Loud pop after taking truck out of 4x4
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jfuent268, Jun 14, 2012.
  1. Jun 14, 2012 at 3:05 PM
    jfuent268
    jfuent268 [OP] Member
    Yuma, AZ
    07 SR5 4x4
    I just bought my 2006 Tacoma SR5 4x4
    I had never had a 4x4 so i decided to go try it out.
    Everything was fine until i heard a loud pop as i was leaving.
    I stopped, put the truck in Neutral and put the truck back into 2wd.
    As i went in reverse the truck made a loud pop (i am pretty sure it was not suspension). then i put the truck in drive and drove off, everything was fine.
    I checked the truck as i got home and everything seems fine..
    Any suggestions as to what might have happened???
    Thanks
  2. Jun 14, 2012 at 3:09 PM
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    It's normal if it was more like a clunk sound and I hope you weren't driving around on pavement with your truck in 4wd.
  3. Jun 14, 2012 at 3:10 PM
    aaronbuell
    aaronbuell Well-Known Member
    aaron
    windsor NY
    09 TRD/OR Access Cab V6 debadged
    Fog-light anytime mod, ,black grill,URD short throw,TRD decals removed ,debadged,black rear bumper, homemade tire carrier,TreadWright tires,Evo mod,removed rear headrests and seats,ABS kill switch mod,black center caps,Clarion CX501 head unit,Relentless hood brackets with floodlights.
    It was your front end disengaging after turning off the 4 wheel drive.
  4. Jun 14, 2012 at 3:48 PM
    TRD6Speed
    TRD6Speed senior member
    Bill
    East Hartford, CT
    08 TRD Sport Access Cab
    885x with 5100s and top plate spacer for full 3", RCD extended 5100s in rear, dakars, flip kit, LR UCAs, tint, shorty antenna, in channel rain guards,BHLM, blacked out emblem, OEM side steps, weathertechs, debadged, rear diff breather
    Ya just the 4wheel disengaging........def caught me off gaurd and it doesnt always do it......sometimes worse than others.
  5. Jun 15, 2012 at 10:16 AM
    jfuent268
    Yuma, AZ
    07 SR5 4x4
    Thanks everyone!
  6. Jun 15, 2012 at 10:31 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    X2 on this, does it sometimes and its sometimes louder then other times! Very normal! Enjoy that 4x4! ;)
  7. Jun 15, 2012 at 2:48 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    The more you use it the smoother the transition into and out of 4x4.
  8. Jun 15, 2012 at 3:06 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    You don't need to stop when going from 4H back into 2WD. The only time you need to stop (and shift into neutral) is when going into and out of 4L. When disengaging from 4H back into 2WD take your foot off the gas...then turn the knob to 2WD. Doing it that way will avoid the "clunk" noise by taking the stress off the driveline... usually disengages smooth as butter.
