Loud popping noise and creaking while steering
Discussion in '2nd Gen. Tacomas (2005-2015)' started by spazjensen, Sep 24, 2012.
  1. Sep 24, 2012 at 11:00 AM
    spazjensen
    spazjensen [OP] Well-Known Member
    Here
    06 Tacoma Prerunner SR5 4cyl 5spd Manual
    3" lift with Biltein 5100's w/Eibach Coils, SPC UCAs
    2006 Prerunner 2WD. When turning i get a loud pop noise, like metal on metal popping and clanking. Its gotten progressively worse and now so bad that i can feel whatever it is hitting in the steering wheel everytime i turn. I keep searching but find nothing that fits exactly what i have going on. Hoping maybe someone can give me an idea or show a past thread of this samething being discussed. Thanks.
  2. Sep 24, 2012 at 5:07 PM
    hakabo
    hakabo Well-Known Member
    Jacob
    Concord, NC
    08 urban runner 4x4
    im a complete mechanical retard, but if you could lift it and have someone look at the wheels while you are turning to see if anything binds?
  3. Sep 24, 2012 at 5:33 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  4. Sep 24, 2012 at 5:36 PM
    DunhamAll
    DunhamAll Well-Known Member
    Jordan
    Baltimore, MD
    '12 Access cab, MT, TRD OR
    Rear diff. breather, BHLM, Wet Okoles.
    Probably correct. Bad ball joints sound like an old wooden door with iron hinges being opened after 20 years.
  5. Sep 24, 2012 at 9:26 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    Check your control arm bolts, they might be loose.
  6. Sep 25, 2012 at 5:45 AM
    spazjensen
    Here
    I took to a shop and they put it on the alignment lift and checked everything. they said the front end was all tight and my ball joint were okay, no movement in them. I talked to another shop that deals with offroad rigs a bit and they told me that it probably has to do with the steering system. Said if could be the rack and pinion, steering box/gear, or the steering shaft, or the bushings holding the rack and pinion. I first thought it was my ball joints but the shop people said it was definitely not that. It only happens when the truck is running and i am steering while either sitting still or moving slowly, say about 5-10 mph, and if its anymore than 1 full turn of the steering wheel.
    Also, i should add that this started a few weeks ago right after I got the alignment done on it. Like the day after. I took it back, they said they couldn't find what was making the noise. Needless to say, I won't be going back to them. Using a different shop.
  7. Sep 25, 2012 at 5:59 AM
    spazjensen
    Here
  8. Sep 25, 2012 at 6:17 AM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    MY BALL JOINT WAS TIGHT AND WAS SQUEAKING LIKE HELL WHEN TURNED
    IDK....GOOD LUCK
    CHECK LCA BOLTS
  9. Sep 25, 2012 at 7:25 AM
    spazjensen
    Here
  10. Sep 25, 2012 at 7:31 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    CORRECT ^^^^
  11. Sep 25, 2012 at 7:32 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    YOU CAN JACK UP THE TRUCK AND USE A CROW BAR OR LARGE SCREWDRIVER AND TRY TO WIGGLE THE BUSHINGS....
  12. Sep 25, 2012 at 7:33 AM
    Large
    Large Red
    WHY ARE YOU YELLING?
    TrdAaron and Byb127 like this.
  13. Sep 25, 2012 at 7:38 AM
    spazjensen
    Here
    I pLan oN cHeckINg ThiS oUt laTER thiS aftErnOon. Any play in ball joints again, and the LCA joints. If its neither of these I'm at a loss. Thanks for the help!
  14. Sep 25, 2012 at 7:41 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    if you have nothing of use to add to op's thread please keep your coments to yourself...thank you and have a great day
    thats a great start remember no one loves your truck as much as you do....
    no one will take the extra steps that you yourself can take....plus you learn a lil more all the time....
    its true u do learn something new everyday
    keep us posted
  15. Sep 25, 2012 at 7:41 AM
    spazjensen
    Here
    One other question:
    If it is my cam bolts will i be able to tighten them up without messing up my alignment? I'm pretty much useless when it comes to the "how-to" of camber and caster adjustments.
  16. Sep 25, 2012 at 7:44 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i belive the cam bolts should be at 100ft lbs
    but dont quote me on that....
    it couldnt hurt as if is the case your alingment is moving around as you drive..
    could also be the start of seized cams / worn bushings ect.....
    try one thing at a time and you will find out what it is......process of elimantion
  17. Sep 25, 2012 at 7:44 AM
    spazjensen
    Here
    Its all good man. I enjoy humor on forums.:) otherwise they're boring.
  18. Sep 25, 2012 at 7:49 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    What UCA are you running?
  19. Sep 25, 2012 at 7:56 AM
    spazjensen
    Here
    Stock right now. but trying to wait til xmas time to get new ones. found some i want that have 2 degrees adjustment in the control arm, if not those maybe T-Chaos or something else. I have verified that the stock ones are still good and have not given out yet.
  20. Sep 26, 2012 at 6:06 AM
    spazjensen
    Here
    Checked it out yesterday....turned out to be the front bolt on the LCA on driver side. So thankful its not my ball joints. Gonna call the alignment shop i took it to and bust some balls. Thanks guys.
