lost sound from front
Discussion in 'Audio & Video' started by jimmy c, May 15, 2021.
  1. May 15, 2021 at 8:07 AM
    jimmy c
    jimmy c [OP] Well-Known Member
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Help! was on way home and lost sound from front speakers. have a pioneer avh head unit and rockford fosgate component front speakers. Have almost no sound from front left tweeter, no sound from driver, and nothing at all from front right. all rear is working.
    Is there a easy way to determine if its the head unit, or possibly the crossovers on the speakers themselves? all other functions work from H U. Tried playing with some settings while driving, thats not fun. all was working perfectly. H U is about 3 years old and speakers are about 1 year old. have extended warrantee on H U.
  2. May 15, 2021 at 8:19 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Meter them. It's just a matter of going through the process.
  3. May 16, 2021 at 7:23 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    Yeah you’ll need any basic multi-meter and maybe a 9v battery if you have one laying around.
    A spare 70-1761 harness would make things easier as well.
    If you have sound from a tweeter, then the radio is putting out power. Since you have a 2nd gen, your tweeters are also in the doors. So I’d pull the door panels and inspect your crossovers. Mane people (and ‘professional’ shops) have a bad habit of mounting them where they can get soaking wet, or fall off completely.
  4. May 17, 2021 at 9:23 AM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Hopefully this week i will take my meter home and test them. maybe find a used good speaker for a test also. Still have 7 months left on my warrantee. Also looked for new head unit and most i would like to have are out of stock with no date available. Damn Covid. Best Buy says they will have to send out for repair and may take more then 3 weeks. Will wait till after vacation if i have to do that.
  5. May 19, 2021 at 8:07 AM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Just curious if there is a way with meter to test signal from head unit to speaker's. will ohm out speakers tonight. dont want to remove head unit again if i dont have to.
    thanks
  6. May 19, 2021 at 8:13 AM
    dolbytone
    South Carolina
    09 TRD Off Road
    If the speakers are unplugged, meter AC voltage while playing a test tone. It will increase/decrease in voltage as you turn it up and down.
    This is assuming your stereo is not load sensing.
  7. May 19, 2021 at 9:32 AM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    tried that last night with HU out and plugged in. rear was nice and steady. front was getting signal raising and lowering volume with radio, but was not real steady. is going into component speakers with built in non adjustable crossover. will try at speaker and ohm out tonight. Thanks
  8. May 26, 2021 at 8:41 AM
    jimmy c
    jim
    Port St. Lucie Fl.
    2015 tacoma
    Finally removed door panel, check signal to speaker, all good. Ohm speaker, showed open. Remove and found terminals rusted off the driver. Had everything sealed and never had a water leak. Some how water got in and wicked it's way up the wire to the driver. Guess i lost right side and didnt notice untill left went out. Crutchfield here i come.
