low pressure light on after new tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by texasedition, Sep 14, 2008.
  1. Sep 14, 2008 at 12:09 PM
    texasedition
    texasedition [OP] Member
    El Paso TX
    tacoma Texas edition
    3in toytec lift, Borla exhaust, 33x12.50x20 nitto grapplers
    anyone out there with the low pressure light on after putting new tires on it!!!!
  2. Sep 14, 2008 at 12:10 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Have you checked the spare? I would start there and if it isn't that, take it back to the tire shop.
  3. Sep 14, 2008 at 12:29 PM
    texasedition
    El Paso TX
    thanks for the info. What about putting 33x12.50x20 does that have anything to do with it?
  4. Sep 14, 2008 at 12:38 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    If you installed new rims and tires you need to have the TPMs on the new rims. If all you did was add tires, I suspect thats what you did, you will have to set your new psi. Inflate all 4 tires to the psi you want and press and hold the button to reset the sensors. I changed my tires and kept my factory spare haven't had my light come on yet except when I lower the psi in my tires. Maybe my spare dosen't have a sensor. If that dosen't work, check this out My TPMS Sensor DIY
  5. Sep 14, 2008 at 12:48 PM
    Marc M
    Marc M Dirty White Boy
    Marc
    Washington, Pennsylvania
    '06 TRD O/R Dbl-Cab
    TRD Cat-Back, TRD CAI, 3" Lift, ATX Chambers, Color matched Grille and Door Handles, Scooped Hood, GrillCraft upper and lower, DTRL, Foglight Mod, Redline Hood Struts, 20% Tint all around, SGII, Blacked out dash, Extang Full-Tilt, etc, etc, etc.
    They probably broke one of your sensors...:(
    Marc M
  6. Sep 14, 2008 at 1:34 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    ^Yeah, wouldn't surprise me. That is the basis of my "take it back to the tire shop" comment.
    luk has some good info there. Definitely check into that.
  7. Sep 14, 2008 at 2:13 PM
    InaKoma08
    InaKoma08 INAKOMA08
    Nokesville, VA
    2008 TRD Access Cab
    FABTECH 6" Lift, 17x9 Moto Metal MO951, 35x12.50x17 Mickey Thompson Baja ATZ, Line Of Fire, Jardine Catback,
    I just put my rims and tires on yesterday. Light came on last night, and this morning it reset it self finally and turned off :)
  8. Sep 15, 2008 at 6:08 AM
    texasedition
    El Paso TX
    Thanks luk it was it spare. i forgot it had a sensor
