Lost boost?
Discussion in 'Performance and Tuning' started by WOODEX M.E., May 13, 2017.
  1. Nov 5, 2017 at 10:45 AM
    #121
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    @WOODEX M.E.
    Came across this lost boost issue.
    XPOTRPR likes this.
  2. Nov 6, 2017 at 8:42 AM
    #122
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I think I'm gonna fiddle with my bypass valve today...
    inwood customs and 12TRDTacoma like this.
  3. Nov 12, 2017 at 6:27 AM
    #123
    WOODEX M.E.
    WOODEX M.E. [OP] Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I dunno, im probably going to take the charger off and have it rebuilt in the spring anyways. A that point it will have about 100k on it and i can address a couple things while im at it. New gaskets, hlicoil some holes, smaller pulley maybe.
    I used a vacuum puller to check the hose connctions and they all seemed fine. I do wanna try out the coated pulley thing. Right now perfomance is satisfactory/ acceptable and since i dont have a place anymore to work on the truck out of the elements, I'm trying not to break it till summer.
    Biscuits likes this.
