Loud chirpy squeal in cold or wet weather
Discussion in '1st Gen. Tacomas (1995-2004)' started by TXBean, Feb 29, 2012.
  1. Feb 29, 2012 at 1:25 PM
    TXBean
    TXBean [OP] New Member
    San Antonio
    2002 Tacoma PreRunner
    Ever since I've had my truck, it's made a persistent loud, high-pitched squeal but only in cold or wet weather, and only when in motion. It sounds like it's coming from underneath the truck. It otherwise runs like a champ and drives very well. The sound doesn't happen when it's warm & dry at all. I'm hoping for some ideas before I take it in for next service, especially since I never know when they'll be able to reproduce the noise.
    Thanks!
  2. Feb 29, 2012 at 1:26 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    prob a belt
  3. Feb 29, 2012 at 1:28 PM
    rdd11
    rdd11 Well-Known Member
    Ross
    Red Deer, AB
    08 TRD Double Cab long box black
    K&N cold air, Exhaust
    Maybe just ice/ water build up causing unwanted friction? Mine does this too it's a 2 gen but never effects how it drives. Maybe even a wheel bearing who knows that seems to be how that stuff goes makes the sound when you ant do anything and won't do it at the time you want it too maybe spray water under it and see if you can recreate ye noise
  4. Feb 29, 2012 at 1:29 PM
    rdd11
    Ross
    Red Deer, AB
    Could be a belt too they shrink in the cold which would make it squeal check of its cracked or worn
  5. Feb 29, 2012 at 1:31 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2003 T4R SR5 V8 4wd
    None
    I had this same problem and it turned out to be my center carrier bearing. Get underneath your truck and push upwards on your drive shaft. If it has more play then you think it should then that is your problem.. If not that then check your U-joints and make sure all caps are sealed and solid..
    He says it does it only in motion.. So that would cancel out the belts..
  6. Mar 29, 2012 at 2:50 PM
    mudpuppet
    mudpuppet Must pay wife for safe passage
    Mark
    Somewhere between where Arizona blows and Texas su
    Lunar Mist Metallic 03 Taco, X-CAB 4X4 TRD
    American Racing 16X8 Bully Nerf Bars, Toytec 3" w/ Eibach Coils 5100's, Dakars, Poly steering bushings, billet x-cab window latch, XM, trenz billet upper grille, billet lower grille, TRD Skid Plate
    Just stumbled on this topic post. I have an 03 X-CAB 4X4 and experienced high pitch squealing every winter while the truck was in motion. Secondly, the squealing only occured when I was not touching the gas pedal. I added some grease the each of the U-joints with zerk fittings and the problem went away a day or so later. Might be something to try.
  7. Mar 30, 2012 at 3:39 AM
    Vincetreking
    Vincetreking Vincetreking
    97 4+4 Taco
    Stock K&N filter
    My 2.7L 96 does the same thing after
    some time I found makers around the
    cover where the harmonic Blancer was
    Walking into the engine.
  8. Nov 7, 2012 at 5:41 PM
    bill-e-boy
    bill-e-boy new and improved
    billy
    florence
    04 dbl cab lifted pre-Runner
    added factory roof rack, factory skid plate, removed cheesy running boards, built a pvc bike rack, added interior floor lighting, added decal plate under rear window, added sylvania silverstars, installed toytec ultimate 3" lift, added hella optilux yellow fog lights, added orange park lights to the turn signals, new 265/75/16 goodyear duratracs tires and raceline rockcrusher 16" wheels
    i have the same problem....high pitched chirping squealing on deceleration only in cold weather around 40 degrees outside or colder....only occasionally in wet humid weather.....had the belts pulleys checked by toyota ...all in spec they say....had another mechanic check, they said they "tightened the belts"....squeal seems even worse now.....any ideas of what to check...pleeeeease help!
  9. Nov 8, 2012 at 4:16 AM
    bguenth17
    bguenth17 Member
    Brian
    Baltimore
    '97 Tacoma
    You can also check the speedometer. Mine did the same thing for about 2 years, then when it started making the noise the spedo would just bounce from 20 to 110. I just greased the one fitting on the spedo line and it never chirped or bounced around again.
  10. Nov 8, 2012 at 9:03 AM
    rzgkane
    rzgkane Well-Known Member
    Huntington Beach, CA
    2000 Tacoma X-Cab PreRunner 2.7 Auto
    I just had my driveshaft (2000 PreRunner 2.7L) refurbished to solve a squealing/chirping noise I was having on deceleration. Sounded like it was dead center underneath the truck. Replaced both front and rear u-joints and the center support bearing and all is well again.
  11. Nov 8, 2012 at 3:56 PM
    Zork
    Zork Well-Known Member
    CA / KY
    04 PreRunner V6 D-Cab
    Alpine CDA-9885
    I had the same problem until I replaced both U-joints like ^^^^. It was quite annoying & embarassing.
  12. Nov 8, 2012 at 5:30 PM
    bill-e-boy
    billy
    florence
    turned out to be a "slip yoke" on the driveshaft needed greasing...apparently it was puuuuurdy dry....
