Low oil pressure & high ATF temp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by frenchyofcp, Dec 19, 2017.
  1. Dec 19, 2017 at 6:19 PM
    frenchyofcp
    frenchyofcp [OP] Active Member
    Taylor
    2017 TRD OR DCSB MGM
    Hey,
    Just looking for any input. I have a 17 TRD offroad DCSB Auto 4x4. A little over one year of ownership and 11k miles. I drove to work 28 miles, truck was a okay. I go to move it, start, put into drive and it shuts off before I push the gas. Low oil pressure light pops up and then high ATF temp. Nice huge red warnings along with a CEL. I turn the truck off for a minute, restart, good to go. Drove it to the dealer, no word yet.
    Has this happened to anyone? or does anyone have the slightest idea what those two could coincide with? Dealer should get back to me by the end of tomorrow, just wanted to check with TW. Unfortunately the truck has been nothing but a pavement queen for months so its pretty darn clean. Along with all the random clanking, shuttering on accel and other drama, im kind of done with this thing. Got this truck for no drama, oh well.
    TruckMan77 likes this.
  2. Dec 19, 2017 at 6:22 PM
    Garrett75x
    Garrett75x Well-Known Member
    Torrance
    2017 TRDOR 4x4 JBL P&T
    Pro Grille, Shmellfab rock sliders, Carhartt seat covers
    Crank Position Sensor
  3. Dec 19, 2017 at 6:27 PM
    frenchyofcp
    Taylor
    Is it "glitching" with this CPS?
  4. Dec 19, 2017 at 6:35 PM
    Garrett75x
    Torrance
    I'm not exactly sure, but there has been cases where the sensor lets go and people are left dead in the water with those warning lights
    It will be fixed under warranty
  5. Dec 19, 2017 at 6:45 PM
    frenchyofcp
    Taylor
    That would be sick. Fingers crossed. Thanks man!
  6. Dec 19, 2017 at 7:19 PM
    Friggin Fuego
    Friggin Fuego Well-Known Member
    2004 Toyota Land Cruiser, 2007 Toyota FJ Cruiser 6MT 4x4, 1988 Toyota Hilux SSR Diesel 5MT 4x4
    Are you located in a warmer climate OP?
  7. Dec 19, 2017 at 8:01 PM
    frenchyofcp
    Taylor
    It was 45 outside when it happened.
  8. Dec 20, 2017 at 1:48 PM
    frenchyofcp
    Taylor
    Turns out there is a small dent on my tranny pan. Apparently that's the rout of all evil. Toyota only wants $750 to replace the pan and then further investigate. HMMMMMMMM
  9. Dec 20, 2017 at 3:00 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The dealer is probably the one that dented the trans pan.
  10. Dec 20, 2017 at 3:18 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Pella and shakerhood like this.
  11. Dec 20, 2017 at 3:52 PM
    jmaxwel8
    jmaxwel8 Well-Known Member
    Tennessee
    2016 White off-road
    If you have time could you get a picture of the dent? I’m really curious about this
  12. Dec 20, 2017 at 3:58 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    I have a hard time believing that a dent in tranny pan causes high tranny temp and low oil pressure. Neither one of those problems are related. They are two different part assemblies. The only common the two have is in gauge cluster. That's where I would start.
    I think further investigate is key word after they sale you a pan and labor. They will fix a warranted issue.
  13. Dec 20, 2017 at 4:36 PM
    SWB Tacoma
    Arkansas
    I would like to add. If both tranny fluid and oil for engine run through same cooler but divided and one of those is have problems. It could effect the other. By heating up or thinning oil.
    ancient11 likes this.
  14. Dec 21, 2017 at 4:00 PM
    SWB Tacoma
    Arkansas
    Just curious to what problem was when you get it fixed?
  15. Dec 23, 2017 at 7:56 AM
    mastro1
    mastro1 Well-Known Member
    2017 MGM DCSB TRD Sport
    It's possible if the pan is bent it can restrict flow due to the trans filter/pic up is on the bottom in the pan, causing the trans to run hot.
  16. Dec 23, 2017 at 11:23 AM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    Is it possible that low oil pressure alarm is just from the engine failing to start? It’s a common affect I see on other types of engines Ive worked on.
  17. Dec 23, 2017 at 11:43 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Ugh, that’s what armor would have cost, now you gotta buy a $750 pie pan?? :eek: Can’t they just pop out the dent?!! Seriously!:mad: I’m so mad at them for you!
    Too bad you can’t take it home, pop out the dent yourself, and then return it... I’ve done that to body shops before, even if it’s not a clean fix, it’s easy enough knocking out some of the dent to make it look smaller before letting them see it - I’ve saved hundreds doing that for myself and for a few friends.
  18. Dec 23, 2017 at 11:52 AM
    OnHartung'sRoad
    Yeah, the mechanic must have stood up under there, accidentally bumped it with his head, and said “ouch, that hurt” and went on with his business. Now his pie tin is dented.
    But really, I’ve seen a local shop do that with their oil changing stand- they left it under the car when they lowered it! Another place I won’t mention left their filter wrench on my Gen 1, then left my skid plate hanging by 4 lose bolts without telling me because they couldn’t get the plate back on due to the wrench. I almost lost the plate driving home. That’s what happens when you do a lube in a jiffy, I guess. I won’t go back to that place (I won’t mention) for any oil changes, ever.
  19. Jan 20, 2018 at 11:06 AM
    frenchyofcp
    Taylor
    Thanks for all your input guys. I got a pan through parts and fixed it no problem. Truck hasn’t had a hiccup since the first one. I think it just glitched as it was the first coldest day. And Toyota just had to bullshit me. Oh well. Just drove to Vegas and back and it was great. Now unfortunately I have to sell it as I have new job and will be driving 24-7. If anyone knows anyone that’s looking. It’s a lease takeover. 350 a month with asking $10k down. Message if interested.
  20. Jan 20, 2018 at 8:43 PM
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    Smooth transition, lol. Don't blame you for wanting to jump ship.
