Low beam bulb number?
Discussion in 'Lighting' started by Tacolady00, Nov 1, 2017.
  1. Nov 1, 2017 at 9:23 AM
    Tacolady00
    Tacolady00 [OP] Active Member
    Karen
    2017 Toyota Tacoma TRD Off-Road
    Grill hood predator bars taillights
    what is the bulb number for low beam in 2017 Toyota Tacoma off road
  2. Nov 1, 2017 at 9:25 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    H11
    tcBob likes this.
  3. Nov 1, 2017 at 9:25 AM
    Tuh-coh-mah
    Tuh-coh-mah Huh?
    Caluhferneeah
    17MGMTRDORDCSB4WDAT
    TRD catback, BAMF sliders, lots o trail stripes
    From the manual:
    Headlights
    Low Beam H11
    High Beam H9
  4. Nov 1, 2017 at 9:26 AM
    Siblue
    So Cal
    25 Tundra TRD pro
  5. Nov 1, 2017 at 9:27 AM
    Tacolady00
    Karen
    Ok crap. I thought that was fog light. Ok. What is the fog light bulb number then :(
  6. Nov 1, 2017 at 9:29 AM
    Tuh-coh-mah
    Tuh-coh-mah Huh?
    Caluhferneeah
    17MGMTRDORDCSB4WDAT
    Also H11
  7. Nov 1, 2017 at 9:32 AM
    Tacolady00
    Karen
    Sweet. Thanks so much. And I am going with xenondepot as we speak. Thank you thank you
  8. Nov 1, 2017 at 9:40 AM
    Siblue
    So Cal
    25 Tundra TRD pro
    For fogs OEM Lexus LEDs are the best.
  9. Nov 25, 2020 at 12:25 PM
    ibicycle2
    ibicycle2 Member
    Iowa
    2018 Tacoma TRD OR
    475X70X17 - 4.88 gears
    Can I use H9's as low beam. Will they have same pattern, only brighter? I think I have read somewhere that there are two tabs that have to be shaved off the H9's and they will fit?
  10. Nov 25, 2020 at 4:04 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Everything you could want to know on the subject here:
    https://www.tacomaworld.com/threads/3rd-gen-hid-vs-led-vs-halogen-h11-projector-headlights.589465/
    Check out post #2, if using an H9 swap the Philips H9 is the recommended option. They will be much brighter and you only need to trim one internal plastic tab on the bulb to make it fit.
    ibicycle2[QUOTED] likes this.
