Loud Pop While Turning Sharp
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fmsvandal, Feb 4, 2011.
  1. Feb 4, 2011 at 1:27 PM
    Fmsvandal
    Fmsvandal [OP] Well-Known Member
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Toytec Ultimate 3" Lift, Light Racing UCA's, N-Fab Steps, Black Headlight Mod, Satoshi Thin Lip Grille, Painted Hood Scoop, Debadged, Bakflip G2 Cover, Pop/Lock, Alpine HU, Kicker Door Speakers, RE Audio Subs, Arc Audio Amps
    So recently when making a really sharp turn, i hear a LOUD pop/clunk sound that seems to be coming from my front end. Anybody have any ideas?
  2. Feb 4, 2011 at 1:36 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    I have one but its when I start going slow from a stop then apply the brakes. I know people say floating brake pads and I used to hear that sound now the sound is hugely increased so my thought a wheel bearing but that doesnt help you lol
    When did you install the lift? Have you re-torqued all the components you replaced?
  3. Feb 4, 2011 at 1:37 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Mine does that occassionally. Only at full lock.
  4. Feb 4, 2011 at 1:39 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I think there is metal on metal contact on the knuckle at full lock just like the old Toyota trucks.
  5. Feb 4, 2011 at 2:09 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    Spring shifting in the plate? Bad strut top? Bad ball joint? Or are you saying when You're at steering lock and moving (like in a parking lot) you hear it. Most cars have turn stops which are almost always metal to metal.. but the grind more than pop.
    On my OLD tacoma, the a/c would drip onto the sway bar/stabilizer bar and cause the rubber bushing to chatter. So you could actually get out of the car and rock it back and forth and get a "pop pop pop" every time it rocked. Pretty loud since it was right at your foot.
    Was fun trying to get them to diagnose that... "it makes a loud pop on hot days whenever I turn left." Take the service guy for a ride, he'd hear it, then the tech would "could not duplicate customer complaint".
  6. Feb 4, 2011 at 2:16 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    It's the CV shaft. There's about a 1/4" play in it. At least on my truck I'm pretty sure that's what it is.
  7. Feb 4, 2011 at 2:39 PM
    Fmsvandal
    David
    Ormond Beach, FL
    09 DC/LB TRD Sport
    Lift was installed Nov 09 and yes.
  8. Feb 4, 2011 at 2:43 PM
    08pretaco
    Oliver
    az
    Does he have a cv shaft :p
  9. Feb 4, 2011 at 2:46 PM
    A7XTaco
    A7XTaco Member
    Bryan
    Austin, TX
    You don't want to know...
    What he said^
    Mine does it too... PreRunner here.
    Look under the truck from the front by your wheel, you will see the contact point, thats what makes the noise.
  10. Feb 4, 2011 at 4:49 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    Probably oversteered your u-joints and destroyed your ears on the shafts...
    OH WAIT THATS THE SOUND ON SAS TRUCKS :D lol
    Not so funny... there goes $600 for me :(
