Low Oil Pressure... Engine replacement?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Loudog504, Dec 24, 2022.
  1. Dec 28, 2022 at 2:20 PM
    #161
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Off highway mobile equipment. Think skidders, tractors etc. Engines basically have two speeds... Low idle and high idle. Torque requirements change, rpm does not.
  2. Dec 28, 2022 at 2:55 PM
    #162
    alwaysHI
    alwaysHI Well-Known Member
    2017 MGM DCSB
    Pro Comp 6", full length 5100's with OME 888 w/ taco lean spacer, 5160s w/ Alcan custom pack, HS extended brake lines, Summit offroad Dakar 17x9, 315/70/17 Falken Wildpeak MT, Nitro 4.88 regear
    Got it. I see what you’re saying.
    but with the cost of fire apparatus’, I’m sticking with the manufacture recommendations
    OP, sorry to have derailed your thread
    hiPSI[QUOTED] likes this.
  3. Dec 28, 2022 at 4:58 PM
    #163
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    There is a motor and transmission, crawl control with 17k miles on it for sale in the FB Tacoma parts swap page for $2000.
  4. Dec 31, 2022 at 1:45 PM
    #164
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    Any updates on this?
  5. Dec 31, 2022 at 1:50 PM
    #165
    Loudog504
    Loudog504 [OP] Well-Known Member
    Luis
    Baton Rouge, LA
    2017 Tacoma TRD Off-Road 4X4 DCLB
    Nothing yet. I'm waiting to see if Toyota corporate will help out and this week definitely isn't a work week for most people.
    Hopefully hear something early next week.
  6. Dec 31, 2022 at 2:05 PM
    #166
    woodsy
    Ohio
    Thanks. I hope it works out for you.
  7. Dec 31, 2022 at 5:26 PM
    #167
    AZ Pete
    AZ Pete Well-Known Member
    Arizona
    best of luck
  8. Dec 31, 2022 at 6:06 PM
    #168
    minium
    minium Well-Known Member
    2017 Inferno Tacoma TRD Off Road
    Curious, did the dealership give you a trade in price, I’m sure it’s still worth a decent chunk at auction. Also wondering if they’d help you roll that thing into a new one or if they’ve discussed that with you.
    I’m def not happy with the history on that truck though, particularly the timing cover - I wonder if an independent shop could just crack that open and determine anything?
    Jan 4th we’ll have had our ‘17 for 6 years, I have 100,650 miles on it. First accident last week as I was parked and someone backed into it. I’m such a baby about it I was considering trading it in after it got repaired .
  9. Dec 31, 2022 at 8:17 PM
    #169
    Bigmatt503
    Bigmatt503 Well-Known Member
    Stop using this video as an example. It's not a tacoma engine. The engine the CCN uses in the video is a turd, the camry engines in that generation had oil issues no matter when you changed your oil. Find a 3.5 with similar issues and link that
    zoo truck likes this.
  10. Dec 31, 2022 at 11:51 PM
    #170
    minium
    He also mentions in this video the oil was changed at the dealer and they use bulk oil so you getting the cheapest oil not the best oil.
    I would like his take on those of us that change our own oil using quality products.
    zoo truck and 22Coma6MT like this.
  11. Jan 1, 2023 at 5:48 AM
    #171
    22Coma6MT
    22Coma6MT Well-Known Member
    2022 TRD Sport AC 6MT
    it seems many overlook that toyota recommends both 10K and 5K OCI, depending on use. and what's important is this may change throughout the year or life of the truck.
    i would bet many people that go by the 10K OCI actually fall into the 5K category, at least at certain times.
    DRAWN, usmc2msu and minium like this.
  12. Jan 1, 2023 at 6:23 AM
    #172
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Great advice. Add one thing further. Make nice with your local machine shop.
    AM6217 likes this.
