Loud Noise while running A/C, Please help
Discussion in '3rd Gen. Tacomas (2016+)' started by jquest, Jul 6, 2018.
  1. Jul 6, 2018 at 12:29 PM
    jquest
    jquest [OP] Well-Known Member
    Los Angeles
    2016 Tacoma SR5 4x4
    There is a loud rumbling noise under the glove compartment. It stops when I turn off the A/C. Suddenly my A/C does not blow anymore air. Whats going on?! I need my A/C its burning hot here Thanks
  2. Jul 6, 2018 at 12:30 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Blower wheel is most likely cracked, it is a known problem and I believe parts are on backorder
    siznarf likes this.
  3. Jul 6, 2018 at 12:57 PM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Stockton
    2000 4runner
    91 Octane
    Yup. What he said.
    Open glove compartment, remove everything including dildo (there’s a story to this), open cabin air filter compartment and check blower fan. Most likely broken.
  4. Jul 6, 2018 at 1:05 PM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    Wtf are these blowers made out of? Why so fragile?
  5. Jul 6, 2018 at 1:15 PM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NWA (Arkansas)
    2017 TRDOR 4x4 DCSB MT
    BROG molle headrest covers, GMRS & Ham radios with roof-NMO discreet antenna, front/rear dashcams, DMM
    You can use a little hose clamp temporarily (or permanently) to hold the fan hub together until the warranty work is done. Just make sure to slowly increase the fan speed. The torque of the electric motor when starting on high is too powerful on the hub of the fan before the plastic can combat the inertia of the outer rim and blades, especially when left on high before starting vehicle. Most newer manufacturers added a speed lag regulator when starting any A/C blower motor. There are many other ways to rectify the issue, such as better materials, metal hub, more flexible plastic, etc.
  6. Jul 6, 2018 at 1:27 PM
    KellyJoe
    KellyJoe Well-Known Member
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    Just did this 2 days ago.... Three screws to pull it / drop it from under the glove box and some high strength epoxy to hold it until the replacement gets here. I'm talking glued to the shaft! :thumbsup: I'll probably just ride the epoxy and keep the new as a spare if it gives up again.... It's holding great with many torture test cycles.
    With the three screws out and blower dropped, unplug it and the plastic outer shroud with the wires attached stays with the truck and the motor and fan come out easy for gluing it up. If you do this just have the fan facing down while drying so any epoxy drippings don't go into the motor.
    Link for what I used but Advance Auto Parts sells it too.
    https://www.amazon.com/Permatex-84107-PermaPoxy-Strength-General/dp/B000HBNV30
    '16goingon'17 likes this.
  7. Jul 6, 2018 at 4:08 PM
    jquest
    Los Angeles
    2016 Tacoma SR5 4x4
    They dont just sell the plastic wheel? I called toyota and they said they only sell with motor attach
  8. Jul 6, 2018 at 6:05 PM
    JHFMX
    JHFMX Well-Known Member
    2016 BBP Tacoma Double Cab Longbed SR5
    I had this issue and it turns out there was just a leaf in my cabin filter. It was a ten second fix. Good luck
  9. Jul 6, 2018 at 6:07 PM
    KellyJoe
    Kelly
    Victoria, TX
    '17 TRD Sport DCSB
    That's right and there's a national back order because of their cheap ass bullshit. Do the epoxy. Trust me. It works. :thumbsup:
