Lost my dash lights after installing a stereo, help fix it?
Discussion in 'Audio & Video' started by RobbySkateboard, Jun 6, 2012.
  1. Jun 6, 2012 at 12:15 PM
    RobbySkateboard
    RobbySkateboard [OP] Well-Known Member
    Robby
    Thousand Oaks, Ca
    05 4x4 Tacoma TRD Sport DCSB
    ok, I'm not good with things like this as is clear after my other thread, but I finally have everything done (I took a few days break from it and just rode my motorcycle) but now that I'm back to it, last night I noticed, when I had my lights off, my dash lights were on like normal, but when I flipped my lights on, I lost my dash lights, couldn't see my speed or anything. I had two wires from my scosche harness attached to the actual head unit (pioneer) I connected the orange (+12v illumination) and the orange/black (dimmer) to the pioneers orange/white (lighting switch terminal). So today I tried to fix it by trying just one of the wires, orange/black to orange/white wouldn't dim (didn't pay attention to dash lights) and then what I have right now and just left it as is orange to orange/white, which dims, when I turn the headlights on, but I have no dash lights in either the lights on or off position, can someone PLEASE help me, I've already done the vast majority of it and would hate to have to go to a shop for them to do it because they'll have to redo the whole thing so that they can back their work and that'll cost $120 at the lowest, so if someone here could please save me the money and explain what I need to do with that I'd be forever in your debt.
  2. Jun 6, 2012 at 12:27 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar/Ontario, CA
    08 TRD 2wd converted to 4wd
    Estock
    dude you have my cell...call me!!!..
    nvm, check what i just told u to check haha..
  3. Jun 6, 2012 at 12:53 PM
    RobbySkateboard
    Robby
    Thousand Oaks, Ca
    he told me to check my fuse, which was still good, anyone have any other ideas?
  4. Jun 6, 2012 at 1:05 PM
    Casey05Taco
    Casey05Taco Well-Known Member
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    trd seat covers, bed mat, tinted windows, debadged, mud flaps removed, tinted tails, blacked out center console, Black Rims, 6000k HID in highs and fogs, blacked out front emblem, Pioneer AVH-4300DVD, Gauge Cluster, lower valence, retrofitted, audio system, Maxtrac Spindles, Billies
    I dont see what you tapped into to lose every light in your speedo. Thats what gets me. When i installed my HU i didnt have any of these problems. It was a simple connect the wire with the corresponding colors.
  5. Jun 6, 2012 at 1:06 PM
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
    What did you do with the orange wire or orange with a white stripe?
    If it is grounding out it would cause the dash lights to fail. Disconnect all orange wires and report back.
  6. Jun 6, 2012 at 1:12 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    So i went and dug thru my new hu box and i remember they put a wire diagram in there for me. On mine it says that the Orange/Black isnt used. Ill add a picture to this once it uploads onto photobucket.
    Biscuits likes this.
  7. Jun 6, 2012 at 1:12 PM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    I dont know if this helps, but the pioneers do not dim with the dimmer switch. The only way they dim is when you turn on the headlights.
  8. Jun 6, 2012 at 1:17 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    I tied some electrical tape to it and left it.
  9. Jun 6, 2012 at 1:24 PM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    Post a pic of your wiring. If it grounded out it should have popped a fuse. If the radio is completely disconnected, harness and all, just the factory plugs remaining, do the dash lights work? If not it is hopefully a fuse.
  10. Jun 6, 2012 at 1:29 PM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    Sorry, I just realized you are not the OP. Are you having issues too?
  11. Jun 6, 2012 at 1:31 PM
    Casey05Taco
    Casey
    Penngrove, CA
    05 Tacoma Prerunner
    no, im having zero issues with connecting the wires i listed above. Just trying to help out the op who is somewhat mia
  12. Jun 12, 2012 at 5:44 PM
    Mep
    Mep 10 in. Member
    SW Ontario, Canada
    2012 DCSB SR5 w/ MT
    ExTang Solid-Fold Tonneau Cover, Weston 3" Step Rails, OE Skid Plate
    If it's not important to you that your stereo's LEDs dim with your dash lights, leave the orange and the orange/black disconnected. It sounds as though your stereo is interfering with your truck's dimmer reference signal.
  13. Jun 12, 2012 at 5:59 PM
    Jerez
    Rod
    Estock
    So me and ProForce (Anthony) checked it out today...
    The problem was that he connected both wires together (+\-) so it over loaded the dimmer switch causing the switch to short itself and not letting the power to go thru...all is well now :thumbsup:
  14. Jul 30, 2012 at 4:34 PM
    lilzee
    lilzee New Member
    Michael
    Mountain Home ID
    08 SR5 v6
    Im having the same issue he had. do you know which wires are the positve and negative and where do i need to hook them up too? Im having to use some LED's from autozone and it doesnt look right.
  15. May 22, 2016 at 8:45 AM
    Jdstory9
    Jdstory9 New Member
    Jesse
    2008 white Toyota 4Runner SR5
    After reading the description from the post I have run into the same issue. I have installed a Pioneer FH-X720BT head unit into my 2008 Toyota everything on the Head unit works as designed however when I turned on my headlights I no longer have my dash board. I removed the new unit and put the old unit back in to se if it was a wiring issue still no dashboard lights. I have also removed the illumination wore from the new HU and now dash lights. Can anyone help me out with troubleahooting? I am currently checking fuses but I don't know what else to look at beyond that.
  16. May 22, 2016 at 10:56 AM
    Jdstory9
    Jdstory9 New Member
    Jesse
  17. May 23, 2016 at 7:59 AM
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    Pioneer uses a different wiring color method, what did you hook the orange wire and orange with white stripe to?
  18. May 23, 2016 at 8:12 AM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Check your fuses if you have no dashboard lights after you removed the pioneer unit.
  19. May 23, 2016 at 8:47 AM
    Jdstory9
    Jdstory9 New Member
    Jesse
    I checked the fuses and I currently do not have the orange wire, orange white, and brown black are not connected at all.
  20. May 23, 2016 at 9:38 AM
    Revelations
    2014 MGM DCSB
    I'm pretty sure you need those brown and black wires connected. If your OEM radio is back in, everything should be connected.
