LOUD HUMMING NOISE AT 40mph, what is it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by copdude33, Mar 2, 2010.
  1. Mar 2, 2010 at 12:40 PM
    copdude33
    copdude33 [OP] Well-Known Member
    Roxboro, NC
    2010 Tacoma Sport 4x4 magnetic gray
    I just got a 2010 4x4 double cab with automatic transmission v6. At about 350 miles I have started to notice an annoying whine or humming sound at about 40 mph. It goes away at higher speeds but when I let off the gas and it comes back down to 40mph the sound comes back. WTF is it? Is this common or am I hearing things?
  2. Mar 2, 2010 at 2:12 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    I have no whinning noise, duratracs i installed humm ever so slightly
  3. Mar 2, 2010 at 3:40 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    Go to your dealer and test drive another one just like yours.
    If that one makes the same noise then maybe they all do it.
    If it doesn't, then it's time to take it in and have it fixed or explained.
    I haven't noticed any noise like that in mine yet.
  4. Mar 2, 2010 at 4:13 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    Nittos:p
  5. Mar 2, 2010 at 5:32 PM
    HARDSHELLTACO
    HARDSHELLTACO HoofHearted
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    It might be the engine braking. I thought the same thing when i first drove mine. Now i don't even notice it.
  6. Mar 2, 2010 at 5:41 PM
    copdude33
    Roxboro, NC
    What is engine braking? So yours made the same noise at 40?
  7. Mar 2, 2010 at 5:42 PM
    copdude33
    Roxboro, NC
    What's engine braking? So yours made that noise at the same speed? I thought at first it might be the wheel bearings
  8. Mar 2, 2010 at 5:53 PM
    HARDSHELLTACO
    McLovin
    BOWLING GREEN, KY
    06 Tacoma
    From what i understand it was designed to make the automatic perform more like a manual transmission. Some also call it downhill assist or downhill braking. The first time i really noticed it was when i was driving in a funeral procession. We stayed at about 35 mph for about 10 miles and it drove me nuts. You can probably search and find out more!
  9. Mar 2, 2010 at 6:11 PM
    silvertaco82
    silvertaco82 No way, get real
    Bozeman, MT
    2010 AC TRD Sport 4x4
    TRD Seat Covers, Weathertech floor mats, Sockmonkey Decals, Pro Comp 6", 35" Nitto Trail Grapplers, 18x9 XD addicts, 20% tint, Kenwood Dnx 5120, 2 10" Kicker Shallow mount subs
    my truck just started making a hum/vibe at around 35mph
  10. Jun 27, 2010 at 2:32 PM
    Jpwarrior
    Jpwarrior Active Member
    Justin
    Alameda
    06 DC TRD 4x4 Silver
    Undercover classic
    06 4x4 with 80,500 miles. Mine has made the same noise for as long as I can remember. Its called "critical speed". Critical speed is when you get a machine at a certain RPM or Speed, the harmonics of all the rotating parts put out "tones/vibrations". When they all merge together it can make a noticable sound. Im my case it sounds like I am running down the street with mud tires on. The key here is to make sure it does not get louder over time. Also keep up with your regular maintenance with all fluids and grease the u-joints and drive lines if applicable. These will act as dampers for the vibrations keeping the noise and normal wear down.
  11. Jun 27, 2010 at 2:39 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Carrier bearing?
