LOTSOFTOYS PANDA BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by lotsoftoys, Aug 16, 2011.
  1. Aug 14, 2014 at 7:28 PM
    #861
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Well done sir!
  2. Aug 14, 2014 at 7:29 PM
    #862
    lotsoftoys
    lotsoftoys [OP] pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    panda fab was in full affect today!:cheers:
  3. Aug 16, 2014 at 2:52 PM
    #863
    capturecolorado
    capturecolorado Well-Known Member
    Alex
    Grand Junction, CO
    01 4Runner SR5 with some things attached
    Just gonna drop this link here... :spy: rear disc w/ e-brake
    I talked to the company a while back, they confirmed that this will work with 1st gens. I don't have the email they sent me with the specific differences we'd need to handle for our trucks, but I think it was basically just send them the measurements for the cables and that was about it.
  4. Aug 16, 2014 at 4:46 PM
    #864
    lotsoftoys
    Jace
    Denver
    bunch of crap
    it fits first and second gens??? that's odd. hella expensive too
  5. Aug 16, 2014 at 4:52 PM
    #865
    capturecolorado
    Alex
    Grand Junction, CO
    Yeah, I'm sure incorporating the e-brake bracket into a disc caliper isn't an easy or cheap thing to manufacture. I wish there were a logical way to add a t-case parking brake on 1st gens...
  6. Aug 16, 2014 at 5:10 PM
    #866
    lotsoftoys
    Jace
    Denver
    bunch of crap
    from what ive read, the problem is clearance between the tcase and the cab of the truck. i wonder if someone with a body lift could fit a tcase brake?
  7. Aug 16, 2014 at 5:30 PM
    #867
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    I've seen some inchworm transfer case have an e-brake. But I don't know if the tacoma TC is the same as inchworms. I'll look for the link. is this what you mean Jace?
  8. Aug 16, 2014 at 8:30 PM
    #868
    lotsoftoys
    Jace
    Denver
    bunch of crap
    Eric took some sweet photos of our night run last weekend. deserves to be reposted!!!!
  9. Aug 16, 2014 at 8:31 PM
    #869
    lotsoftoys
    Jace
    Denver
    bunch of crap
    i don't have an inchworm lefty???
  10. Aug 17, 2014 at 5:21 AM
    #870
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah Jace not trying to clutter you build page. I understand you don't have the lefty inchworm. It's the idea of adding the disc and brakes to your existing transfer case but hey you know a lot more about this stuff then I. I just remember seeing an e-brake placed on an transfer case that's all and that's what you mention in your other post. Anyways glad I was able to make the night run with you guys those pics are badass. Did you see the moose pic he posted. Sweet!
  11. Aug 17, 2014 at 9:44 AM
    #871
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ur not cluttering man, good conversation.... but im betting the lefty case is shaped differently on top allowing for a brake to be mounted
  12. Aug 18, 2014 at 9:03 PM
    #872
    lotsoftoys
    Jace
    Denver
    bunch of crap
    so still waiting on a trasharoo from rebel.... obviously i want a hlack one, but black trasharoos are all on back order.... sucks.....
  13. Aug 18, 2014 at 9:19 PM
    #873
    Madjik_Man
    Colorado Front Range
    Jace
    Just reading this page of your build... how do I know if the front to rear braking ratio is proper after installing my lift?
    I only have the Dakars in the rear with shock shackle length. No AAL added.
    I added the BAMF BPV bracket and have it adjusted so that the horizontal cable that runs atop the axle is still parallel to the axle (like it was before the lift).
    My braking feels much different now though. I don't feel as though the front discs are handling most the duty of stopping and I feel as though my stopping power is lessened.
    And I do not have those fancy pressure gauge things that the FSM calls for when checking brakes.
    tl;dr Any advice?
  14. Aug 19, 2014 at 6:42 AM
    #874
    lotsoftoys
    Jace
    Denver
    bunch of crap
    how does ur ebrake hold the truck? how many clicks does it take to pull til it holds?
  15. Aug 19, 2014 at 6:10 PM
    #875
    Madjik_Man
    The e-brake holds my truck better than ever since the lift.
    And I forget the number of clicks but it is in the range per the FSM.
    Just curious, what's your thought process asking those questions diagnosing if my front brakes are receiving enough load?
    Thanks, man.
  16. Aug 19, 2014 at 7:22 PM
    #876
    lotsoftoys
    Jace
    Denver
    bunch of crap
    id say 90% of taco owners rear brakes are out of adjustment, this causes the fronts to work extra hard... just a few questions that came to mind.
    i don't get your question tho exactly... u said u dont feel like ur front brakes are working as great?
  17. Aug 19, 2014 at 7:24 PM
    #877
    Madjik_Man
    When we took the stock rear brake line off to put in the extended one, not a single drop of brake fluid dripped out of the line or out of the BPV thingamabobby. The rear brake line was bone dry.
    Pretty sure my front brakes were working extremely extra hard for years.
  18. Aug 19, 2014 at 7:26 PM
    #878
    lotsoftoys
    Jace
    Denver
    bunch of crap
    thats weird^ when u bled the the rear brakes did u bleed the bpv?
  19. Aug 19, 2014 at 8:03 PM
    #879
    Madjik_Man
    Yeah. Lots of bubbles out of the BPV.
  20. Aug 29, 2014 at 6:04 PM
    #880
    lotsoftoys
    Jace
    Denver
    bunch of crap
    so ive doing alot of of research and cross referencing part numbers and blah blah blah.... kinda seems like i may be a guinea pig for this one tho. poly urethane lower control arm bushings. after talking with Kevin at toytec, he showed me and b.s.ed about his new poly lca bushings and how smooth the front travel and how tight the suspension felt.
    http://www.whitelinesuspensionparts.com/proddetail.asp?prod=W53377A
    after talking with whiteline, they dont list lca bushings for the taco.... but they do offer it for the 3rd gen 4runner. i triple checked the part numbers through work. 3rd gen runner and 1st gen taco lca bushings are the same part numbers, same arms as well... Whiteline told me, if i find out they work for the taco, they will start listing it for the taco..... so.... ordered:D
    IF they do work.... they will be a sweet addition with some shiny new coilovers before moab hopefully
