Low Coolant Warning? 07 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SubFrozen, Oct 21, 2009.
  1. Oct 21, 2009 at 8:19 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    3" OME Heavy Duty Lift, 18" Chrome Rimes, ARB Front Bumper, K&N Cold Air Intake
    Someone with a Manual - is there a Low Coolant Warning light in a 2007 Tacoma?
  2. Oct 21, 2009 at 8:20 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No mention of it in my manual. Give me some time, and I will go see if there is an idiot light somewhere on the dash....
  3. Oct 21, 2009 at 8:42 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    i dont have a standard, just curious about this thread...low coolant as in antifreeze correct?
  4. Oct 21, 2009 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DOH!!! I thought he meant "Manual" as in Owners Manual.....:eek:
  5. Oct 21, 2009 at 8:46 AM
    gupster88
    Brett
    Almost Heaven
    STOCK 4 NOW
    wait he might mean that, what would having a manual transmission have to with coolant? hell i dont know...i was just wondering that wouldnt your engine running hot or hotter than normal suggest you have low coolant? thus your temperature gauge may in way be pre-warning to low coolant
  6. Oct 21, 2009 at 9:32 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    I meant an owners manual. Low coolant is antifreeze. I have an Automatic.
  7. Oct 21, 2009 at 9:44 AM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    Not sure about the Tacoma, but my '84 Celica had a sensor that shut the motor off when it was low on antifreeze/coolant.
    One freezing cold morning on the way to work, the top of the radiator blew off. The engine shut down almost immediately.
    After I replaced the radiator, the car wouldn't start until I refilled the system.
    Marc M
  8. Oct 21, 2009 at 11:31 AM
    SubFrozen
    SubFrozen [OP] r00t
    William
    Sandy, UT
    2007 Taco SR5 V6
    My motor did shut off... at 275 degrees ;-)
    I drove it for half an hour, or, 24 miles with no fluid. The gauge showed normal running temperature the entire time.
  9. Oct 21, 2009 at 11:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I just check my gauges as well as I could, and there is no low coolant warning light.
