lost the battle with Toyota corp on my differential
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EMT760-, Oct 12, 2017.
  1. Nov 4, 2017 at 11:40 AM
    #201
    la0d0g
    running for the hills
    For crawling not hauling
    Pop it open, scrape off old shit, lay down bead of RTV, tighten it up and be done with it.
    EatSleepTacos likes this.
  2. Nov 4, 2017 at 12:09 PM
    #202
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    No way on a truck with a warranty. Toyota will blame you till the end of time if you monkey with it.
    Out of warranty, absolutely.
    jackn7 and la0d0g[QUOTED] like this.
  3. Nov 4, 2017 at 12:14 PM
    #203
    la0d0g
    Its not monkeying with it, its fixing it and if you used FIPG there would be no way to tell.
  4. Nov 4, 2017 at 12:16 PM
    #204
    httuner
    httuner Well-Known Member
    2015 Tacoma TRD-OffroadPckg
    AFe Rebel Catback Exhaust, AFe GT Momentum Air Intake, Method Wheels, Bilstein 5100, Rigid 30" SR2 Light Bar, Rigid 10" SR Light Bar. Lots of Love
    Yup; Toyota will do anything to deny repairing anything. They blamed my driverside window motor noise on my Window Visors! Then they blamed my vibrating driveshaft on my 2inch lift and aftermarket tires when the last 64k miles I didn't have the vibes and it just became a recent issue. And now my blower motor is howling and they say its normal operation noises.
    The vibrations and blower motor noises are all common issues yet they will deny it all the way.
    la0d0g likes this.
  5. Nov 4, 2017 at 12:19 PM
    #205
    Lt. Dangle
    Ohio
    It's exactly monkeying with it. You go ahead and try and let us know how it goes.
    la0d0g[QUOTED] likes this.
  6. Nov 4, 2017 at 12:23 PM
    #206
    la0d0g
    How do you think they would fix the issue? Magic? No, they would take it apart, clean the surface, put down some FIPG, and seal it back up. Not sure why that would be classified as monkeying with it.
  7. Nov 4, 2017 at 12:25 PM
    #207
    Lt. Dangle
    Ohio
    OMG... If they do it is not monkeying with it. If they see you have tampered with it, congrats its now your baby. Toyota will say you messed it up, its now not a warranty issue but a repair ticket issue. Quit being dense.
  8. Nov 4, 2017 at 12:26 PM
    #208
    VirusCage
    VirusCage Overwhelmed with fun
    Bruce
    Allison Park, PA
    2017 TRD Sport DCSB 6MT 2015 Highlander XLE
    Hood deflector, window vent visors, stainless steps, kb voodoo bedrack, bed cubby cap seals, meso ext fuse cover, meso lower switch panel, 4xhella horns, power tray aux panel, 2wd lo mod, rear FU lights, bed led lights, BPF SKID and Hook, rear view mirror usb power ports, front and rear dash cam, front and rear cam anytime mod, cherry air freshener! Anytime 400watt, inside 110v outlet, BPF Skid plate, BPF shackle mount,
    I may have missed this is all of the posts, but there seem to be tacomas with no diff howl and some with the diff howl...is there there any difference in the diff based on where/when the truck was built? Again sorry if this was covered, just curious.
    San Antonio vs Tijuana?
    la0d0g likes this.
  9. Nov 4, 2017 at 12:27 PM
    #209
    Lt. Dangle
    Ohio
    No difference. Luck of the draw. Diffs aren't made at assembly plant anyways.
    la0d0g likes this.
  10. Nov 4, 2017 at 12:27 PM
    #210
    la0d0g
    Please tell me how they would know if it's been tampered with?
  11. Nov 4, 2017 at 12:31 PM
    #211
    Lt. Dangle
    Ohio
    I could tell they torqued my rear end just by looking at the nuts. I'm sure using the rtv you initially suggested doesn't require a degree in anything from Toyota U. I'm also thinking that using the FPG would show once they cracked the diff and yours looks different from the 9000 other diffs they have had to open. Bottom line is why would anyone with half a brain cell give Toyota a reason to deny them warranty coverage until the warranty option is completely exhausted?
  12. Nov 4, 2017 at 12:31 PM
    #212
    VirusCage
    Bruce
    Allison Park, PA
    I wasn't thinking the diffs were made there, but for instance, when I worked for Acura/Honda different factories (assembly points) used different suppliers for parts. Even though many were "interchangeable" even used the same part number the manufacture was actually a different company between the parts, we saw more failures with one over the other. CL/TL/Accord window regulators and motors. MDX/Pilot rear diff (although not a conventional diff) there were three suppliers for a while. Integra/Civic Radiators...stuff like that.
    la0d0g likes this.
  13. Nov 4, 2017 at 12:35 PM
    #213
    Lt. Dangle
    Ohio
    As far as I know, Hino is the maker off the OR diffs(maybe sports too, dunno) and my OR does not howl, others do. I do not know if HINO assembles them in multiple plants or just one, but if it was a supplier issue like that, I'd assume Toyota would have nailed it pretty quick.
    Like I said, I think its just luck of the draw if you get a noisy one or not.
    la0d0g likes this.
  14. Nov 4, 2017 at 12:36 PM
    #214
    VirusCage
    Bruce
    Allison Park, PA
    Thanks for the info. No howling yet for me, either I got luck or it just has not started yet...
    la0d0g likes this.
  15. Nov 4, 2017 at 12:37 PM
    #215
    Lt. Dangle
    Ohio
    I'm at 9997 and no noise. Good luck.
    /I do have a leaky diff though, so...
    la0d0g likes this.
  16. Nov 4, 2017 at 12:42 PM
    #216
    la0d0g
    Not sure why it would look different. And you would do it so it would be fixed.
  17. Nov 4, 2017 at 12:43 PM
    #217
    EMT760-
    EMT760- [OP] Well-Known Member
    17 Tacoma TRD Offroad 4x4 DCLB
    As a,lawyer I talked to said " Toyota is worse than the mafia". 100% true.
    la0d0g likes this.
  18. Nov 4, 2017 at 12:49 PM
    #218
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    The Mafia kills people, so far a Howling rear differential in a Tacoma has not
    Omar RVA, hiPSI and la0d0g like this.
  19. Nov 4, 2017 at 12:49 PM
    #219
    Lt. Dangle
    Ohio
    Because FPG is not the same as the gasket it is assembled with. Not to even mention I already told you that you can tell the diff has been opened/touched simply by looking at the nuts themselves.
    You know what, you are right. Go ahead and fiddle with your truck and then try to claim warranty status for the repair. Let us know how it goes.
    Actually nevermind, I see you are a second gen owner. Figures.
    stun gun, hiPSI and la0d0g[QUOTED] like this.
  20. Nov 4, 2017 at 12:53 PM
    #220
    EMT760-
    But Toyota killed people with Prius and said it was " floormats".
    :der:
    la0d0g likes this.
