Low Oil Pressure... Engine replacement?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loudog504, Dec 24, 2022.
  1. Jan 1, 2023 at 12:22 PM
    #181
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    The truck just ended it’s warranty., I’m pretty sure Toyota will honor the repair.
    Loudog504[OP] likes this.
  2. Jan 1, 2023 at 12:54 PM
    #182
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Usually if it out of warranty by a month, they can do something. More than that its a crap shoot. I wouldn't hold my breath if so.
  3. Jan 1, 2023 at 2:29 PM
    #183
    Dual Port
    Dual Port Active Member
    B. D.
    21 Tacoma Silver V6
    Do your best with Toyota, if they end up refusing all help get a used motor from www.car-part.com and have it put in. There's hundreds of them listed starting at $2500-3000.
    Good Luck!
  4. Jan 1, 2023 at 2:38 PM
    #184
    jrallan26
    Iowa
    Is the motor a 4.0L V6?
  5. Jan 1, 2023 at 2:47 PM
    #185
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    You’re in the 3rd gen page. OP has a 2017 OR. It’s a 3.5
    Chew likes this.
  6. Jan 1, 2023 at 2:50 PM
    #186
    jrallan26
    Iowa
    Sorry. I only know the first gens.
    stftaco likes this.
  7. Jan 1, 2023 at 3:05 PM
    #187
    TacoTuesday1
    SD CA
    Synthetic oil change is due every 5k mi.
    This is not some light use passenger car with a large filter and oil capacity that does 10k, set up by car companies for your vehicle to break once it's out of warranty to make you buy the newer turd.
    5k is the minimum, possibly even more if subjected to hard use. Depends on the quality of the oil. Some people use high quality proven oil, some people use cheap shit.
    Other manufacturers may goodwill (partial or complete coverage of repair) slightly out of warranty, provided vehicle has proof of other things being done, like a minimum of good services.
    Toyota is known for not doing that.
    It is also suspicious that Toyota has chosen not to put the 3.5L into the 5th Gen 4Runner.
    I also don't think that Toyota, who has intentionally fucked up the design of all of these trucks since 2005, is going to care. Their plan has been the opposite.
    When other brands revise bad parts to fix them, Toyota does not. When other brands design parts to be proven and common sense, Toyota alters the design to be garbage.
    They also pay shit for warranty times. Perhaps they don't have the money.
    The pictures do not show excessive wear. It takes a lot.
    IF, there is excessive wear, that can certainly cause low oil pressure, because engineers design oil to flow through a passageway with a certain level of pressure. If that passageway is suddenly worn out to be way bigger (such as wear, or mechanical failure), the pressure drops and fails to reach further up components at the required high pressure, failing to lubricate them as well.
    Usually monitored by multiple pressure sensors.
    Or, wear/failure can clog the oil delivery system, whether that be a pickup tube screen mesh or otherwise.
    All is easy to inspect yourself on a truck, including filter, draining oil, and dropping lower oil pan to inspect inside and look upwards at pickup tube with a flashlight.
    The tech may just want to quote you an engine. It's more lucrative. Or perhaps they have enough experience with these trucks to know it may need one.
    Or maybe they don't have experience with high mile trucks, because people don't take high mile trucks to dealers.
    Some techs know their TSB's and check them. Some just glance at the vehicle and quote to the moon, which is certainly faster, especially if you live in a flat rate state (every state that is not California); not to mention on a brand that, again, does not pay well for warranty to begin with, if you've not paid hour diagnostic minimum.
    From what I gather, you have not spoken to the actual tech working on the vehicle, or even know his name or who is working on it. That also is probably not a good thing. I know some dealers also require videos to be sent to customers, of 4-5minutes, plenty of time to show their findings, provide explanation, etc. Very easy to do. Doesn't sound like that happened either.
  8. Jan 5, 2023 at 2:07 AM
    #188
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Update?
  9. Jan 5, 2023 at 3:09 AM
    #189
    Loudog504
    Loudog504 [OP] Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Nothing yet. Spoke to Toyota corporate on Tuesday to get an update and the case manager said they left a message and haven't heard back from the dealer. Then spoke to the person at the dealer that was suppose to have gotten that message and he said no one reached out. The case manager said that she would contact me by Wednesday with an update and I didn't get a call.