  13. Jan 1, 2023 at 6:43 AM
    #173
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Just want to put out some facts about diesel engines and idling. First the engine will idle just fine... the issue is cylinder pressure. A diesel engine runs off fuel volume delivery opposite of a gas engine that uses air volume delivery. What this means it the fuel is metered to control RPM. There is no air throttle valve. ( except newer versions like CM2350 ISB Cummins engines but still not used to meter airflow into the engine )
    So the engine at idle has a very small amount of fuel injected to maintain idle, this results in very little cylinder pressure. Cylinder pressure is needed to push the rings outwards against the cylinder walls. Without this pressure, the cylinders can get washed out causing excessive wear and oil contamination. Another issue is heat, at idle a diesel engine creates very little heat. This causes more cylinder pressure issues because the pistons shrink and causes my bypassing of the rings. This is why highway tractors have the grille covers even in mild climates. The grille cover is just a bandaid solution though... newer commercial vehicles will use a diesel auxiliary heating unit like Spheros or a Proheat unit.
    The use of a hi idle switch is always the best way to idle a diesel engine. This will increase cylinder pressure and produce a little more heat. It still isn't the best... diesels prefer to work hard and will last much longer as a result.
    This information is applicable regardless of emissions compliance such as mechanical or electronic injection, pre-EGR, equipped with DPF or equipped with SCR emissions systems... these are add ons, and do not change the basic engine design or operation.
  14. Jan 1, 2023 at 8:13 AM
    #174
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I've always gone with 5K intervals in my Toyotas. Never had an engine problem, but that's probably a combination of doing the maintenance at those intervals and how well Toyota engines are built.
    Back in the 1970s and '80s when Toyota started to sell in volume, my dad owned an auto salvage. He sold a lot of used GM, Ford, Chrysler engines both to independent and dealer shops. Way up back in the yard there was a mountain of engines destined for scrap. There were piles of perfectly good Toyota engines because no one ever needed them. The one exception was this crap box 1972 Carolla that some gave him because the engine had blown at about 150K miles. Since we had dozens of perfectly useable engines in completely rusted out Carollas we just pulled one and dropped it into the car. I drove that for a few years until the floor boards rusted out. The only thing I had to do was brakes and replace a rear axle bearing.
    BTW, this is the perfect TW thread. It starts with a guy who possibly has a blown engine, to a discussion of diesels and fire trucks, to me talking about cars from the 1970s.
    rkd1119, AZ Pete and usmc2msu like this.
  15. Jan 1, 2023 at 8:47 AM
    #175
    Loudog504
    Luis
    Baton Rouge, LA
    No, no trade in offer. I'm mainly dealing with the service side at this point. I'm sure if nothing comes from Toyota they may offer a trade, but who knows.
  16. Jan 1, 2023 at 9:13 AM
    #176
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Why are we talking about things from half a century ago. In the 70s were you taking advice from people that were shoveling horse shit in the 1920s?
    mrkabc likes this.
  17. Jan 1, 2023 at 9:18 AM
    #177
    HisDad
    Texas at last
    For the same reason we're talking about diesel engine idling in a thread about a blown Toyota gasoline engine.
    Because we can.
    69 Jim and Speedfreak like this.
  18. Jan 1, 2023 at 9:20 AM
    #178
    alwaysHI
    2017 MGM DCSB
    Thank you sir
    Speedfreak[QUOTED] likes this.
  19. Jan 1, 2023 at 9:33 AM
    #179
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Can relate..I had a Datsun 280ZX as a teenager that turned out to be rotted out underneath..frame, floorboard, etc. No problem I think, running gear has 75K so I'll sell it to someone who needs an engine/trans and get some money
    Nope.
    Nobody had any use for it for those same reasons you mentioned.
    HisDad[QUOTED] likes this.
  20. Jan 1, 2023 at 11:46 AM
    #180
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Thing is toast , dealer ain't gonna do anything but string you along a few days while they await word from corporate . Then you will get the phony "sorry we tried BS". Then right back trying to get you to fold for the new motor. Fuck em find a local guy that specializes in foreign vehicles.
