Loud clunk when the 4WD disengages
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grutzmac, Oct 25, 2009.
  1. Jan 21, 2014 at 4:41 PM
    DelinquentTaco
    DelinquentTaco Active Member
    Colin
    '11 4x4 TRDOFFROAD
    TRD cat-back,TRD CAI,TRD quick shifter,N-fab lightbar & 2 Hella 700ff,AirHorn&compressor&2gal tank, LowRange Offroad leveling kit 3"and1", XDSeries Badlands Chrome 18x9, 285/65/r18 Nitto TrailGrapplers
    ^^^^ hes right. in my 2011 ive used 4WD a lot and if you disengage it on a hill, where a load is being put on the gears, it will make a clunk. ive had it happen several times, and it still goes good as new.
    Alexely999 and ticaz like this.
  2. Jan 21, 2014 at 4:51 PM
    addicted7369
    addicted7369 She Thinks My Tacoma is Sexy
    Al
    Middlesex County, N.J.
    06 Tacoma Sport DCSB 4X4
    Toytek 3" ultimate lift Billstein 1500 coilovers, and Light Racing UCA's with AAL in the rear, Mickey Thompson classic lock III rims with color matched powder coated color rings,with 285/75R16 General Grabber AT2 tires led tail lights , T-Rex Billet grill, HID reverse lights, FLYZEYE V2W led lights, throttle body spacer, and K&N air filter, Kenwood head unit, Rockford Fosgate punch 6 1/2" speakers, 6x9 Rockford Fosgate punch speakers,1 inch Rockford Fosgate prime tweeters, 5%tint all around, CBI rock sliders, Cobra 19 CB with 3' firestik antenna, 6 1/2" lightforce 170's behind grill, redline elite hood struts, retro fit HID projector head light with halos and demon eyes, weather tech floor liners, led interior lights, truxzedo low profile bed cover, rear diff relocation mod, anytime fog light mod.
    Mine only made a loud clunk once and that was a couple of weeks ago when it was like 5 degrees out and I just started the and had forgot to take it out of 4hi and when I did it clunked pretty loud.
    :burnrubber:
  3. Apr 18, 2016 at 5:31 PM
    UBYBC
    UBYBC Well-Known Member
    2014 Tacoma TRD OR
    Mine clunks when disengaging 4H to 2WD. I usually stop and go to neutral then turn the switch. 50/50 on whether I get a clunk or not.
    DrFunker likes this.
  4. Apr 19, 2016 at 10:14 AM
    CroResident
    CroResident Well-Known Member
    Nick B
    Opelousas, Louisiana
    2015 4X4 DCSB
    6" Zone lift 35x12.50 Super Swampers
    i bought my 2015 brand new and it clunks coming out of 4hi to 2hi almost every time. its more of a clack than a clunk though
    Alexely999 likes this.
  5. Apr 19, 2016 at 10:26 AM
    eon_blue
    Azusa, CA
    My '04 does it too...I wouldn't call it a "loud" clunk but it's definitely noticeable, doesn't sound bad though so I never worry about it.
  6. Feb 14, 2017 at 10:29 AM
    ticaz
    ticaz Well-Known Member
    Dan
    2010 Timberland Mica DCLB 4x4
    After a little searching I found this thread, as I accidentally caused this to happen today in my truck. My driveway has a pretty steep incline, and living in snowy Northern Ontario, I often have to shift into 4hi to reverse up my driveway.
    Today we had some wet slippery snow fall, and my truck wasn't making it up in 2wd. So, I switched it not 4hi. The switch into 4x4 is usually seamless, with just a light click, today, for whatever reason there was a bit of a delay, and as I was easing up the hill, my rear tires started to spin at the same time the transferase engaged resulting in a pretty loud thunk and slight jarring of the truck. 4x4 engaged fine however, and made it up my driveway. Engaged and disengaged a few times to make sure everything was still working once parked (seems ok). Will be doing a t-case oil change soon, be interesting to see if there are any metal chips or shavings in the drained oil. I suspect everything will be fine, but it's always a little disconcerting when something like this happens.
