LOTSOFTOYS PANDA BUILD
Discussion in '1st Gen. Builds (1995-2004)' started by lotsoftoys, Aug 16, 2011.
  1. Jan 23, 2015 at 2:23 PM
    #1021
    NativeTaco
    NativeTaco Mountain Man
    Travis
    Fort Collins, CO
    '08 DCLB
    ARB, OME, BAMF, ATO, Rigid, more... Mountain Man Limousine
    I feel like my truck would do well if you could spend an hour looking at everything underneath to see what I need to do for upkeep. Since this is my first 4x4 that I actually wheel, I am not sure what to keep an eye on.
  2. Jan 23, 2015 at 3:23 PM
    #1022
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    So Mr. Toyota Tech, I went to Toyota today and they didn't have the contact I needed. Since it looked like my plunger was hitting the right side of my contact I picked up the right offset contact to and hoped for the best. I cleaned everything and put it all back together and got nothing, not even a click. I pulled it back off and hooked it up again to see if it would turn over by itself and this time I got a small click (not as loud as with the bad contact) and the brake light would come on and off as I turned the key. Any ideas?
    I think I'm going to put the bad contact back in and see if it turns over then. If so, it means the other right offset contact wont work.
  3. Jan 25, 2015 at 12:23 PM
    #1023
    lotsoftoys
    lotsoftoys [OP] pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    ok so you wanna bring it to me or what r you sayin?
    yeah you gotta have the right ones..... the whole brake light thing, i have no idea what you did? did you disconnect the battery before taking the starter out? did the wire short out on the frame or motor And blow a fuse?
  4. Jan 25, 2015 at 4:57 PM
    #1024
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Yeah I found a few things I put back together in the wrong order on the posts and the alt relay was loose but I still had issues getting a response form the starter. I ended up getting mad at it and turning the key like 15 times really fast and it magically turned over. Now it fires right up everytime haha. No clue
  5. Jan 25, 2015 at 5:50 PM
    #1025
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Fuck me. Pulled the whole locker motor apart, cleaned it, replaced parts...still doesent work. Can't even hear it trying to turn. Seems like the magnet part gets warm when I hit the button a few times. Gonna get a volt tester and try to compare against Andy's locker next weekend...but I'm at a total loss why it doesent work
  6. Jan 25, 2015 at 7:07 PM
    #1026
    lotsoftoys
    Jace
    Denver
    bunch of crap
    thats weird
    u sure you got it back together right? i fucked up the first time too. follow that write up verbatim
  7. Jan 25, 2015 at 7:12 PM
    #1027
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    I had some "expert" help lol.
    Ya we took it apart twice. What did you mess up the first time?
  8. Jan 25, 2015 at 7:16 PM
    #1028
    lotsoftoys
    Jace
    Denver
    bunch of crap
    did u knock out the center piece with the spring on it? i didn't, it spun both directions against the spring. i thought it was good. not. the center piece is supposed to spin WITH the spring.... big difference. also make sure your 3 electrical contacts r touching. also that you timed the center contact piece correctly. the tricky part is i have the factory ecu with light, you just have a switch and relay huh?
  9. Jan 25, 2015 at 7:21 PM
    #1029
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    hmmm. im not exactly sure we tested it close enough with that center piece with the spring. I mean we took it out and cleaned it, but just kind of...put it back on lol. By three electrical contacts you mean the ones that touch the metal surface of the gear?
    ya I just have a relay.
    can you go into slightly more detail about setting the spring right/timing that center contact piece? Like I said we really didnt spend much time on that. then again we never actually took the spring/center piece apart. that whole assembly with the multi direction spring and shaft the drive gear sit on came out together as one piece and we put it back in as one piece.
  10. Jan 25, 2015 at 7:38 PM
    #1030
    lotsoftoys
    Jace
    Denver
    bunch of crap
    it comes out as one piece but should spin. i can tell you didn't follow the write up close enough. i literally had to read it 3 times and go step by step and pay attention to the pictures.
    id find another first gen trd and hook your locker up. see if its the locker or your setup
  11. Jan 25, 2015 at 8:44 PM
    #1031
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    it can be a first or second. It should work on andys, which is what we are going to try next weekend. No i did not follow the write up close enough, and for my sake I hope not. That would mean there's nothing really wrong and we just put it back together incorrectly.
  12. Jan 26, 2015 at 5:29 PM
    #1032
    lotsoftoys
    Jace
    Denver
    bunch of crap
    ordered some black round rubber things today:D
  13. Jan 26, 2015 at 5:41 PM
    #1033
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Did you get the same one's or trying something else?
  14. Jan 26, 2015 at 6:05 PM
    #1034
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    they better end with a 5 :p
  15. Jan 26, 2015 at 6:06 PM
    #1035
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
  16. Jan 26, 2015 at 6:17 PM
    #1036
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    LCA bushings again? :D
  17. Jan 26, 2015 at 6:43 PM
    #1037
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Dilduhs?
    Wrong forum
  18. Jan 26, 2015 at 7:35 PM
    #1038
    lotsoftoys
    Jace
    Denver
    bunch of crap
    trying new:) If they fail me, im going back to duratracs though
    nah not this time man. I don't wanna have to regear. 285's for me...
    hell no, I don't ever wanna do those again.
    pm inbound for a good time ;)
  19. Jan 26, 2015 at 7:52 PM
    #1039
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    Can I get a pm also?!
  20. Jan 26, 2015 at 7:58 PM
    #1040
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    I'm not sure he ordered the double ended one, might be sloppy seconds :eek:
    I need tires for Moab also. Was thinking 255s for the Taco, or the Taco gets the 4runners sloppy seconds if they come out with those 34x10.5r17 soon. BFG needs to get that size on the presses.
