lost the battle with Toyota corp on my differential
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EMT760-, Oct 12, 2017.
  1. Oct 12, 2017 at 9:53 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    "Fool me once"....
    scottalot[QUOTED] likes this.
  2. Oct 12, 2017 at 9:54 AM
    EMT760-
    EMT760- [OP] Well-Known Member
    17 Tacoma TRD Offroad 4x4 DCLB
    The independent shops both recommend a tear down. One shop did not charge me, other cost $ 25.00 they even had 2nd Gen Tacomas with trucks parked outside. The driveline/differential shop says they do 5-10 carrier bearing jobs/differential jobs on 2d gens a month. Both shops have told me its the contact pattern/ or bearing.
    The dealerships have told me its " normal". So I went around them to corporate, then executive who ultimately took the FST opinion on a set of handwritten notes in a format of 4 sentences that made the whole ordeal go south and caused them to close my case.
  3. Oct 12, 2017 at 9:55 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    ........so is that a no on the memes?
  4. Oct 12, 2017 at 9:56 AM
    Trucko
    Trucko Well-Known Member
    Summit County Colorado
    2005 Tacoma
    arb bull bar Smittybulit 9.5 winch topper shell with yakima basket piaa lights toytec boss coilovers Dakar leaf pack with boss shocks 28/75/16 bfg at ko2 Midland CB Home made trailer with CVT Mount Rainer tent and max coupler hitch
    Well that sucks. sorry to hear man. any option to trade it in a get something else.
  5. Oct 12, 2017 at 9:57 AM
    smitty99
    Scottsdale
    Seems like Toyota went to the lowest bidder for supply of the diff assemblies and then didn't properly field test or enforce quality controls over said vendor.
  6. Oct 12, 2017 at 9:59 AM
    EMT760-
    The driveline shop told me exactly that. They think Toyota is getting screwed by their supplier. He said OEM gearsets should not make that noise because they come pre-lapped Aftermarket gearsets can make noise because they're not-prelapped which is why the first 500 miles is critical.
  7. Oct 12, 2017 at 10:05 AM
    DirtDriven
    DirtDriven Active Member
    I have went through the lemon law in my state. I varies a little state by state I think. It can be a long process, but in the end it can be worth it. They even paid me back for all the accessories I had added to the truck. How many times has it been to the dealer for the same issue?
  8. Oct 12, 2017 at 10:05 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Welcome back.
    tcjacado, Joe23, over60 and 2 others like this.
  9. Oct 12, 2017 at 10:07 AM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    I am a little confused. What are you going to lemon law? A diff they say is operating perfectly normal and that hasn't been replaced or failed 3 times? Also what does an independent shop that does 5 or so 2nd gen trucks diffs a month have anything to do with a 3rd gen? Are they the exact same diff?
    Tyler
    Tacomamike mike likes this.
  10. Oct 12, 2017 at 10:08 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Anyone have diff failure not related to fluid loss or banging it into rocks on the trail? Has there been a documented failure related directly to noisy diff from either 2nd or 3rd gens?
    If not and many might not like this but you just might end up with a perfectly functional noisy diff.
  11. Oct 12, 2017 at 10:10 AM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Who let you out of the hole?
    Welcome back
    mtip, over60 and smitty99[QUOTED] like this.
  12. Oct 12, 2017 at 10:10 AM
    tedburgundy
    tedburgundy Well-Known Member
    Which dealer?
  13. Oct 12, 2017 at 10:10 AM
    EMT760-
    The way I understand it to be. The lemon law process doesn't require 3 actual attempts at repairing it. Meaning 3 differential have to be put in. The mere fact of you just showing up for 3 different ' attempts'. Notice I say " attempts" if you're able to prove via independent shops that goes against Toyota. The burden of proof relies on Toyota to prove its " normal".
    I mentioned 2nd gens because they have experience with Tacomas.
  14. Oct 12, 2017 at 10:10 AM
    splitbolt
    NW Arkansas
    Without a teardown, it's just some dude's opinion.
  15. Oct 12, 2017 at 10:12 AM
    #35
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    So you can lemon something you don't like even if it hasn't failed?
  16. Oct 12, 2017 at 10:14 AM
    #36
    EMT760-
    Well define " failure" a noise to me indicates a bearing failure or contact pattern that is " not normal". Toyota has never stated why its " normal".
  17. Oct 12, 2017 at 10:15 AM
    #37
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    What if it's gear whine at a certain speed and not related to bearings?
  18. Oct 12, 2017 at 10:15 AM
    #38
    smitty99
    Scottsdale
    If you want to lemon it, I would just get a lawyer and start there. The first thing they'll probably tell you is to stop posting on public forums about it.
  19. Oct 12, 2017 at 10:15 AM
    #39
    Trident904
    Trident904 Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    My diff howled until I upgraded to 265/75/16 E load tires. Now I'm on 35's and it hasn't howled since.
  20. Oct 12, 2017 at 10:17 AM
    #40
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    Or you can't hear it from the howling of the tires.
