, 2019 at 9:34 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    How much were the ones you bought on Amazon and do you still have the vendor info? That may help us determine if they were counterfeits
  8. Nov 25, 2019 at 9:36 AM
    cruiserguy
    Elijah
    SEKS
    The MIL blinks or illuminates when you're misfiring right? What codes are you seeing from an OBDII scan?
  9. Nov 25, 2019 at 10:55 AM
    Timmah!
    TIM
    Please, Please, Please, PLEASE, do not buy brand new OEM injectors. You will pay an arm, a leg and maybe your right or left nut too. They are crazy expensive and it's totally unnecessary to buy new. There are businesses that refurbish them. The place I like is located in Los Angeles, CA called MotorWest Performance. I link the business in the video description below. Lots of people have used MotorWest refurbished OEM injectors with great results and it's a huge money savings. I actually visited this shop when I was in LA visiting a friend and the owner Martin Diaz is a good dude.
    https://www.youtube.com/embed/N-lhZIWOkyU
    Rachelsdaddy and outlawtacoma like this.
  10. Nov 25, 2019 at 11:00 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Good point about checking the fuel tank. Is there a way that we can direct the OP to verify fuel pressure at the rail to identify a weak fuel pump or pressure regulator?
    I've seen a lot of injector failures isolated to a single cylinder misfire or fuel leak.
  11. Nov 25, 2019 at 11:11 AM
    Timmah!
    TIM
    I've never performed a fuel pressure test at the fuel rail or anywhere else in the fuel system so I wouldn't be much help. Hopefully somebody will have some suggestions on how to go about doing it.
  12. Nov 25, 2019 at 12:36 PM
    CS_AR
    I see Tundra people talking about using this fuel pressure loaner kit from Autozone. Will need someone who has done the test on a 2rz to suggest where to tap into the fuel system.
    https://www.autozone.com/loan-a-too...F:US:EN:AZ:NL:1000000:GEN:ppjmid21181-8-11065
    If we were talking about a 3.4L, I can see how this fuel rail banjo bolt pressure tap can come in real handy.
    Thread about rail pressure testing using a banjo bolt. .
    https://www.tacomaworld.com/threads/3-4l-fuel-issue.452218/page-2
    Bails369 likes this.
  13. Nov 25, 2019 at 1:50 PM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    It did originally and it was a cylinder 3 and 4 misfire. But this second time around I didn't drive it long enough for it to get bad and throw a code, and it isn't misfiring anymore.
  14. Nov 25, 2019 at 1:51 PM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    They were only $45... I should have known better. The vendor is called Jem&Jules. Is that one of the ones people have had issues with?
    CS_AR likes this.
  15. Nov 25, 2019 at 1:52 PM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    I will definitely order refurbished injectors from them. Thanks so much for the suggestion!
    Timmah![QUOTED] likes this.
  16. Nov 25, 2019 at 1:53 PM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    This is super useful. I think once I put in injectors that I know are quality I will refer to this if there are still any problems. Thanks so much for the info!
    CS_AR[QUOTED] likes this.
  17. Nov 25, 2019 at 1:54 PM
    CS_AR
    The bulk of the counterfeits that I've seen have been for the 3.4L. When a deal is too good to be true on a critical part like an injector, it usually is.
    Rachelsdaddy and jl0[QUOTED][OP] like this.
  18. Nov 25, 2019 at 1:56 PM
    CS_AR
    Please post some pics of the counterfeits. I have plenty of counterfeit pictures for the 3.4L but none for the 4-cyls.
  19. Nov 25, 2019 at 1:56 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Hard to say, I tend to tell people to avoid car parts from places like Amazon anyway. Either you're getting Chinese counterfit parts or you are relying on Amazon (who sell games and books) to know exactly what parts fit your vehicle.
    Stick to automotice specialists at least. Rockauto is good. Some parts IMO it's more important to go OEM (new or reman'd) like engine internals.
  20. Nov 25, 2019 at 1:58 PM
    jl0
    jl0 [OP] Member
    Jeremy
    2001 Tacoma 2.4l
    As soon as I get them out I will. They looked exactly the same as the OEMs that I took out to me.