    From what I have read on this topic, it appears this may happen on occasion without causing harm, but best to avoid this scenario if possible due to the added stress on components.
    CroResident likes this.
  7. Feb 14, 2017 at 11:23 AM
    CroResident
    Nick B
    2015 4X4 DCSB
    my 2015 hardly ever engages into 4hi unless im rolling at least a little bit.
    i have a friend who only engages 4hi at a dead stop
    but my truck usually always makes the "clunk" going from 4hi to 2hi
  8. Feb 14, 2017 at 11:23 AM
    Pabloeeto
    Pabloeeto Well-Known Member
    Paul
    San Diego
    06 DCSB TRD Sport 4x4
    K&N filter, 3.5 Aux input mod, Fox 2.0 Coilovers, Fox 2.0 Resi Shocks, Element UCAs, Old Man Emu Dakar Leaf pack.
    Mine does it as well, not every time though, sometimes i'll go from 4H to 2H and no bang. Other times i'll be stopped, then start rolling then "Bang" disengage.
    DrFunker and CroResident like this.
  9. Feb 14, 2017 at 11:24 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    This truck shakes and clunks so much I just assume its normal at this point.
  10. Dec 22, 2017 at 2:55 AM
    rothy3652
    rothy3652 Member
    2017 DCLB sport
    I have been using my dclb sport like this since new. I am just wondering if synthetic gear lube or an additive like Lucas would help with the transfer. My truck is a 15 with 40 k and has done this since new.
  11. Dec 22, 2017 at 10:00 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Maybe 1 out of 10 times it'd make a clunk when coming out of 4WD which is normal, just means thing got bound up and are releasing like a spring when it comes out of 4WD. How often does it happen OP? if you engage and then disengage while driving in a PERFECTLY straight line for a bit does it do it?
  12. Dec 22, 2017 at 10:23 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Bought my 15 brand new. Makes a quiet clicking noise going INTO 4wd. Going back to 2wd I get a loud CLUNK. I’ve always known it to be normal.
    tacocart762 likes this.
  13. Dec 22, 2017 at 10:24 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    You read my mind.
  14. Dec 22, 2017 at 11:52 AM
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    o_O OP hasn't been around since 2010.
  15. Dec 22, 2017 at 12:18 PM
    #35
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    probably driving a Nissan Frontier by now.
  16. Dec 22, 2017 at 1:00 PM
    #36
    andrew61987
    Damn necro threads
    bobsuruncle[QUOTED] likes this.
  17. Dec 22, 2017 at 2:02 PM
    #37
    Foozer
    Foozer Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    2012 here, I have the clunk as well when coming out of 4wd
  18. Jan 8, 2018 at 9:47 AM
    #38
    CroResident
    Nick B
    2015 4X4 DCSB
    its a pretty loud clunk and i can feel it as well as i can hear it. after 3 years of driving this thing i still havent gotten used to hearing that dam noise
  19. Mar 30, 2019 at 6:59 AM
    #39
    hesty
    hesty New Member
    2006 Tacoma
    none
    I'm running General Gabbers AT2 265/70r17 on my stock 06 4x4. Excellent rubber. I have never ran BFG's on my truck, but I can always tell when someone on the highway is running them coming up beside me cuz those BFG's are loud! That's what sold me on Grabbers. Someone reviewed them stating they have run both BFG's and Grabbers, and reported a huge difference in noise.
    As far as the loud thud that I can also feel, I get that too, and I always feel like I'm gonna jack up something. I think that I have gotten it out once without a thud. I have tried many things, but I'm gonna follow the "give it some acceleration, let off, and take it out of H4" on my next go. Anyone found a round about speed that the taco likes coming out of H4?
  20. Mar 30, 2019 at 7:56 AM
    #40
    billthehiker
    billthehiker Well-Known Member
    I sometimes get quiet disengage by driving up gentle incline at a crawl, 1-3 mph, with just a bit of power. But not totally consistent .