    Yeah so overall not a good feeling so far lol.
    Guess I'll call again today.
    Called again today and the Dealership guy is out today returning tomorrow and the Toyota Corp case manager was "Unavailable" but would return my call in 24 hours.
    So most likely no new news until next week if i had to guess.
    shakerhood, minium and AthensTac like this.
  10. Jan 5, 2023 at 3:13 AM
    #190
    2018 Silver Tacoma
    2018 Silver Tacoma New Member
    Lester
    Oil is cheap in comparison to engines. My Taco has its oil changed every 6 months (3-4k miles). I just got rid of a 2005 Corolla with 227,000 miles and it didn’t use any oil.
  11. Jan 11, 2023 at 3:55 PM
    #191
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Any updates?
  12. Jan 11, 2023 at 4:03 PM
    #192
    Loudog504
    Luis
    Baton Rouge, LA
    Nothing new. Still waiting. The dealer said corporate requested some information that they sent Monday so at least the ball is rolling.
  13. Jan 13, 2023 at 4:06 PM
    #193
    Loudog504
    Luis
    Baton Rouge, LA
    Finally got a hold of Toyota corporate after the case officer didn't call me back for close to 2 weeks after 3 call back request... Basically said there is no goodwill that can be offered.
    I asked what she reviewed and she basically read back the email that the dealer told me they sent her. I said do I have any options that Toyota would assist with. She said there is no good will that can be provided.
    I asked are there any reasons why a Tacoma with all maintenance completed by the dealer would fail after 95k miles... She said while its unusual it does happen...
    I requested for a supervisor or manager to review my case. Not hopefully but said they would contact me by Wednesday.
  14. Jan 13, 2023 at 4:09 PM
    #194
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    and this was 4 days out of warranty?? If so, that sucks! I get there has to be a cutoff somewhere,,, sometime, at some point, but 4 days not to provide some kind of assistance is silly.
    DES2009 likes this.
  15. Jan 13, 2023 at 4:11 PM
    #195
    jrallan26
    Iowa
    I’m shocked!
    AZ Pete likes this.
  16. Jan 13, 2023 at 4:26 PM
    #196
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    You might still have a shot . Keep pressing
    If not get a salvage motor and have a private shop drop it in . I’ve worked on cars my whole life and unfortunately sometimes shitty stuff like this happens . All it takes is a small flaw somewhere and it will crop up later. Even with so called bullet proof stuff. Other times you have an engine with known flaws and nothing happens . Luck of the draw . Sorry this had to happen to you.
  17. Jan 13, 2023 at 4:38 PM
    #197
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Dealer has goodwill they could offer. Toyota not so much.
  18. Jan 13, 2023 at 4:46 PM
    #198
    TruckGuy63
    Gilbert
    New York
    Bad times right now is not helping . Lots of businesses are feeling the crunch as with most people. They are watching profits shrink .
    AZ Pete likes this.
  19. Jan 13, 2023 at 5:42 PM
    #199
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sit down with the service manager and the GM. Ask them if they’re willing to the job at internal shop rates on the labor and parts. You never know and it never hurts to ask. Or even at employee cost which at most dealers is cost + 10-20 percent.
  20. Jan 13, 2023 at 6:13 PM
    #200
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    This is the reason I never buy extended warranties, and bank the money instead. Something is likely to come up, better have the money in your pocket.
    And the PCV valve too?
    While changing the oil @5k with fresh clean oil helps to remove harmful contaminants and wear debris that can attack seals and gaskets, a worn PCV valve can raise those crankcase pressures and can cause oil leaks & seeps.
    Notice that by the time the valve is replaced in this video, it was too late for the gaskets and by the time the CEL came on, the damage was done.
    https://www.youtube.com/watch?v=gaHriGHfxss
    OP, at first I thought you might need a bigger truck and suggested a trade in, as there might be other expensive repairs. But if I were in your shoes. I’d look for a shop or tech with TOYOTA experience that can do an engine swap.
    Many good suggestions here on how to go about finding a good engine. Just find a shop and get a price then make a decision.
    Good luck what ever you do
    usmc2msu likes this.
