Lost headlights
Discussion in 'Lighting' started by Techoma, Jan 16, 2012.
  1. Jan 16, 2012 at 7:26 PM
    Techoma
    Techoma [OP] This is the Wild, Wild, West!
    Alta Mesa, AZ
    Extreme Expo 05 PreRunner
    Dirty fives on Level 8s, 4.88 gears and Harrod Locker on rear. Cab Chop x2, MBRP Cat Back Dual Exhaust w Flowmaster 44 for punch, cut off at rear axle, Throttle Body spacer, Camburg UCA and Coil-Overs, Matrix Spindle lift up front ProComp extended travel on rear w\ Dakar leafs +, Panasonic HU w Front x2 and rear x1 camera, kicker 500 powering 2 JL Audio 10" subs, JL component speakers in front doors and JL audio coaxials in rear doors powered by alpine 600 amp. Cobra all in one CB, Easy Lift hood, and Easy Down Tailgate, Pop N Lock, Dual RGB Halo Projectors, Blacked out tails with HI intensity LED's, Scanguage II, AVID Custom sliders and Hybrid rear bumper, Pelfreybilt Hybrid front, Glock Steering Column Holster, 2 Hella's behind Satoshi on Avid light Bar, Decepticon Badges, 2x 24" LED ropes and 2X 4" HI LEDs to fire up Satoshi w Super Bright green Halo's. Under Hood lighting as well as RGB rock lights. PrinSu Cab/Shell Rack with FreeSpirit hard shell RTT, 28", 2x 20", and 50" LED Bars all controlled by SwitchPros and Weathertechs front and rear.
    I put in a new battery today. I use top AND side terminals. I have my aux lighting (seen in my sig and avatar) connected to side terminals... And stereo amp to top post with oem battery cable.
    When I connected the powerlines to side terminal, my aux lights.. At least some, as well as my green LEDs flashed and went out. I finished tightening and started the truck. It fired right up. I hit my green rocker to test green LEDs and they did not turn on... But light on green and orange switch are lit, but not full brightness. The orange switch is my behind satoshi hellas. They do not work either. Interesting enough... My headlights do not work. 3rd set of lights on blue switch work just fine... Hellas on bull bar.
    I know it's a short.. I can't find where. The LEDs and satoshi Hellas work if I put them direct to the battery. It appears the relay for satoshi lights may have arched... As there's discoloration and I smell it. Even with ithat relay removed...mgreen LEDs and headlights are out.
    High and low beams are out. I checked all aux fuses... Good. Right and left headlamp fuse is good. Fogs work... And I do have the fog light mod done. I have no ideas where the headlight relay is.
    Any ideas? I'm going to replace the suspect bad relay tomorrow but I don't see how that plays into the headlights. I work very late tomorrow... So I need to try and fix at lunch. Driving with the bull bar Hellas will def get me some blue light attention from the law. :eek:
  2. Jan 16, 2012 at 7:48 PM
    superwhite10
    superwhite10 Well-Known Member
    Garner, NC
    double check all your fuses. when i did the lighted 4x4 switch mod i blew a fuse in the process and lost all interior and brake lights. got the manual out and the fuse panel cover and went searching for the fuse. took me a couple trys to find the right one. hope you figure it out!
  3. Jan 16, 2012 at 7:52 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Did you accidentally reverse polarity any of your connections, even briefly? Were the switches for the lights that flashed turned on at the time?
    Headlight relay's are in the underhood fuse box. Hopefully you checked all the fuses in there and the ones in the interior box to the left of the steering column.
  4. Jan 17, 2012 at 12:05 PM
    Techoma
    Alta Mesa, AZ
    Haven't gotten out to it today... Although I'm sure nothing was reversed (almost impossible the way it I changed out the battery) The green LED's and Headlight switches were both on when the battery was reconnected. I will recheck all the fuses soon. If I don't find a blown one, my plan is to swap out all 3 AUX relays. At under $5 each... what the hell! I have confirmed all AUX lights will work if directly coonnected to the battery.
