Loss of power with lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sneakysnack, May 8, 2017.
  1. May 8, 2017 at 1:57 PM
    sneakysnack
    sneakysnack [OP] Member
    I recently got my 2011 Tacoma TRD off road lifted (6inch rough country with 35s). I got it re geared as well with 4:56. I can't go above 80 on the highway and it revs high RPMs. I notice the power loss when accelerating as well. Is this from the lift or something else?
    ChadsPride likes this.
  2. May 8, 2017 at 2:20 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    It's the tires. 35 inch tires are gonna slow you down even with the regear.
    agunday21, ChadsPride and Alexely999 like this.
  3. May 8, 2017 at 2:21 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    x2
    The re-gear will get you back closer to factory ratios, but not factory weight.
  4. May 8, 2017 at 2:21 PM
    sneakysnack
    Thanks Harry, what size tire will get me back to normal stock speed and performance with that regear?
  5. May 8, 2017 at 2:22 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Is it an auto? I would have recommended 4.88 gears instead. Besides, these trucks have the aerodynamics of a UPS truck. Lifting it up ~8" (lift and tires) is not going to help either.
    ChadsPride and THROTTLE231 like this.
  6. May 8, 2017 at 2:23 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    Theoretically a tire that weighs the same as the stock one's but is tall enough to match up with the re-gear, don't know if that exists though.
  7. May 8, 2017 at 2:25 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    33's w/ with 4.56 then? It would probably help.
  8. May 8, 2017 at 2:28 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah, and something skinnier will help too since there's less rolling resistance. I'd recommend some 34x10.5r17 KO2's as they only weigh 56lbs. Or possibly a 255/85r17 tire. They're also 33" tall, but 10" wide aka pizza cutters. That'll help too.
  9. May 8, 2017 at 2:32 PM
    Harry
    Santa Fe NM
    Or - there's always the supercharger option :burnrubber:
    danbow, 1mike1888, ChadsPride and 4 others like this.
  10. May 8, 2017 at 2:44 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I don't think he can get 255/85/16 or 255/80/17s.. Pretty sure you have to run at least 18in wheels on 6in lifts b/c you have to flip the tie rod ends to keeping steering angles decent and 18's are the smallest wheels that will clear.
  11. May 8, 2017 at 2:45 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hmm, never heard of that before.
    OP, what size wheels are you running?
  12. May 8, 2017 at 2:48 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    I had heard that, but I just looked under my truck, looks like plenty of clearance to flip the tie rod ends w/ my 16s... maybe there is another reason.
    I remember reading that 18s were the smallest due to some clearance issue, but I have apparently forgotten why.:anonymous:
  13. May 8, 2017 at 2:51 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Skimming through this thread real quick, I found a few members running 17" wheels.
    https://www.tacomaworld.com/threads/fabtech-procomp-6-lift-or-more-pictures.43093/
  14. May 8, 2017 at 2:58 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
  15. May 8, 2017 at 3:12 PM
    Clearwater Bill
    Billy
    Largo Florida
    Yes it is.
    The lesson to be learned here is to research before spending your money.
    Wait till you see what's happened to your MPGs. And many will come along and say it's a truck, it doesn't matter, but they are only the 5% er's
    Hopefully you'll be able to resolve it to perform as you wish w/o having to double your spending...........
