Low coolant?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by YoterHead, Feb 20, 2010.
  1. Feb 20, 2010 at 10:05 AM
    YoterHead
    YoterHead [OP] Well-Known Member
    Is the coolant supposed to be read when it's hot? The pictures below are cold reads, but even when its hot it doesn't seem that much higher, maybe slightly above the low mark. I have 45000 miles on my truck, and wasn't planning on flushing the coolant until 60k to 100k.
    Should I go buy some coolant from the dealer and top it off? Have them pressure check it? Does this seem normal for our trucks?
  2. Feb 20, 2010 at 10:33 AM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    get a bottle and fill it up to the full mark.
  3. Feb 20, 2010 at 10:44 AM
    eight3one_offroad
    eight3one_offroad Honey your two French Fries short of a Happy Meal.
    Richard
    Santa Cruz, California
    TRD Sport 4x4 with a few things.
    Optima Red Top 34R, OME 885 / N140S + 5100 rear, TSB leaf pack, Camburg Ball Joint UCA, Wheelers Diff drop, AEM Brute Force Intake with filter wrap, Summit Super Turbo muffler, Llumar 5% tint, Pioneer single din head unit, PIAA 510 Ion Crystal Fogs in stock location, Sonar LED tails. Sway Bar removal. Charcoal filter delete. Stant 11509 Locking Gas Cap.
    Get that topped off dude before its too late...
  4. Feb 20, 2010 at 10:52 AM
    YoterHead
    I'll go out and buy a gallon to fill it up. Is it normal for the coolant to go down over time, or am I leaking?
  5. Feb 20, 2010 at 12:19 PM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    Don't mix any just old coolant with the pink toyota long-life stuff. If you're going to be changing it soon and it's not too cold where you are, I'd top it off with distilled water and go buy the toyota LL stuff. It's not normal for the level to drop, so that coolant is going somewhere. Hopefully just a loose hose connection somewhere. You should have it pressure tested so they can find where the leak is coming from.
  6. Feb 20, 2010 at 3:49 PM
    YoterHead
    I'm just about to go top it off. Hopefully you're right about this just being a loose hose or something. My S-10 I traded to get this had a leaky radiator that made me fill it up like every week.
    I'll probably get it pressure tested this week sometime. Dealer best place to do this?
  7. Feb 20, 2010 at 4:00 PM
    dee_bo
    dee_bo Well-Known Member
    DFW
    2007 TRD Sport Tacoma
    None yet
    Dealer is never the best place to do anything unless you don't mind paying extra lol
  8. Feb 20, 2010 at 4:18 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Since I sort of had the same question, everyone pointed me to other threads and other websites where they say it's NORMAL for the coolant to go down over time (evaporation mainly from the reserve bottle itself). So it really depends on where it was when you bought it. After 5 years, mine is still above the low line when it's cold. So maybe you have a leak, and maybe you don't. Personally, I would just look around for any pink stains where the hoses are and fill up the reserve bottle. Then monitor it. Maybe use a permanent marker and mark what the level is after you fill it up (and do it when it's cold).
  9. Feb 20, 2010 at 4:57 PM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    +1
  10. Feb 20, 2010 at 5:01 PM
    YoterHead
    Also good advice. I've had the truck for two years now. I've never added coolant to it. Unless the dealer has been doing it at oil changes/services, then it might just be normal. I topped it off and will keep an eye on it over the next few weeks.
    Thanks for the help.
  11. Feb 23, 2010 at 11:31 PM
    Bodete
    Bodete Well-Known Member
    Missouri
    2009 SR5 DC LB 4x4
    Eibach springs w/ 5100 Bilstein shocks set to "0", Rear TSB
    Make sure you look the radiator over good with a flash light from every direction possible. I had a 06 explorer that every time I filled the reserve tank it would be empty in a couple of months and with no dips on the garage floor. This went on for 6 months before the leak got big enough to start leaving a spot on the garage floor. It was leaking so slow that it was evaporating within a couple of inches from the leak. It was very had to spot the leak because of location.
